Espritmodel.com Heli Air
Old Jan 26, 2013, 11:46 AM
always something to learn...
metalguy's Avatar
Tacoma, WA
Joined Jan 2011
HobbyB has it for $70.00. Prettiest plane I have bought in a while. If I wasn't such an idiot, it would still be pretty!------Metalguy
metalguy is offline Find More Posts by metalguy
Old Jan 26, 2013, 01:16 PM
You haz hurricane?
Coot83's Avatar
United States, VA, Portsmouth
Joined Jun 2012
Is this easy to fly on 3s if I drop in a 30 amp esc? My 800 FMS FW 190 flies on 3s and man it rips. Also does it land well?
Coot
Coot83 is online now Find More Posts by Coot83
Old Jan 26, 2013, 01:23 PM
Reap the wild wind
headlessagain's Avatar
Bristol,UK
Joined Feb 2007
I've no doubt that the airframe could handle a 3 cell's extra grunt but, without some modification, you will only be able to fit a small pack as the battery compartment is small. I used to run my 800 series FMS "Jug" on 3s and it was a blast.
I'd say it would land at a similar speed to the FMS models which seem to glide on forever.
Andy
headlessagain is offline Find More Posts by headlessagain
Old Jan 26, 2013, 01:27 PM
You haz hurricane?
Coot83's Avatar
Joined Jun 2012
I have no problem hollowing out foam for the batteries to fit as my FW required the same thing. I have been flying with a 1000 mah 3s and I hope I can do that with this plane. I will have to pull the trigger on this next month since I just got a back up eflite hurricane.
Coot
Old Jan 26, 2013, 01:57 PM
Reap the wild wind
Bristol,UK
Joined Feb 2007
The Hurri has a ply plate under the lipo which you would have to remove. I'm not sure how important this is the the integrity of the airframe/wing mount. Perhaps other's who have gone that route will chime in.
Andy
Old Jan 26, 2013, 09:02 PM
You haz hurricane?
Coot83's Avatar
Joined Jun 2012
Could somebody take a picture of the battery bay of this plane? I would like to see what I am dealing with as far as room. Thanks in advance!
Coot
Old Jan 27, 2013, 02:13 AM
Reap the wild wind
Bristol,UK
Joined Feb 2007
See here http://www.rcgroups.com/forums/showp...7&postcount=78 for pictures of my Hurri with a 800 2S pack in situ. I had to remove the ridges from the canopy lid to get it to close. My Hurri is inaccessible at the moment (no, not in a tree) due to my son's clutter but I'll try to get some pictures later.
Andy
Old Jan 27, 2013, 06:59 AM
Low'n Slow is safest, right?
KaiWE's Avatar
Norge, Østfold, Fredrikstad
Joined Jun 2011
Coot
Earlier post by my self:
I have room for my NanoTech 2s 1300. They are same height and width as the 2S 850, but 15mm longer - there is plenty of room lengthwise, the height/width are the limiting measurements...
Just for the fun of it - I just tried with a NanoTech 3cell 1300 25-50c, and they will fit with a minimal shave on the ridges off the inside of the hatch - but it makes the plane way to nose heavy,, the wing loading will increase, no doubt ruining the sweet handling, and there is in my opinion not a single reason to use 3 cell in this plane. It already have thrust over 1:1 and it is a warbird, not a 3D plane...
And I must ask again, why run this plane on 3-cell? It is (for its size) a good looking warbird with plenty scale details and more than enough power on 2-cell.
It has a trust/weight ratio over 1:1 with the stock setup, and will perform all warbird aerobatics without any hesitation. It is not a 3D plane, and a Hurricane is not the ideal starting point for a Reno Racer either. If it is a pylon racer you are looking for, why not start out with a more suitable airframe, like the FunFighter series from J-Power?
I cannot see any reason to fly this on 3 cell, so could anybody please enlighten me? I have no problem seeing the need for 3cell in the 800mm FMS warbirds (I have 6 of those), they are clearly lacking power when run on 2 cell, but this one is not...
KaiWE is offline Find More Posts by KaiWE
Old Jan 27, 2013, 07:53 AM
You haz hurricane?
Coot83's Avatar
Joined Jun 2012
I figured this plane was very comperable to what the 800 scale fms warbirds are like which is why my FW is on 3s. What speeds are you guys getting with it? I dont mind flying on 2s, I just get worried that I will get bored with it pretty quick. Also with a 12 amp esc, does it get hot quick? I have a 20 amp lying around that I could throw in it.
Coot
Old Jan 27, 2013, 09:20 AM
Reap the wild wind
Bristol,UK
Joined Feb 2007
I'll apologise if I've already posted this video but here's the maiden flight of my Hurri. Still on the stock 3 bladder. Video was shot on a misty morning with my #16 HD Keycam so do select "HD" when viewing.
Top RC Hurricane maiden flight 7th Oct 2012 (5 min 21 sec)
Andy
Old Jan 27, 2013, 11:02 AM
KaiWE's Avatar
Joined Jun 2011
Coot
No problem with my Stock ESC so far...
I took a couple of pics to illustrate what fits:
First pic is a 3 cell 850, fits without any modifications.
Next, 3 cell 1300, small modification of hatch required.
Last pic shows these two batteries compared to the one I fly with - 2 cell 850.
Posted video of the Hurri flying with 2 cell 850 in post #45 in this thread...
Old Jan 27, 2013, 02:04 PM
metalguy's Avatar
Tacoma, WA
Joined Jan 2011
This has no real need for 3s. It certainly doesn't need the extra weight, either. I will probably get another, as I messed mine up due entirely to pilot error, and because I tinkered with it a bit too much! -------Metalguy
Old Jan 27, 2013, 03:37 PM
You haz hurricane?
Coot83's Avatar
Joined Jun 2012
Kaiwe, thanks for the pics! Out of curiosity, how fast would you say this goes with the stock setup?
Coot
Old Jan 27, 2013, 05:55 PM
metalguy's Avatar
Tacoma, WA
Joined Jan 2011
50???MPH, I would guess. ANd its a WAG.-----Metalguy
Old Jan 27, 2013, 07:44 PM
You haz hurricane?
Coot83's Avatar
Joined Jun 2012
What WAG?
Coot
New Product 700mm WS Hawker Hurricane anj4de Electric Warbirds 17 Aug 23, 2012 03:45 PM
Sold Eflite Hawker Hurricane 25e Retracts!! BNF Deal!! $200.00 LPU drewpert15 Aircraft - Electric - Airplanes (FS/W) 13 May 26, 2012 05:52 PM
Build Log 45" Hawker Hurricane playaviation Foamies (Scratchbuilt) 38 May 06, 2012 10:42 AM
Discussion Mick Reeves Hawker Hurricane 1/6 scale Kit -Exlex- Fuel Warbirds 5 Mar 25, 2012 06:55 PM
Sold E-flite hawker hurricane 25e bnf hi2nr Aircraft - Electric - Airplanes (FS/W) 7 Mar 06, 2012 08:21 AM
