Old Oct 12, 2012, 05:13 AM
KaiWE is offline
Find More Posts by KaiWE
Low'n Slow is safest, right?
KaiWE's Avatar
Norge, Østfold, Fredrikstad
Joined Jun 2011
And came back from flying just to buy another one not exactly scale :
http://www.hobbyking.com/hobbyking/s...00mm_PNF_.html
But rest assured - a Windrider Hurricane is on its way, and then at least I'll have one that can be made fairly accurate
KaiWE is offline Find More Posts by KaiWE
Old Oct 12, 2012, 04:28 PM
metalguy is offline
Find More Posts by metalguy
always something to learn...
metalguy's Avatar
Tacoma, WA
Joined Jan 2011
I saw that one! Funny how it seemed like there weren't many hurricanes out there, and now it seems many! I had expo turned up to 100%, and I probably should have had it down for maiden. I have since turned it down some, and it should work better for my heavy hands. I would hate to crash it, it is just so pretty! LOL! -----Metalguy
metalguy is offline Find More Posts by metalguy
Old Oct 15, 2012, 10:46 AM
metalguy is offline
metalguy's Avatar
Tacoma, WA
Joined Jan 2011
*sigh* windy, and rainy. again. Looks like summer is over here until next July 5th. ----------Metalguy
Old Oct 22, 2012, 12:01 PM
metalguy is offline
metalguy's Avatar
Tacoma, WA
Joined Jan 2011
I broke the prop! Anyone have a replacement size? Hobbyb has no spares listed. I would even go for a 2 blader, just to fly.... anyone flying with a 2 blader??-----Metalguy
Old Oct 22, 2012, 01:25 PM
headlessagain is offline
Find More Posts by headlessagain
Reap the wild wind
headlessagain's Avatar
Bristol,UK
Joined Feb 2007
I used a 2 blade 8x6 APCe style prop http://www.rcgroups.com/forums/showp...4&postcount=44
headlessagain is offline Find More Posts by headlessagain
Old Oct 22, 2012, 02:15 PM
KaiWE is offline
KaiWE's Avatar
Joined Jun 2011
Rc-castle.com have them in stock at $3.20 - I bought 3 extra + a spare spinner when I got my Hurri...
Old Oct 23, 2012, 03:59 PM
chops3 is offline
Find More Posts by chops3
New Zealand, Canterbury, Christchurch
Joined Aug 2011
can this fly with a 3 cell.
thanks.
chops3 is offline Find More Posts by chops3
Old Oct 23, 2012, 04:41 PM
Reap the wild wind
Bristol,UK
Joined Feb 2007
Your problem will be fitting a 3s pack. There is nowhere near the space afforded by say the Skyangel/HK Funfighters where some have gone as large as a 2200 3s pack! You would probably need to do major surgery as even a 3s 500 pack would be too deep to fit under the hatch. I had to remove the inner canopy ridges and carve out some foam infront and behind the lipo compartment to fit 2S 800 packs Gens Ace 800 2S1P 20C Lipo Battery
Weight: 45g
Capacity: 800mAh
Voltage: 2S1P (7.4v) 2 cell
Discharge Rate: 20-30C
Andy
Old Oct 23, 2012, 05:23 PM
KaiWE is offline
KaiWE's Avatar
Joined Jun 2011
thanks.
May I ask why? It has more than adequate speed on 2 cell.
Andy: are we talking about the same plane here?
I use NanoTech 2S 850mAh 25-40C. They are 60x31x16 and fits with plenty of room to spare...
I even tried a Nano 3S 850 850mAh 25-40C, at 63x32x25 just now - they fit very snug, but I would have had to shave 2mm off the ridge in front of the hatch to get it flush. Not that I would ever fly with that, to heavy, and I do not by any means need more speed.
Old Oct 23, 2012, 05:29 PM
huntingfield is offline
Find More Posts by huntingfield
Clean up! The missus is home
huntingfield's Avatar
United States, MD, Salisbury
Joined Dec 2007
Agreed, this plane flys great on 2 cells!
huntingfield is offline Find More Posts by huntingfield
Old Oct 23, 2012, 08:05 PM
metalguy is offline
metalguy's Avatar
Tacoma, WA
Joined Jan 2011
I put an 8-6 APC on it for now, but will be ordering some of the stock 3 bladers, thanks!-----Metalguy
Old Oct 24, 2012, 03:37 PM
chops3 is offline
Joined Aug 2011
you say you are useing a NanoTech 2S 850mAh 25-40C
but spec says Battery: Li-Po 7.4V 1000 - 1300mAh so a 2 cell 1300mAh wont fit
Old Oct 24, 2012, 04:18 PM
KaiWE is offline
KaiWE's Avatar
Joined Jun 2011
I have room for my NanoTech 2s 1300. They are same height and width as the 2S 850, but 15mm longer - there is plenty of room lengthwise, the height/width are the limiting measurements...
Just for the fun of it - I just tried with a NanoTech 3cell 1300 25-50c, and they will fit with a minimal shave on the ridges off the inside of the hatch - but it makes the plane way to nose heavy,, the wing loading will increase, no doubt ruining the sweet handling, and there is in my opinion a single reason to use 3 cell in this plane. It already have thrust over 1:1 and it is a warbird, not a 3D plane...
Old Oct 24, 2012, 08:58 PM
chops3 is offline
Joined Aug 2011
[QUOTE=KaiWE;23090698]I have room for my NanoTech 2s 1300. They are same height and width as the 2S 850, but 15mm longer - there is plenty of room lengthwise, the height/width are the limiting measurements...
Just for the fun of it - I just tried with a NanoTech 3cell 1300 25-50c, and they will fit with a minimal shave on the ridges off the inside of the hatch - but it makes the plane way to nose heavy,, the wing loading will increase, no doubt ruining the sweet handling, and there is in my opinion a single reason to use 3 cell in this plane. It already have thrust over 1:1 and it is a warbird, not a 3D plane...[/QUOTE
thank you.
chops.]
Old Oct 25, 2012, 08:49 PM
metalguy is offline
metalguy's Avatar
Tacoma, WA
Joined Jan 2011
I got in some more flying with this beautiful aircraft today. I flew it with an APC 8-6 and a 1000mAh pack after an 800 pack proved to be one of mine that is a little tired. Flies nice, and seems to have ample power. I am afraid there isn't a lot of room, weight-wise for big, heavy packs, but I don't mind less flight times, it is just such a beauty in the air, as well as on the ground. I did notice the landing gear are poorly glued in, as on a smooooooth landing on grass, one came out! Other than that, a really nice plane.-------Metalguy
New Product 700mm WS Hawker Hurricane anj4de Electric Warbirds 17 Aug 23, 2012 03:45 PM
Sold Eflite Hawker Hurricane 25e Retracts!! BNF Deal!! $200.00 LPU drewpert15 Aircraft - Electric - Airplanes (FS/W) 13 May 26, 2012 05:52 PM
Build Log 45" Hawker Hurricane playaviation Foamies (Scratchbuilt) 38 May 06, 2012 10:42 AM
Discussion Mick Reeves Hawker Hurricane 1/6 scale Kit -Exlex- Fuel Warbirds 5 Mar 25, 2012 06:55 PM
Sold E-flite hawker hurricane 25e bnf hi2nr Aircraft - Electric - Airplanes (FS/W) 7 Mar 06, 2012 08:21 AM
