Old Nov 05, 2003, 09:28 PM
Mafu is offline
Find More Posts by Mafu
Gravity always wins!
Mafu's Avatar
Brisbane, Australia
Joined Apr 2003
Foils, washout and tip stall - or Plouf, which foil?
Hi guys,
While procrastinating instead of doing this assignment I am supposed to be doing, I found a couple of threads with the cool 28" v tail the "Plouf". I know have in my virtual hands the plan for this and a CAD version drawn from the plan by a fellow Australian. It looks like a great little plane to play with!
Since I have the CAD version of the wing, when I get to building it, I'll use that - I want to do the foil accurately as well, and so have been trying to work out what to use. I've chatted with a few people about it, and have some suggestions - I am very novice when it comes to foil choice, tip stall, wash out etc, so figure here is the place to ask - I'm sure there are guys out there that know all this stuff, and having been around the forums a while, I know everyone is great with sharing info.
The suggestions I have had for the foil are:
RG15
SD7037
S2091
You can see the plan for the Plouf on this thread - there is a link on the last post of the last page for the download.
http://www.rcgroups.com/forums/showt...ighlight=plouf
So I'm open to suggestions, comments or any lessons in foils/washout/tip stall etc.
Oh - and I'll build it to slope on low to medium wind days - I want something that will fly in light winds, and also do a bit of aerobatics. Cheap and small is good too :-) I figure I need to move on to something I can break - yet afford to fix too :-)
Thanks!
Matt
Mafu is offline Find More Posts by Mafu
Old Nov 05, 2003, 11:03 PM
Ado is offline
Ado
Find More Posts by Ado
Ado
Meow?
Ado's Avatar
Brisbane Intl, Australia
Joined Sep 2001
Buy a mini weasel :P
Ado is offline Find More Posts by Ado
Old Nov 05, 2003, 11:23 PM
Mafu is offline
Mafu's Avatar
Brisbane, Australia
Joined Apr 2003
LOL - you are such a help You know I want one of those too - but this one will satisfy the building from balsa need :-) Besides, I want to learn a bit more about foils etc!
Matt
Old Nov 05, 2003, 11:49 PM
Ado is offline
Ado
Ado
Meow?
Ado's Avatar
Joined Sep 2001
I have the plans for the Plouf aswell....never got around to building it though.....be interested on how yours turns out.
Old Nov 06, 2003, 03:12 AM
TCM is offline
TCM
Find More Posts by TCM
TCM
TCM's Avatar
UK, County Antrim, Belfast
Joined Aug 2002
Mafu
I have just built the Plouf as per plans. Wanted something cheap to try slope soaring with. I can't help as per wing section but all I can say it is a realy fun glider which has inspired me to get into slope soaring. Just make sure you reduce the wing incidence from that on the plan.
Tim
TCM is offline Find More Posts by TCM
Old Nov 06, 2003, 05:07 AM
Mafu is offline
Mafu's Avatar
Brisbane, Australia
Joined Apr 2003
Hi Tim,
How much did you reduce it to - from the plan I worked out (and I think I calculated it correctly!) it is about 6.2 degrees. Are you talking a big reduction? or a small reduction - like 4 degrees? And do you mean by dropping the carbon joining spar, or raising the locator dowel?
Thanks!
Matt
Old Nov 06, 2003, 07:20 AM
TCM is offline
TCM
TCM
TCM's Avatar
Joined Aug 2002
I raised the locator dowel by 2 deg.
Tim
Old Nov 06, 2003, 09:01 AM
TFLG is offline
Find More Posts by TFLG
TFLG's Avatar
United States, CA, Riverside
Joined Feb 2002
How can you build a plane called a "PLOUF"??
If you must then go with an easier airfoil to make than the ones you posted. Those are undercambered and will be hard to make accurately in wood. I'd go with the S3021 or use the ones you listed but take out the slight undercamber near the trailing edge. They will all work fine though. You do not need washout on a plank style wing. Tip stalling shoul not be a problem. You might still stall but it's not likely to be a tip stall.
You're not really gonna build a plane called a Plouf, right? It's like they named it after the sound it makes when it crashes into a huge cow pie!
TFLG
TFLG is offline Find More Posts by TFLG
Old Nov 06, 2003, 10:11 AM
stegre is offline
Find More Posts by stegre
CaliforniaSailplanes.com
stegre's Avatar
So California
Joined Dec 2002
LOL... I really like that TFLG... !!!!!
Steve
stegre is offline Find More Posts by stegre
Old Nov 06, 2003, 02:29 PM
Mafu is offline
Mafu's Avatar
Brisbane, Australia
Joined Apr 2003
Of course I'm going to build it - its a cool little plane and looks like fun to build and fly!
I also grew up on a dairy farm, so the fact it is named after the sound it makes "when it crashes into a huge cow pie!" only makes it more appealing - it takes me back to my childhood ;-)
Thanks for the suggestions for the foil and pointing out it doesn't need washout - that gives a good starting point. The foil on the plan has a lot of undercamber - that's why when trying to match the foil people have suggested foils with undercamber.
This won't be built for a while - I already have a backlog of kits in the garage - but it looks like a great fun one to do a first balsa build on - I do a lot of woodwork, so this doesn't phase me at all.
Thanks again for the suggestions and the laugh :-)
Matt
Old Nov 07, 2003, 12:19 PM
Brian Courtice is offline
Find More Posts by Brian Courtice
Free as a bird now.
Brian Courtice's Avatar
United States, FL, Punta Gorda
Joined May 2002
I know that sound...
For proof, check out the landing my Bluto makes in this video clip.
http://www.flex.com/~mbs/Brian.mpg
Brian Courtice is offline Find More Posts by Brian Courtice
Old Nov 07, 2003, 02:48 PM
wildpalms is offline
Find More Posts by wildpalms
Professional idiot
Hampshire, UK
Joined Jun 2002
Why not use the wing section on the plans? The few I've seen fly seem to do okay.
Just waiting for some clear space on my bench. Hopefully sometime in the next few months I'll get mine done.
Plouf is French for Splash which is slightly less lame.
Dave
wildpalms is offline Find More Posts by wildpalms
Old Nov 07, 2003, 04:18 PM
Mafu is offline
Mafu's Avatar
Brisbane, Australia
Joined Apr 2003
Brian,
Very spectacular :-) LOL
Dave,
The only reason I am looking for a foil is for accuracy - the plan I have is a scanned JPG, and even though its big, when printed at the correct size the lines are less than thin :-) So, I figure if I can find a good similar foil that I can print from a foil program with a nice thin line, I will have a better foil to start with.
I guess I just like to make things accurately - especially when it comes to woodwork :-)
Matt
Old Nov 10, 2003, 08:12 AM
Up&Away is offline
Find More Posts by Up&Away
The original Flying Pigs Sqd.
Up&Away's Avatar
Netanya, Israel
Joined Aug 2002
TFLG
Close Actually, it is originally a french design, to be flown on the Normandy coast. "Plouf" is supposed to be the sound effect of the plane hitting the water
Up&Away is offline Find More Posts by Up&Away
Tip Stall? BNA Bob Beginner Training Area (Aircraft-Electric) 15 Sep 06, 2007 06:07 PM
Tip Stall. Which wing drops? hkowalczyk Modeling Science 15 Jul 02, 2002 06:09 PM
Hitec Focus 3 for Zagi 400? AM or FM? Which one! Josh C Power Systems 5 Jun 08, 2001 10:05 AM
Someone please descibe exactly what a tip stall is. slowflyer Electric Plane Talk 2 Jun 05, 2001 09:29 PM
Transparent Monokote or Solarfilm - Which is lighter?? atsiang Electric Plane Talk 5 Jun 05, 2001 11:30 AM
