| Thread Tools |
| This thread is privately moderated by jjmouris, who may elect to delete unwanted replies. |
The Futaba 12FG motor menu gives you several options to play with. I have highlighted in the respective colour what does what.
The first part of the ramp is called SPEED 1 and the second half is called SPEED 2. The number ranges from 0 to 27 where 27 is really slow and 0 is instantanious. Sensible numbers are between 10 and 24. I always use 10 for speed 1 and something around 22 for speed 2. Then there is the switchover point. This is called (SPEED 1 > 2 ) and can be adjust from -100 to +100. Sensible numbers are around -25 to +10 and you should adjust in steps of 5 or 10% at a time. Note that there is an IN and OUT speed given. You want to add a delay on the ON side only and not when switching OFF the motor. Note that in some cases things may be reversed, it may also depend on if you use a throttle stick or a switch. Try the manual for the TX you have and/or experiment a little with a servo plugged into the throttle channel. Page 103 of the 12FG manual reads MOTOR; http://manuals.hobbico.com/fut/12fg-manual.pdf http://www.futabarc.com/downloads/manuals.html |
| Thread Tools | |
| Question 9X - FlySky/iMax/Turnigy/Eurgle FOR DUMMIES | aeajr | Radios | 578 | Today 04:40 PM |
| Discussion Spektrum DX6i for Dummies? | Scootatrash | Beginner Training Area (Heli-Electric) | 2 | Apr 23, 2012 02:46 PM |
| Discussion Battery nomenclature for Dummies? | overmyhead | Batteries and Chargers | 2 | Mar 25, 2012 06:35 AM |
| Discussion can you dummy this up for me I'm lost | smitty919 | Batteries and Chargers | 2 | Mar 09, 2012 07:50 PM |
| Question Progamming a cc for slow ramp up | Oian | Castle Creations | 3 | Nov 09, 2011 09:03 PM |
