Old Dec 01, 2012, 05:22 PM
Xermalk is offline
Find More Posts by Xermalk
Sweden, Helsingborg
Joined Jun 2012
Is the Spare port on the Master CP Rx controlled by the 7th channel on devo tx'es?
Xermalk is offline Find More Posts by Xermalk
Old Dec 01, 2012, 05:26 PM
BThirsk is offline
Find More Posts by BThirsk
Brent 黑雁
BThirsk's Avatar
Canada, AB, Ponoka
Joined Jan 2012
Originally Posted by candy76man View Post
It's necessary but not the way walkera does it....I think they just dip the whole screw in a vat of loctite when all that's needed is a trace of it on a portion of the threads....I've lost count of how many screws I've had twist in two on walkera rc's because of excessive loctite....and the worst part is there is no easyout small enough for the micro screws on these helis so I end up having to replace the part with the screw broken off inside it more often than not.
It seems like the locker they use is more like CA glue. I had similar problems getting the heads apart on several HobbyKing kits I was building and needed to disassemble to grease and check everything. I needed to use a hot soldering iron to loosen the locker to. Remove the screws. Featuring shafts were the worst. Maybe customery in China to use CA.
BThirsk is offline Find More Posts by BThirsk
Old Dec 01, 2012, 05:34 PM
BThirsk is offline
Brent 黑雁
BThirsk's Avatar
Canada, AB, Ponoka
Joined Jan 2012
That port is designated for the telemetry motor temp sensor. Would they use a standard channel for that.
Old Dec 02, 2012, 06:05 PM
Rain4LA is offline
Find More Posts by Rain4LA
Rain4LA's Avatar
United States, IL, Chicago
Joined Nov 2012
Tool for locking screw on tail rotor assembly?
Just wondering what you guys use to tighten/untighten the little locking screw that keeps the tail shaft on??? It looks like a hex under a magnifying glass, but I don't have anything anywhere NEAR that small.....
Rain4LA is offline Find More Posts by Rain4LA
Old Dec 02, 2012, 06:30 PM
candy76man is offline
Find More Posts by candy76man
alienfpv, warpquad, goby180
Tampa,FL
Joined Dec 2003
If it's the same as mine it's a small philips head screw...any jewelers screwdriver set should have one that will fit.
Be carefull removing it though, the heads twist off those little screws easily so if it doesn't feel like it's budging with moderate force I would use a soldering iron to heat the screw first to soften the loctite.
candy76man is offline Find More Posts by candy76man
Old Dec 02, 2012, 07:12 PM
Rain4LA is offline
Rain4LA's Avatar
Joined Nov 2012
It must not be the same - or we're not talking about the same one. This thing doesn't have a head, and neither does the one in the picture when you order the parts. It's the world's smallest little tiny screw with no head. It's like there's a little hex hollowed out - but again - I don't have anything near that small.
Old Dec 02, 2012, 08:10 PM
mono is offline
Find More Posts by mono
mono's Avatar
Joined Aug 2008
The only screw used on the tail shaft is part 46 in the diagram which goes through the plastic locking collar (part 45) and is a simple phillips head, it's not even that small.
If you quote a part number from the diagram then we know what you are referring to.
mono is offline Find More Posts by mono
Old Dec 03, 2012, 12:34 AM
Rain4LA is offline
Rain4LA's Avatar
Joined Nov 2012
Honestly, this does not go through plastic, it's not a phillips head, and it IS even that small. If you don't consider this small, then I'm assuming that you could probably pilot this helicopter from inside the canopy - due to your freakishly tiny size.
EDIT: When I was saying tail shaft, I was talking obviously about the rotor shaft on the tail, since there's no actual "tail shaft". Sorry if that caused confusion. But back to the issue of this being a very tiny part!
Old Dec 03, 2012, 12:37 AM
thwaitm is offline
Find More Posts by thwaitm
Team WarpSquad
United Kingdom, England, Royal Leamington Spa
Joined Jun 2011
Knowing how big that Tail Rotor is ... that grub/set screw is definitely small... Walkera aren't know for very accurate drawings either... usually it's V1 and since usually it's V1.xx that hits the stores there are some bits missing on the drawings.
Mono is right about it's number... but from the drawing and your pic it suggests allen head... not philips
thwaitm is offline Find More Posts by thwaitm
Old Dec 03, 2012, 12:41 AM
thwaitm is offline
Team WarpSquad
Joined Jun 2011
And Walkera now have
MENTAL GEAR SERVOS ...
http://walkera.com/en1/particular.jsp?pn=Master+CP
Cool...!!
Old Dec 03, 2012, 12:59 AM
Rain4LA is offline
Rain4LA's Avatar
Joined Nov 2012
Cool...!!
This is listed as optional accessories, and they're also listed as "mental" gears....
Old Dec 03, 2012, 01:04 AM
thwaitm is offline
Team WarpSquad
Joined Jun 2011
I wonder what's so mental about them...
Old Dec 03, 2012, 02:17 AM
Rain4LA is offline
Rain4LA's Avatar
Joined Nov 2012
The fact that they're optional...
Old Dec 03, 2012, 02:31 AM
thwaitm is offline
Team WarpSquad
Joined Jun 2011
LOL - good one!
Old Dec 03, 2012, 03:47 AM
Xermalk is offline
Sweden, Helsingborg
Joined Jun 2012
Thats some very decent specifications on those servos. 2.8 kg torqe and 0.08s/60sec speed.
The gears looks like brass though on that picture.
Discussion Blade Mcpx v1 v2 vs Walkera Mini Cp vs Genius Cp vs solo pro 100 3d f.a.r.m.e.r Micro Helis 134 Mar 30, 2016 10:51 AM
Sold Walkera Genius CP with Devo 6 King.7200 Aircraft - Electric - Helis (FS/W) 2 Feb 02, 2012 10:52 AM
Sold Walkera Genius CP Brushless version 3D with 6-axis gyro Devo stretch1100 Aircraft - Electric - Helis (FS/W) 3 Jan 25, 2012 08:37 AM
For Sale Walkera Genius CP with DEVO 6 bymannan Aircraft - Electric - Helis (FS/W) 0 Nov 07, 2011 07:57 AM
New Product Walkera 6-Axis gyro UFO5# (new version with Camera~) DLY Micro Helis 6 Oct 29, 2011 01:48 PM
