Old Nov 30, 2012, 10:46 PM
thwaitm is offline
Find More Posts by thwaitm
Team WarpSquad
United Kingdom, England, Royal Leamington Spa
Joined Jun 2011
Originally Posted by Chow View Post
Whole solution is to understand that you cannot have a heli which is 100% crash resistant
The whole point is to make sure that it's cheap and easily repairable parts (servo horns) that fail in preference to expensive and more difficult parts (servos/servo gears).
thwaitm is offline Find More Posts by thwaitm
Old Dec 01, 2012, 12:13 AM
candy76man is offline
Find More Posts by candy76man
alienfpv, warpquad, goby180
Tampa,FL
Joined Dec 2003
Originally Posted by PirateBlenny View Post
Guys I'm sorry if this is dumb but I'm new to walkera and devo. I got the master cp with 7e and the only way it binds is if I turn the heli on first then the tx. But in the manual it says tx first then helicopter. Am I missing something?
It will bind either way but if you turn on the tx first (which is preferred order) you have to get your heli battery plugged in before the tx stops beeping which is about 8 to10 seconds. After that the tx is no longer in bind mode.
You could also set fixed id on your tx so you can skip that whole binding routine.
candy76man is offline Find More Posts by candy76man
Old Dec 01, 2012, 12:29 AM
zadaw is offline
Find More Posts by zadaw
Hong Kong
Joined Jan 2010
I have over 100 flights and 20 crashes with it and its durability has been amazing. Provided that the servo issue is sorted out, the running cost per crash is as low or lower than the V120D02S. I am still using the same main and tail blades, main and feathering shaft, canopy and skids. The main gear and sometime the tail boom are the only items that are damaged besides the servos. I have seen at least two protective mechanisms.
1. The swashplate sometimes separate in a crash. It is a simple matter to snap it back together.
2. The main pin sometimes shatters in the main gear, thus functioning as a sheer pin.
The vast majority of my crashes were dumb thumb crashes although there were a few due to incorrect maintenance. Otherwise the only failures I have seen was a tail motor that died in mid-air after 42 flights. I also had a head link that flew off suddenly in mid-air. However, it could be that the heli have had a number of crashes and the link had become loose. As far as the dumb-thumb crashes were concerned, there were definitely a few that would not have happened if I could see the canopy and blades clearly. But Walkera knows what exactly they are doing when they brought helicopters with dark canopies and blades.
I do have some issues with how it flies. It is very heavy and behaves like a flying elephant at times. It is not that it flips slowly, it is that I often find it hard to stabliize following a half-flip to an inverted position. Sometimes, I saw some pendulum effect as well. Therefore, the heli seems to be better at full flips than half flips. Flipping to the L or R presented even a bigger problem to me. The heli would pitch forwards as it goes into an inverted position. I found this quite difficult to handle and just had a hard crash because of it. Basically, I think this heli is a great inverted flight trainer as long as you can get it into an inverted position. However, it is great for sports flying for beginners.
zadaw is offline Find More Posts by zadaw
Old Dec 01, 2012, 12:44 AM
pmerritt is online now
Find More Posts by pmerritt
Joined Oct 2010
Two things...please stop saying flip to the side...it's a roll, sometimes you confuse me with that till i realize what you're getting at. Second, you just have to try a brushless setup it makes a huge difference.
pmerritt is online now Find More Posts by pmerritt
Old Dec 01, 2012, 08:44 AM
Tampa,FL
Joined Dec 2003
I agree, totally different bird with a strong brushless motor in it. feels much lighter and more agile when flying it.
Old Dec 01, 2012, 09:24 AM
Xermalk is online now
Find More Posts by Xermalk
Sweden, Helsingborg
Joined Jun 2012
Is it an empy document??
Something went wrong when i posted that from my tablet, https://docs.google.com/document/d/1...zNiVS2f1o/edit is the correct link.
Xermalk is online now Find More Posts by Xermalk
Old Dec 01, 2012, 11:31 AM
zadaw is offline
Hong Kong
Joined Jan 2010
It is just that many prefer to call stationary rolls flips because they are quite different technically. It is the same situation when moving back flips which are technically inside loops. I will make sure there is no confusion in the future.
I can;t get parts for a brushless conversion here. In any case, I will be flying my Trex 250 soon. I just want to use the Master CP in order to get acquainted to the size of a 250 when doing 3D.
Old Dec 01, 2012, 11:45 AM
Rain4LA is offline
Find More Posts by Rain4LA
Rain4LA's Avatar
United States, IL, Chicago
Joined Nov 2012
Does anyone know if there's a trick for getting the feathering shaft out to take the blade grips off? The nuts seem really tight in there - and I feel like I'm going to break them or strip them. Any help would be appreciated.
Rain4LA is offline Find More Posts by Rain4LA
Old Dec 01, 2012, 12:35 PM
Sweden, Helsingborg
Joined Jun 2012
The Master CP document is starting to look good now, we should soon hunt down someone that can send it in to Walkera (I doubt it will reach the master cp engineers if we simply mail it in).
Old Dec 01, 2012, 12:36 PM
vronny is offline
Find More Posts by vronny
los angeles,ca
Joined May 2010
They probably have thread lock on the screws alittle heat from soldering iron will help but be careful sense the blade grips are plastic.
vronny is offline Find More Posts by vronny
Old Dec 01, 2012, 12:49 PM
Tom Z is offline
Find More Posts by Tom Z
RC Reviews & Tx Setup Guides
Tom Z's Avatar
United States
Joined Sep 2007
I can have the document sent to Walkera for you.
Tom
Tom Z is offline Find More Posts by Tom Z
Old Dec 01, 2012, 12:51 PM
Rain4LA is offline
Rain4LA's Avatar
Joined Nov 2012
Yeah, I was afraid of that. Jeez, this thread lock.... Don't really think it's that necessary there...
Thanks for your reply....
Old Dec 01, 2012, 12:55 PM
Joined Oct 2010
oh, nice....i still think i will use my mastercp for awhile since it's flying pretty nice but I'm going to get a better small bird too....a gaui x2. I already started picking up a few of it's suggested upgrades. This is pretty much what i do in winter....upgrade/tweak everything.
Old Dec 01, 2012, 01:11 PM
Rain4LA is offline
Rain4LA's Avatar
Joined Nov 2012
Thanks man, I got it...
Old Dec 01, 2012, 02:31 PM
Tampa,FL
Joined Dec 2003
It's necessary but not the way walkera does it....I think they just dip the whole screw in a vat of loctite when all that's needed is a trace of it on a portion of the threads....I've lost count of how many screws I've had twist in two on walkera rc's because of excessive loctite....and the worst part is there is no easyout small enough for the micro screws on these helis so I end up having to replace the part with the screw broken off inside it more often than not.
Discussion Blade Mcpx v1 v2 vs Walkera Mini Cp vs Genius Cp vs solo pro 100 3d f.a.r.m.e.r Micro Helis 133 Oct 31, 2015 10:04 AM
Sold Walkera Genius CP with Devo 6 King.7200 Aircraft - Electric - Helis (FS/W) 2 Feb 02, 2012 11:52 AM
Sold Walkera Genius CP Brushless version 3D with 6-axis gyro Devo stretch1100 Aircraft - Electric - Helis (FS/W) 3 Jan 25, 2012 09:37 AM
For Sale Walkera Genius CP with DEVO 6 bymannan Aircraft - Electric - Helis (FS/W) 0 Nov 07, 2011 08:57 AM
New Product Walkera 6-Axis gyro UFO5# (new version with Camera~) DLY Micro Helis 6 Oct 29, 2011 02:48 PM
