Old Nov 26, 2012, 03:46 AM
ehirobo is offline
Find More Posts by ehirobo
Hong Kong
Joined Nov 2008
Originally Posted by addifromgermany View Post
For better visibility just put a tail led on your master :-)
nice.
ehirobo is offline Find More Posts by ehirobo
Old Nov 26, 2012, 06:33 AM
pmerritt is online now
Find More Posts by pmerritt
Joined Oct 2010
Originally Posted by Spyro37 View Post
pmerritt's Master CP has very good visibilty as well.
Picture please
it's not all together yet....hold your horses :P been a busy weekend for me (I was the on call guy) even though i mostly ended up monitoring this forum....LOL
pmerritt is online now Find More Posts by pmerritt
Old Nov 26, 2012, 06:41 AM
Xermalk is online now
Find More Posts by Xermalk
Sweden, Helsingborg
Joined Jun 2012
Hrm, wonder how well it would go to light up the master similar to this
Amazing night flight over the pond at Joe Nall pilot Joe Smith (7 min 20 sec)
With some bright leds on thin cf rods.
Xermalk is online now Find More Posts by Xermalk
Old Nov 29, 2012, 03:14 AM
Sweden, Helsingborg
Joined Jun 2012
http://www.rcgroups.com/forums/showp...&postcount=141
Metal servos incoming from walkera.
Old Nov 29, 2012, 08:26 PM
one01 is offline
Find More Posts by one01
Hobbyone
Joined Aug 2011
Yep, Walkera will listen to users suggestion now , the metal gear servo coming soon .
http://www.hobbyone.com.hk/cn/product.jsp?id=11348
one01 is offline Find More Posts by one01
Old Nov 29, 2012, 08:45 PM
thwaitm is offline
Find More Posts by thwaitm
Team WarpSquad
United Kingdom, England, Royal Leamington Spa
Joined Jun 2011
So the next step is then to supply those metal gear servos with servo arms which break on impact instead of damaging the gears. Those little black (ABS?) arms are really tough and transmit all the force back to the servo, Futaba and Savox use a much more brittle plastic which is still stiff and strong under normal loads but under shock loads it will shatter, protecting the servo gears from overloading.
The other alternative is of course to produce the servo output shaft with splines which match the Futaba or Savox horns. There's no point to have a Walkera specific output shaft...
Next, upload the servo specs to servodatabase.com so everyone can make a comparison against them and other servos available. You never know, maybe non heli fliers will buy WK servos as well... assuming the issue of controller boards shorting out is fixed as well (WK-09-8/9).
Metal gears are a step in the right direction but it's not the whole solution.
Keep going with your improvements WK!! Keep up the good work!
thwaitm is offline Find More Posts by thwaitm
Old Nov 29, 2012, 09:36 PM
mono is offline
Find More Posts by mono
mono's Avatar
Joined Aug 2008
... metal gear servo coming soon .
Can we assume this is an analog servo?
One thing I have noticed in my research over the years, the only time I see Walkera say anything is if it's digital. They seem to be rather tight lipped with servo specs, whereas all other manufacturers release information.
mono is offline Find More Posts by mono
Old Nov 30, 2012, 02:24 AM
valestrife is offline
Find More Posts by valestrife
Indonesia, Jakarta Capital Region, Jakarta
Joined Nov 2012
My servos haa arrives from hk today..turnigy metal micro gear servo 9025mg,i just tested the movement of the servos and it went the same as the stock servo no need to rewire agaon..but it not fit..need to do some cuta and mods for the placement..furher information eill added within 3 daya
valestrife is offline Find More Posts by valestrife
Joined Nov 2012
Sory for my bad type ..i use my android to write lol
Old Nov 30, 2012, 02:50 AM
Sweden, Helsingborg
Joined Jun 2012
One01 do you have contacts inside walkera? We would love if this https://docs.google.com/document/d/1...AkfmGzNiVS2f1o document could be forwarded to the engineers behind the master cp.
Its a group collaboration from some users here on rcg. It contains issues, feedback and suggestions we would love to get some comments on.
Old Nov 30, 2012, 05:01 PM
Chow is offline
Find More Posts by Chow
Chow's Avatar
The Netherlands, NH, Nieuw-Vennep
Joined Mar 2011
Is it an empy document??
Chow is offline Find More Posts by Chow
Old Nov 30, 2012, 05:04 PM
Chow is offline
Chow's Avatar
Joined Mar 2011
Whole solution is to understand that you cannot have a heli which is 100% crash resistant
Old Nov 30, 2012, 06:18 PM
BThirsk is offline
Find More Posts by BThirsk
Brent 黑雁
BThirsk's Avatar
Canada, AB, Ponoka
Joined Jan 2012
Try this link. https://docs.google.com/document/d/1...f1o/edit?pli=1
BThirsk is offline Find More Posts by BThirsk
Old Nov 30, 2012, 07:23 PM
Joined Oct 2010
who wants the scale body? the MasterCP is already heavy, only way i'd recommend it for a scale body is if you were to go brushless. I see too many superficial things on that list. The first thing we should be asking for are fixes for the issues it's having.....servos (which it looks like they are addressing), The bobbing when you are flying, the fixed id issues. Things the CAN fix and would make the heli better. I also think that if the blades were a little wider it would get better lift. I have no issues with lift now with my brushless but for stock it surely could use it.
Old Nov 30, 2012, 08:46 PM
PirateBlenny is offline
Find More Posts by PirateBlenny
United States, NY, New York
Joined Mar 2011
Guys I'm sorry if this is dumb but I'm new to walkera and devo. I got the master cp with 7e and the only way it binds is if I turn the heli on first then the tx. But in the manual it says tx first then helicopter. Am I missing something?
PirateBlenny is offline Find More Posts by PirateBlenny
Discussion Blade Mcpx v1 v2 vs Walkera Mini Cp vs Genius Cp vs solo pro 100 3d f.a.r.m.e.r Micro Helis 134 Mar 30, 2016 10:51 AM
Sold Walkera Genius CP with Devo 6 King.7200 Aircraft - Electric - Helis (FS/W) 2 Feb 02, 2012 10:52 AM
Sold Walkera Genius CP Brushless version 3D with 6-axis gyro Devo stretch1100 Aircraft - Electric - Helis (FS/W) 3 Jan 25, 2012 08:37 AM
For Sale Walkera Genius CP with DEVO 6 bymannan Aircraft - Electric - Helis (FS/W) 0 Nov 07, 2011 07:57 AM
New Product Walkera 6-Axis gyro UFO5# (new version with Camera~) DLY Micro Helis 6 Oct 29, 2011 01:48 PM
