Old Nov 19, 2012, 11:32 AM
valestrife is offline
Find More Posts by valestrife
Indonesia, Jakarta Capital Region, Jakarta
Joined Nov 2012
Originally Posted by Razors edge 29 View Post
So as it turns out my devo7E is to blame for signal loss.
I bought my heli today friends Devo 10 and had no signal issues at over 300 feet.
Not sure what is wrong with TX but ill be needing a new one
Which transmitted has better gimbal? Devo 10 or Devo 8?
Despite all of those tx things..have u check ur rx as well? I think devo 7 is enough for everything regarding this master cp..
valestrife is offline Find More Posts by valestrife
Old Nov 19, 2012, 11:35 AM
Joined Nov 2012
Originally Posted by Xermalk View Post
So, i just tested my HK-15178B servos. They center nicely and does not need to be reversed.
However, to fit on the master cp the tabs of two servos needs to be trimmed, as the tabs are wider and thicker then the stock tabs. Thats a 2 min job on each servo with a dremel though (a nail file should work just as well, its only plastic).
Ill fit mine to the frame sometime this weekend, but flight test will have to wait as im short one ball link for the blade grip. And im going to need some serious luck for it to arrive before the weekend.
Glad to see the review..adding some pictures would be perfect because i had my aileron servos stripped and still thinking bout the fits most one..i have bought two types of servo that i posted previously..
Old Nov 19, 2012, 12:03 PM
Spyro37 is offline
Find More Posts by Spyro37
WIFE HAND LAUNCHED MY PLANES!
Spyro37's Avatar
Joined Jun 2009
Originally Posted by pmerritt View Post
try those zippy's i linked....it sounds like that motor is a bit power hungry. I'm getting 6mins out of them at the same capacity. If anyone wants my other batteries i will GIVE them to you but you pay for shipping. It's 3 no brands from oomodels and two turnigy nano's. They all have no more than 5 flights ea.
Yes, I might get some of those.
Pretty cheap plus they are US warehouse, fast & low shipping.
Spyro37 is offline Find More Posts by Spyro37
Old Nov 19, 2012, 12:05 PM
Spyro37 is offline
Spyro37's Avatar
Joined Jun 2009
That's really good to know...
Thanks.
Old Nov 19, 2012, 12:29 PM
Xermalk is offline
Find More Posts by Xermalk
Sweden, Helsingborg
Joined Jun 2012
Ill add pictures once i start fitting the servos, right now its pitch black outside and i lack a good desklamp on my workbench (its on the to buy-list).
I did just notice however that the servos are a fraction of a mm thicker, but thats easily fixed with a nail file, either by filing the servo, or the plastic bracket that holds the servo in place.
Edit: I wouldn't recommend these servos to those looking for drop in replacements, your going to have to do some modification to the frame to get them to fit. Its a fraction of a millimeter, but on a couple of locations so its some work to get them to fit in the frame. Specifically the rear 2 servos as those are slightly too long and high, so you have to sand down some of the rear support and the bracket to get them to fit.
0.2mm or so that needs to be modified in a couple of places, and tabs needs to be reduced by ~2-3 mm. Completely doable but will take some time to get it done perfectly. New time estimate is 1-2h and don't use a dremel unless you don't care for precision.
Xermalk is offline Find More Posts by Xermalk
Old Nov 19, 2012, 01:09 PM
pmerritt is offline
Find More Posts by pmerritt
Joined Oct 2010
the bracket will be the easier of the two.
pmerritt is offline Find More Posts by pmerritt
Old Nov 19, 2012, 07:22 PM
Spyro37 is offline
Spyro37's Avatar
Joined Jun 2009
That's what I thought, it takes more than 2 min to do mods, just because the there is not really much room in there.
Also, another thing to watch is the ball link on the servo arm does not bind with the elevator servo.
Otherwise the extra effort might be worthwhile for others.
- Spyro
Old Nov 19, 2012, 07:31 PM
Razors edge 29 is offline
Find More Posts by Razors edge 29
QuAd FaNaTiC
Razors edge 29's Avatar
Canada
Joined Aug 2009
Radio is going back to Walkera
So
Which TX Is better.?
8 or 10?
Razors edge 29 is offline Find More Posts by Razors edge 29
Old Nov 19, 2012, 09:26 PM
Spyro37 is offline
Spyro37's Avatar
Joined Jun 2009
So
8 or 10?
8S is really nice & worth the money.
devo Hack is now available & o the works for more options and compatibility.
Stock FW works me as is.
Old Nov 19, 2012, 09:46 PM
QuAd FaNaTiC
Canada
Joined Aug 2009
thanks
Old Nov 19, 2012, 10:17 PM
pmerritt is offline
Joined Oct 2010
i agree, the 8 is probably the nicer of the two but for the money you still can't go wrong with the Devo10....it really comes down to how much you want to spend and if you feel the touchscreen is worth the premium. Deviation software is coming to Devo10 also so that point is kind of moot.
Old Nov 19, 2012, 11:15 PM
zadaw is online now
Find More Posts by zadaw
Hong Kong
Joined Jan 2010
Deviation software is already working in Devo 10 although it is an Alpha version. I found the screen of the Devo 8S very difficult to read in sunlight. In the end, I went for the Devo 12S. But you have had the Devo 6 before and the screen is basically the same as the Devo 8S.
Deviation Of DEVO10 Playing With Blades NANO CPX (6 min 9 sec)
zadaw is online now Find More Posts by zadaw
Old Nov 20, 2012, 02:36 AM
Xermalk is offline
Sweden, Helsingborg
Joined Jun 2012
- Spyro
Will fit the servos later today, but from what i saw yesterday the arm/ ball link should end up very close to the same position as the stock servos.
Old Nov 20, 2012, 04:47 AM
BThirsk is offline
Find More Posts by BThirsk
Brent 黑雁
BThirsk's Avatar
Canada, AB, Ponoka
Joined Jan 2012
So
8 or 10?
So, did you get any response from Walkera. I never did on my Devo 8s screen issue. I even sent photos.
BThirsk is offline Find More Posts by BThirsk
Old Nov 20, 2012, 08:30 AM
BHChieftain is offline
Find More Posts by BHChieftain
Joined Apr 2010
So
8 or 10?
I have the 8 (not 8S) and am pretty impressed with it. Ergonomics and balance are spot on. Gimbals are on bearings and are silky smooth. Interface is great, but the only downside is the color screen is very hard to read outside.
I have not seen the 10 so I can't compare it...
Chief
BHChieftain is offline Find More Posts by BHChieftain
Discussion Blade Mcpx v1 v2 vs Walkera Mini Cp vs Genius Cp vs solo pro 100 3d f.a.r.m.e.r Micro Helis 134 Mar 30, 2016 10:51 AM
Sold Walkera Genius CP with Devo 6 King.7200 Aircraft - Electric - Helis (FS/W) 2 Feb 02, 2012 10:52 AM
Sold Walkera Genius CP Brushless version 3D with 6-axis gyro Devo stretch1100 Aircraft - Electric - Helis (FS/W) 3 Jan 25, 2012 08:37 AM
For Sale Walkera Genius CP with DEVO 6 bymannan Aircraft - Electric - Helis (FS/W) 0 Nov 07, 2011 07:57 AM
New Product Walkera 6-Axis gyro UFO5# (new version with Camera~) DLY Micro Helis 6 Oct 29, 2011 01:48 PM
