Old Nov 13, 2012, 12:48 PM
Xermalk is offline
Find More Posts by Xermalk
Sweden, Helsingborg
Joined Jun 2012
Originally Posted by Spyro37 View Post
Yes keep us posted how it works (?) and issues installing them (?).
This thing has got pretty tight space for servo mods.
1mm size difference could take so much time off from you.
Well, the only dimension I'm slightly worried about is the servo height, for all other dimensions there's room for a mm or two extra space.
Xermalk is offline Find More Posts by Xermalk
Old Nov 13, 2012, 05:20 PM
BThirsk is offline
Find More Posts by BThirsk
Brent 黑雁
BThirsk's Avatar
Canada, AB, Ponoka
Joined Jan 2012
Anyone knows the the tail's motor KV?
No, but if your thinking brushless, I am sure a 1500kv using the stock blade would be enough. I just did a large fixed pitch using a 200okv on 7.4 volts and the tail holds very well and I had to tune it down some.
I had a 1500kv I got as an alternate for that that I will try on this when I kill the stock tail motor.
BThirsk is offline Find More Posts by BThirsk
Old Nov 13, 2012, 07:35 PM
PonyBoy1973 is offline
Find More Posts by PonyBoy1973
Joined Mar 2011
Originally Posted by pmerritt View Post
http://helircstore.com/shop/helicopt...a,master%20cp,
Unfortunately, out of stock at the moment.....the MasterCP is a pretty popular heli right now. It's like an unsung hero in Walkera's hanger. I'm not going to say it's better than the more expensive heli's in this size but for what a beginner/intermediate needs...it does just fine.
Thanks for the replies all, I might have to buy, buy, buy!!!
PonyBoy1973 is offline Find More Posts by PonyBoy1973
Old Nov 14, 2012, 12:20 AM
Spyro37 is offline
Find More Posts by Spyro37
WIFE HAND LAUNCHED MY PLANES!
Spyro37's Avatar
Joined Jun 2009
Originally Posted by BThirsk View Post
No, but if your thinking brushless, I am sure a 1500kv using the stock blade would be enough. I just did a large fixed pitch using a 200kv on 7.4 volts and the tail holds very well and I had to tune it down some.
Are those motors you mentioned brushed as well?
My Bird Looks Angry
I have a hard time with orientation when my heli is flying high & on gloomy wethear.
The red & yellow covering now looks so much better in the air.
The White Skids is also very visible during flights.
Spyro37 is offline Find More Posts by Spyro37
Old Nov 14, 2012, 03:27 PM
BThirsk is offline
Brent 黑雁
BThirsk's Avatar
Canada, AB, Ponoka
Joined Jan 2012
The fixed pitch was brushed on both mail and tail motors originally. It now has an EH200 4100kv brushless main running 11.1V and a 2000kv 7.4v tail with a HK401B Gyro. I will probably change the gyro to a GY250 later, but this one works pretty well. I still need a lot of fine tuning because I also changed the flybar from weight to paddles and it is now more responsive than my 450. Almost too much to handle. I have some pictutes on my blog. It really was almost a waste of time, but it was a fun project and something I can fly at 200 feet high.
Old Nov 14, 2012, 04:32 PM
Spyro37 is offline
Spyro37's Avatar
Joined Jun 2009
So 1500KV 3S BL motor should work (?).
I have to find (or I may have one?) a 3S BL motor for the tail.
As you probably know (?), BL motor should only be used with voltage max voltage as specified by manufacturer. They could burn even if no throttle is applied or not running if higher voltage is applied across the wires. I have smoked an expensive HET motor on the bench after plugging a 4S lipo on a 3S HET motor.
For now, I'll keep the tail stock, but I may convert it to BL eventually.
Hope it doesn't crap out on me midflight though.
- Spyro
Old Nov 14, 2012, 06:04 PM
Razors edge 29 is offline
Find More Posts by Razors edge 29
QuAd FaNaTiC
Razors edge 29's Avatar
Canada
Joined Aug 2009
Awesome Spyro37
Awesome
I just downloaded Angry Birds Star Wars - its pretty good
My Bird Looks Angry
Razors edge 29 is offline Find More Posts by Razors edge 29
Old Nov 14, 2012, 06:48 PM
BThirsk is offline
Brent 黑雁
BThirsk's Avatar
Canada, AB, Ponoka
Joined Jan 2012
- Spyro
I think this one would work. http://www.hobbyking.com/hobbyking/s...or_1500kv.html
Old Nov 14, 2012, 06:49 PM
BThirsk is offline
Brent 黑雁
BThirsk's Avatar
Canada, AB, Ponoka
Joined Jan 2012
Originally Posted by Razors edge 29 View Post
I emailed Walkera
Waiting for there response
You get any response yet?
Old Nov 14, 2012, 07:25 PM
Spyro37 is offline
Spyro37's Avatar
Joined Jun 2009
(Oops double)
Old Nov 14, 2012, 07:29 PM
Spyro37 is offline
Spyro37's Avatar
Joined Jun 2009
I have the same motor in my spare box from HK So I'll check it out such as shaft size and mounting to use it as a trial motor.
It would be nice to find an inrunner if I'd pursue with the project.
I could probably try it out and see how it works.
Awesome Spyro37
I treid flying it today, It is so much easier to see and it's attitude is easy to tell.
Thanks.
Old Nov 14, 2012, 08:08 PM
pmerritt is online now
Find More Posts by pmerritt
Joined Oct 2010
My Bird Looks Angry
i love it!!! you wanna make a few dollars?....LOL
pmerritt is online now Find More Posts by pmerritt
Old Nov 14, 2012, 10:04 PM
QuAd FaNaTiC
Canada
Joined Aug 2009
Nope - have you?
They likely dont care because we're Canadian
Old Nov 15, 2012, 12:01 AM
Spyro37 is offline
Spyro37's Avatar
Joined Jun 2009
I got a few more remnants left, good for one more canopy.
And the paint can is still full.
If you wanna send it to me, with the $ to ship it back to you, I'll do it.
I also vinyled the horizontal stab, looks great too.
I don;t mind...
You could PM me...
I'm in California.
Old Nov 15, 2012, 02:11 AM
jonnewbie is offline
Find More Posts by jonnewbie
Joined Nov 2012
Feed back from some experienced flyers please....
Looking at getting a Master CP after flying a FP 9116 for a couple months. However before I do this I am buying a SIM.
Question is what DEVO transmitter should I get that is newbie friendly (DEVO 7E had had sum good reviews )?..... and will work on a flight SIM? .....I have looked at the Phoenix 4 SIM but doesn't look like the DEVO works on there?
Please inform me haha.....
jonnewbie is offline Find More Posts by jonnewbie
Discussion Blade Mcpx v1 v2 vs Walkera Mini Cp vs Genius Cp vs solo pro 100 3d f.a.r.m.e.r Micro Helis 134 Mar 30, 2016 10:51 AM
Sold Walkera Genius CP with Devo 6 King.7200 Aircraft - Electric - Helis (FS/W) 2 Feb 02, 2012 10:52 AM
Sold Walkera Genius CP Brushless version 3D with 6-axis gyro Devo stretch1100 Aircraft - Electric - Helis (FS/W) 3 Jan 25, 2012 08:37 AM
For Sale Walkera Genius CP with DEVO 6 bymannan Aircraft - Electric - Helis (FS/W) 0 Nov 07, 2011 07:57 AM
New Product Walkera 6-Axis gyro UFO5# (new version with Camera~) DLY Micro Helis 6 Oct 29, 2011 01:48 PM
