Joined Aug 2008
Spyro37
sounds like a good plan ,,, the only thing you need to watch is connector 7 on the Rx, the Power Check from the brushed esc, which you are removing completely. If you use an esc that does not have that (only seen it on some Walkera esc's) then you will need to do the 1k resistor in the 3 pin connector trick to get around it. Details of that in the v400d02 thread in electric heli talk forum. |
Joined Oct 2010
- I converted my HoneyBeeKing V2 from brush to brushless, and all I had to do is use my own BL motor & BL ESC. No converter needed. Just plug the ESC to the receiver (throttle terminal). - Since the Master CP has a separate receiver with throttle terminal, you could plug either brush ESC or BL ESC. Receivers does not care whether you use a brush or BL ESC. I have not received my Master CP yet, & it takes a while from HK to USA. I have not seen the actual electronics of it yet. I'm just going by the pictures of it on the web. - Spyro |
Joined Aug 2008
If you connect a converter straight to the rx throttle port then you are missing the signal output of the rx (white wire for main) which is the throttle signal that you actually need, whether it's running brushed or brushless esc. Here's a simple analogy on my view about the converter.... You have a glass of nice clean water for drinking, a handful of dirt is thrown into it so it's not usable. To fix that, it is then put through a filter so it can be used again. Hope that makes sense. I only brought this subject up so that parts are not bought when they are not actually needed and the conversion is straight forward for those that want to go brushless. |
The OC, California
Joined Feb 2007
Joined Oct 2010
That's exactly why i purchased this converter, i figured much of what walkera is using is the same old stuff they always have been using. The MasterCP is like a blend of MiniCP and the V400D02. Servos, motor, and even though it's rebadged I bet the esc is exactly the same. Therefore i purchased this, and it should fix the throttle issue.
Signal Converter |
Joined Aug 2008
ok, that one is different to the ususl converters, it has the signal connection.
have not seen it before, but the rchobbygear name I have seen mentioned in the v400 thread. In that case it will certainly do the job. ![]() I still think a walkera esc from a similar model like the v200d03 will work without the conversion in the middle. Perhaps I will get the parts for a bench test experiment. I tend to get more from that aspect of the hobby than flying them. Am also interested in what mods dkfuji does with his. |
Hopefully, Walkera did not design the Master CP's Rx unique that a "direct" conversion is not possible. |
This thread needs more vids and flight reviews
Latest blog entry: Estes Rubber Band Condor gets powered...
The OC, California
Joined Feb 2007
Okay, so I did the conversion again and this time I decided to drop the little Devo 7E Tx and use my Devo 10 and it works much better with this combination. The throttle still doesn't start to kick in until about 35%. But, that's acceptable since I do all of my flying in stunt mode anyway. However, it will fly just fine in Nor mode using a linear throttle curve. I think with a little more adjusting of the curve, I can get it to perform pretty much like it was brushed. All I can say is this heli is a rocket with a B/L motor in it and the tail still holds solid. IMO, if you are thinking of using a motor with less than 4200kv, you will have to locate a bigger pinion gear to get the headspeed needed for some 3D. I am using a 4200kv motor with the stock pinion. At 90% throttle performance was a little better than stock while at 100% the heli really wakes up.
| Thread Tools | |
| Discussion Blade Mcpx v1 v2 vs Walkera Mini Cp vs Genius Cp vs solo pro 100 3d | f.a.r.m.e.r | Micro Helis | 99 | Jul 04, 2012 09:09 PM |
| Sold Walkera Genius CP with Devo 6 | King.7200 | Aircraft - Electric - Helis (FS/W) | 2 | Feb 02, 2012 10:52 AM |
| Sold Walkera Genius CP Brushless version 3D with 6-axis gyro Devo | stretch1100 | Aircraft - Electric - Helis (FS/W) | 3 | Jan 25, 2012 08:37 AM |
| For Sale Walkera Genius CP with DEVO 6 | bymannan | Aircraft - Electric - Helis (FS/W) | 0 | Nov 07, 2011 07:57 AM |
| New Product Walkera 6-Axis gyro UFO5# (new version with Camera~) | DLY | Micro Helis | 6 | Oct 29, 2011 01:48 PM |
