Old Feb 03, 2013, 08:11 AM
BThirsk is offline
Find More Posts by BThirsk
Brent 黑雁
BThirsk's Avatar
Canada, AB, Ponoka
Joined Jan 2012
Originally Posted by Xermalk View Post
Hrm, is there a metal swash upgrade for the master?
Id love to get rid of the slop i have in mine, its producing some wierd behavior when i fly with Alzrc blades because of the faster blade response (it does small twitches in the air, whenever the load direction on the swash is changed).
With the stock blades its nowhere near because of the heavier blades and slower response, but its still present.
Then again i might just go for a proper 450 kit for the summer instead, would need a new tx for that though :<.
Did you adjust gyro gain pot after installing the new blades. Lighter blades may require more gain.
BThirsk is offline Find More Posts by BThirsk
Old Feb 03, 2013, 09:53 AM
gapi is offline
Find More Posts by gapi
gapi's Avatar
North Georgia
Joined Oct 2010
Fixed ID is not working for me ever since I installed my 5055s
The fixed ID thing for the 5055's & Master CP may be able to be overcame.
Does the Aileron port on the Master CP RX double for a fixed ID clearing port?
The V400D02 Heli with a 5055 connected to the Aileron port would not bind "period". We had to remove it, bind, reinstall and fly. Every time the TX was powered down or the battery disconnected.
I tested the 5055's in a Master CP for binding and it was OK but did not test for the fixed ID function.
What we found was the 5055 is unique to a few other mfg servos tested in having 2.15v on the signal wire when connected to the powered up RX2614v-D.
The other tested servos had 0.0v
We disconnected the signal wire from the plug and plugged in the servo then measured for voltage across the (-) & disconnected signal wire. 2.15v was found.
We believe the RX was thinking its time to clear the Fixed ID, not time to bind.
We found bridging a 4.7khom resistor from the (-) to Signal terminal did the trick with no ill effects.
See my Blog for pics of our fix.
I cut the ends of the resistor at an angle in an attempt to make a pointed end.
I opened up the area between the plug's wall and the signal & (-) wire's terminals with a long and narrow very sharp pointed needle, and with needle nose pliers pushed the resistor pin in the void before it closed back up. Hot melt glue is now in there but it was pretty tight anyways.
gapi is offline Find More Posts by gapi
Old Feb 03, 2013, 10:15 AM
FlyingPhilUK is offline
Find More Posts by FlyingPhilUK
I built a new
FlyingPhilUK's Avatar
United Kingdom, Scotland, Edinburgh
Joined Jan 2013
Originally Posted by BThirsk View Post
The TX gyro setting is only used to set the tail gyro function as well as turning off the ELV/AIL gyro when at 50% or lower.
I haven't seen this bit of information before
- where did you see it?
Does it completely turn off the ELV/AIL gyro, or just mean it does to 3-axis mode, not 6-axis mode?
- What is the Tail gyro doing at this point?
Thanks!
FlyingPhilUK is offline Find More Posts by FlyingPhilUK
Old Feb 03, 2013, 10:26 AM
gapi is offline
gapi's Avatar
North Georgia
Joined Oct 2010
Thanks!
I recently purchased the 5055's before I knew about the V400D02 binding issue.
So I went after the issue tooth and nail and got help from a kind member of Deviation forums.
It has no other effect but to blind the RX from the 2.1v on the signal wire at startup. The Aileron works fine. It does not turn off the ELV/AIL.
Xermalk is offline
Find More Posts by Xermalk
Sweden, Helsingborg
Joined Jun 2012
Thanks!
Below 50% in the tx gyro setting will completely disable all gyros on the heli. This goes for all walkera helicopters.
It's for when one is setting up the helicopters on the workbench.
Xermalk is offline Find More Posts by Xermalk
Old Feb 03, 2013, 04:13 PM
BThirsk is offline
Brent 黑雁
BThirsk's Avatar
Canada, AB, Ponoka
Joined Jan 2012
Thanks!
Page 9 of the manual. As Xermalk stated, pretty much all walkeras as set up this way. I think the V120D02S and the V400D02 are the only ones with a dip switch to turn off the gyro. Everything lately does it by the gain setting.
Old Feb 03, 2013, 05:12 PM
Rollmops67 is offline
Find More Posts by Rollmops67
Eternal beginner
Rollmops67's Avatar
France, Alsace, Strasbourg
Joined Jun 2012
V450D03 has also a WK<>ADJ switch
Roland
Rollmops67 is offline Find More Posts by Rollmops67
Old Feb 03, 2013, 05:28 PM
Xermalk is offline
Sweden, Helsingborg
Joined Jun 2012
From how it acts its most likely less gyro gain, as it looks like its the slop thats causing the helicopter to act strangely. It twitches/wobbles in the air.
And its not from vibrations, as the light blades actually seem to have less vibes then my night blades and those fly just fine.
Ill see if i can get a video of it the next time the weather allows for some air time. With some luck the weather should be decent enough on tuesday. Right now its subzero and 15 m/s, with rain later.
Old Feb 03, 2013, 05:38 PM
chuank is offline
Find More Posts by chuank
Joined Nov 2012
twitching, spasming servos
The TX gyro setting is only used to set the tail gyro function as well as turning off the ELV/AIL gyro when at 50% or lower. The pot on the RX is where you set servo gain. Try adjusting that.
@BThirsk, thanks for this info and also the rest who added on about the Tx gyro setting.
I've tried adjusting the servo gains on my Rx to see if the servo twitching will stop, but that didn't work. All 3 pots on the Rx were adjusted both ways, but again, as I tilt and level my Master CP by hand with the throttle stick at mid, I still get that same spasm the gyro sort of tells the servos to center up, but they twitch their way back to neutral. It's basically unflyable right now, as you might expect a twitching helicopter would (or wouldn't).
What's curious is this twitching takes time, about 3-4 seconds of twitching before it sort of reaches it's intended point, instead of the half sec it would probably take normally for the swashplate to center. Adding cyclic makes the twitching even more pronounced, seeing that the servo horns have more 'distance' to travel.
All 3 servos are twitching, not just 1 or 2. I plugged them into my Hitec HFP-21 for a test, and they all still behaved normally.
I'm just guessing that the gyro in my Rx is toast, or something else in the Rx is gone. Either way it looks like I have to get a replacement...
@gapi, pretty interesting mod you have, I will have to try that out after I get these spasms out of my heli.
chuank is offline Find More Posts by chuank
Old Feb 03, 2013, 06:32 PM
oldsneakers is offline
Find More Posts by oldsneakers
oldsneakers's Avatar
United States, CT, Hamden
Joined Jul 2011
chuank, my mcp twitches just as you describe it. 2 of the three servos. And the servos twitch their way back to center on the bench. It didn't do it new, only after a few cashes and servo replacements. I've flown it like that and it did ok. No inverts, just sport flying.
oldsneakers is offline Find More Posts by oldsneakers
Old Feb 03, 2013, 08:07 PM
Wasp09 is offline
Find More Posts by Wasp09
Canada, ON, Ottawa
Joined Jun 2009
I can't confirm what the differences are, but I am positive they are not the same.
I have signal converters for both helis and they are different and the difference is the throttle output signal. Several tried the converter from the V400 on the master and had throttle range issues.
The issue is still under investigation. I have 2 V400D02s, I put the master CP Rx on one, it obviously has a lot less head speed than the other with the original RX. So far I had put new main gear, swapped the main motors and the ESCs.. The one with the master CP RX still has less head speed. It is either the RX or the head left in the equation.
I could not swap the entire frame easily as the 2 RXs require servos turning in opposit directions, but I did not notice anything wrong with the head. When I took the motors off, both heads free rotated for a long long time when I spinned the main rotors by hand. They came to stop about the same time.
It looks like it is the RX itself making the difference. It make sense if you found that you require 2 different signalling converters.
My next step would be putting a scope on the throttle channel to see what is going on..
Strange. I could not believe Walkera actually does that.
Thanks.
Wasp09 is offline Find More Posts by Wasp09
Old Feb 03, 2013, 09:17 PM
gapi is offline
gapi's Avatar
North Georgia
Joined Oct 2010
Curious, I have heard the Master CP RX on the V400 is a drop in without the head speed issue. And the added Gyro Axis's makes it more stable.
I'll check my source and have them confirm and get back.
Did you try the swap in fresh models in your TX?
Old Feb 03, 2013, 09:54 PM
BThirsk is offline
Brent 黑雁
BThirsk's Avatar
Canada, AB, Ponoka
Joined Jan 2012
Thanks.
Yes, it appears they do. One of the guys who has a MiniCP and a SuperCP has issues with the same brushless comversion that works on the mini but not on the super due to signal pulses on the super. He's still testing so there is no concrete conclusion yet.
Old Feb 03, 2013, 10:10 PM
Wasp09 is offline
Canada, ON, Ottawa
Joined Jun 2009
Gapi,
On the scope the throttle output on the master CP RX is 2ms cycle time. While on my original V400D02 RX (2614V non-devo) is 1ms. Apparently my ESC's do not handle the difference well.
I may open one of them up to check why it does not like the longer cycle time. I always thought it was dumb MOSFETs inside, perhaps not.
Or could it be current sourcing on the new RX output is weaker and not cycle time making the differene?
My V400D02's are the earliest version. If yours works, perhaps Walkera ships a different ESC that can work with both now. Or if you have good batteries, you may use a very high pitch to compensate for the lack of head speed. However my batteries are simply too weak to sustain that torque.
BTW, the gyro correction on the RX is wrong since the servo layout has changed. TX configuration could not change that I suppose. It is not a drop in. It may work moving the front servo to the other side and turn the RX 180 degree. I thought I had to mod only one servo but ended up mod'ing all three without moving the servos. There is no pitch reversal switch on the master CP RX.
The master CP RX would allow me to use my Devo TX otherwise I could only use my 2603TX. It has not quite worked out yet.
Old Feb 04, 2013, 02:03 AM
thwaitm is offline
Find More Posts by thwaitm
Team WarpSquad
United Kingdom, England, Royal Leamington Spa
Joined Jun 2011
Originally Posted by chuank View Post
.... twitching and servo spasms....
Have you tried a big fat separate BEC on there instead of the built in one? It might be an overloading issue? servo links are tight?
thwaitm is offline Find More Posts by thwaitm
Discussion Blade Mcpx v1 v2 vs Walkera Mini Cp vs Genius Cp vs solo pro 100 3d f.a.r.m.e.r Micro Helis 134 Mar 30, 2016 10:51 AM
Sold Walkera Genius CP with Devo 6 King.7200 Aircraft - Electric - Helis (FS/W) 2 Feb 02, 2012 10:52 AM
Sold Walkera Genius CP Brushless version 3D with 6-axis gyro Devo stretch1100 Aircraft - Electric - Helis (FS/W) 3 Jan 25, 2012 08:37 AM
For Sale Walkera Genius CP with DEVO 6 bymannan Aircraft - Electric - Helis (FS/W) 0 Nov 07, 2011 07:57 AM
New Product Walkera 6-Axis gyro UFO5# (new version with Camera~) DLY Micro Helis 6 Oct 29, 2011 01:48 PM
