Old Jan 31, 2013, 09:08 AM
54885488 is offline
Find More Posts by 54885488
Joined Jan 2012
Originally Posted by BThirsk View Post
I don't think the setting you see are intentional by Walkera to destroy your helis.
When you set up a new model, the pitch curves default to -100% at L and +100% at high. This is normal practice. On most heli builds, that is pretty close to where you want them and you limit pitch by travel. In these RTF helis they build, there is far more pitch capability the you need and 100% will likely cause bind. They have supplied pitch curves that beginners should use, usually between 50 and 60%.
In the case of the throttle hold, it is disabled when you get you heli and or TX. When you enable it, the default is the 100% you see. It is up the the user too set it up properly. it's just a case of learning the transmitter setup procedures and the heli requirements.
Yea i agree with you . The first thing i do with a new heli is drop pitch travel down to 30 percent and set all pitch curves linear -100 to +100 . Next make sure i have 0 pitch at center stick . next raise pitch travel untill i have the max pitch i want at low and high stick which is 12 or 13 on the master . Set 8-10 deg cylic . Last set throtle hold to 0 deg pitch .
54885488 is offline Find More Posts by 54885488
Old Jan 31, 2013, 12:14 PM
ITS ME DAVID is offline
Find More Posts by ITS ME DAVID
ITS ME DAVID's Avatar
Joined Apr 2011
Will getting the master cp with devo 7e for $199 worth it or just get it with the devo 10 for $249?
ITS ME DAVID is offline Find More Posts by ITS ME DAVID
Old Jan 31, 2013, 12:40 PM
zadaw is offline
Find More Posts by zadaw
Hong Kong
Joined Jan 2010
I would definitely go for the 10 as you need all the range you can get as a beginner. When you start doing FFF, you will find that the heli gets away from you very quickly. The Devo 7e is suitable for small field flying only and is of a lower quality build. You can use the Devo 10 to fly larger helis from other brands later on if you want.
zadaw is offline Find More Posts by zadaw
Old Jan 31, 2013, 01:04 PM
Joined Apr 2011
Thanks @zadaw
Old Jan 31, 2013, 01:08 PM
Joined Apr 2011
Anyone see this review
http://www.rcgroups.com/forums/showthread.php?t=1740906
Old Jan 31, 2013, 03:48 PM
oldsneakers is online now
Find More Posts by oldsneakers
oldsneakers's Avatar
United States, CT, Hamden
Joined Jul 2011
I see a number of guys here put lipo battery alarms on their MCP. That what I use on my V200D02. Other than the extra drain on the battery, are there any other negatives to using the telemetry to monitor the flight battery? I can live with a little less flight time if the thing works really well.
oldsneakers is online now Find More Posts by oldsneakers
Old Feb 01, 2013, 04:24 AM
Xermalk is online now
Find More Posts by Xermalk
Sweden, Helsingborg
Joined Jun 2012
How much cyclic and collective pitch is recommended for acrobatics/3d?
Edit: im running 12 degrees of collective, and 7 degrees of cyclic. Using http://www.helifreak.com/attachment....6&d=1291570047, blade length of 205mm and a ruler to measure.
Xermalk is online now Find More Posts by Xermalk
Old Feb 01, 2013, 04:27 AM
jonnewbie is offline
Find More Posts by jonnewbie
Joined Nov 2012
Hey all
I have a Mini CP and enjoy it alot.....when its a little windy I cant fly. I am looking at also getting Master CP to help me learn more.
Is it worth getting a Master CP or should I get the TREX 450 DFC rtf package?
Many thanks for your thoughts.
jonnewbie is offline Find More Posts by jonnewbie
Old Feb 01, 2013, 05:30 AM
addifromgermany is offline
Find More Posts by addifromgermany
Joined Sep 2012
Originally Posted by jonnewbie View Post
Hey all
Try the Master, itīs pretty cheap and durable after you changed the servos after the first crash.
addifromgermany is offline Find More Posts by addifromgermany
Old Feb 01, 2013, 05:40 AM
BThirsk is offline
Find More Posts by BThirsk
Brent 黑雁
BThirsk's Avatar
Canada, AB, Ponoka
Joined Jan 2012
Hey all
As previous post, I would also suggest the MasterCP. The 450DFC is a different bird to fly. It's hard to tame down a DFC head due to it's design. It needs lots of head speed which relates to very fast response and if your not up to it, you will crash a lot.
BThirsk is offline Find More Posts by BThirsk
Old Feb 01, 2013, 07:25 AM
Sweden, Helsingborg
Joined Jun 2012
Hey all
What tx are you using? As long as its not a 7E id recommend going for a master cp, and then when you get the feel for it consider a 450 or 500.
If your flying with a 7E you might as well go grab a rtf trex kit. Or swap out that 7E for a devo 10 or 7.
Old Feb 01, 2013, 08:07 AM
Sweden, Helsingborg
Joined Jun 2012
Just did a range test of my Master cp + devo 7E. Range is 80m +-4 direct line of sight & no canopy. Measured using my phones gps.
Seems its time to look into a tx or atleast a radio module upgrade.
Old Feb 01, 2013, 08:31 AM
54885488 is offline
Joined Jan 2012
12 is good on collective and i'm at 8 deg on cylic . The few flybarless units that i have had recommend 8 or 10 deg . If this gives you to much conrtol either use dual rates or expo to tame it down .
Old Feb 01, 2013, 09:33 AM
Joined Nov 2012
http://www.rcgroups.com/forums/showthread.php?t=1325037
Awesome page with all different setups!
Old Feb 01, 2013, 09:33 PM
gapi is offline
Find More Posts by gapi
gapi's Avatar
North Georgia
Joined Oct 2010
What do you guys see as far as the future for factory and vendor support of the Master CP?
Some sites don't carry it and some do not carry parts. Not the majority but still it seems if a heli is not on the list it is more often the Master CP.
gapi is offline Find More Posts by gapi
Discussion Blade Mcpx v1 v2 vs Walkera Mini Cp vs Genius Cp vs solo pro 100 3d f.a.r.m.e.r Micro Helis 134 Mar 30, 2016 10:51 AM
Sold Walkera Genius CP with Devo 6 King.7200 Aircraft - Electric - Helis (FS/W) 2 Feb 02, 2012 10:52 AM
Sold Walkera Genius CP Brushless version 3D with 6-axis gyro Devo stretch1100 Aircraft - Electric - Helis (FS/W) 3 Jan 25, 2012 08:37 AM
For Sale Walkera Genius CP with DEVO 6 bymannan Aircraft - Electric - Helis (FS/W) 0 Nov 07, 2011 07:57 AM
New Product Walkera 6-Axis gyro UFO5# (new version with Camera~) DLY Micro Helis 6 Oct 29, 2011 01:48 PM
