Old Jan 26, 2013, 04:13 AM
addifromgermany is offline
Find More Posts by addifromgermany
Joined Sep 2012
Originally Posted by Xermalk View Post
I can get the 11-13T pinions locally, though 14t + 4200 kv? .
14t and 4200kv will be extreme. Even 13t is really more than enough headspeed.
addifromgermany is offline Find More Posts by addifromgermany
Old Jan 26, 2013, 06:46 AM
weladhalah is offline
Find More Posts by weladhalah
Joined Jan 2013
i have question,
what the Master CP can supports with J6 from Nine Eagle transmiter and NASA 701 transmiter from Skyartec?
thanks,
weladhalah is offline Find More Posts by weladhalah
Old Jan 26, 2013, 08:45 AM
Xermalk is offline
Find More Posts by Xermalk
Sweden, Helsingborg
Joined Jun 2012
Originally Posted by weladhalah View Post
i have question,
thanks,
Master Cp has a all in one reciever/gyro so you cannot use your own. Master Cp will only work with Devo Transmitters.
Xermalk is offline Find More Posts by Xermalk
Old Jan 26, 2013, 09:40 AM
54885488 is offline
Find More Posts by 54885488
Joined Jan 2012
Only tail gyro, not elev/alie.
I did not know that either , but it makes since . I am currently messing with a brushless tail set up were gyro gain has to be low to prevent tail wag . I was worried that such a low gain would effect the cylic holding ability . Thanks for the piece of information .
54885488 is offline Find More Posts by 54885488
Old Jan 26, 2013, 06:49 PM
BThirsk is offline
Find More Posts by BThirsk
Brent 黑雁
BThirsk's Avatar
Canada, AB, Ponoka
Joined Jan 2012
Man, i really wish walkera would go away from gyro pots and move the gyro settings to a extra channel in the tx. Would be awesome to tweak gyro settings midflight.
+1 on that. I am awaiting stock on an MHS gyro for a 500 build. From what I have read, it does that. Skukum as well. Most you need to program with a PC and cannot make changes in the TX. But it would be nice.
BThirsk is offline Find More Posts by BThirsk
Old Jan 26, 2013, 07:07 PM
gapi is offline
Find More Posts by gapi
gapi's Avatar
North Georgia
Joined Oct 2010
Is there an exploded view diagram for the Master CP?
gapi is offline Find More Posts by gapi
Old Jan 26, 2013, 07:35 PM
Xermalk is offline
Sweden, Helsingborg
Joined Jun 2012
Now, if only walkera would release a fix for the throttle hold issue, it would be so simple for them to even make it so it can keep the current soft cutoff.
All they would need to do is make negavite throttle cutoff while 0 throttle is the idiotic slow cutoff. If i had the source code it would have been a 20 minute fix, even without knowing what language its written in :<
Old Jan 26, 2013, 08:43 PM
Joined Jan 2013
oh no...
thanks Xermalk
Old Jan 27, 2013, 03:15 AM
Rollmops67 is offline
Find More Posts by Rollmops67
Eternal beginner
Rollmops67's Avatar
France, Alsace, Strasbourg
Joined Jun 2012
Here you go :
http://reprol.free.fr/Master_CP_ex.pdf
Roland
Rollmops67 is offline Find More Posts by Rollmops67
Old Jan 27, 2013, 06:14 AM
Joined Sep 2012
Originally Posted by addifromgermany View Post
Just try the 13t that comes with the motor and lower a little bit your throttle in the TX
I was wrong, the pinion that came with the motor is M0,5 and the maingear is m0,6. After several flight I can now see that this pinion is eating my maingear.
Just ordered a m0,6 13t pinion, the are pretty hard to find especially cause my motor has a 3mm shaft
Old Jan 27, 2013, 09:48 AM
gapi is offline
gapi's Avatar
North Georgia
Joined Oct 2010
Originally Posted by Rollmops67 View Post
THANKS, I downloaded Adobe FontPack11000_XtdAlf_Lang.msi and it translated nicely.
Then did a "Save As" with a new name and its really nice.
If you just run the font pack and do not do the Save-As thing it will be sluggish as if it were streaming the translation.
Old Jan 27, 2013, 02:20 PM
Xermalk is offline
Sweden, Helsingborg
Joined Jun 2012
Originally Posted by system450 View Post
I found in another forum that setting the hold switch at -10% will stop immediatly the motor.
I can't try because i don't have the heli, but who have it can try this and tell if it works.
Hrm, anyone here running the official walkera devention firmware that could test this? Im running deviation now so i have a completely different throttle curve. Also its 15 m/s outside and id rather not spin my bird up indoors.
Old Jan 27, 2013, 09:37 PM
jazzjohn is offline
Find More Posts by jazzjohn
Madison WI
Joined Jan 2009
I just tried it at -10% and also -20%. It didn't make any difference. The delay is still there.
jazzjohn is offline Find More Posts by jazzjohn
Old Jan 28, 2013, 02:48 AM
Xermalk is offline
Sweden, Helsingborg
Joined Jun 2012
Depressing. Wish walker would fix it so I can start doing flips,rolls n inverted hover with my master.
Has anyone dared to replace the brushed tail for a brushless one?
I have a wk-wst-10A tail each lying around that could potentially be used for a tail mod.
Edit How does a brushless main + extra esc affect the Cog?
Old Jan 28, 2013, 05:42 AM
Joined Sep 2012
http://www.ebay.de/itm/MASTER-CP-HEL...item53f27f8ffd
http://www.ebay.de/itm/MASTER-CP-HEL...item53f27f568c
YouŽll need a converter for the brusless tail. See links :-)
Discussion Blade Mcpx v1 v2 vs Walkera Mini Cp vs Genius Cp vs solo pro 100 3d f.a.r.m.e.r Micro Helis 134 Mar 30, 2016 10:51 AM
Sold Walkera Genius CP with Devo 6 King.7200 Aircraft - Electric - Helis (FS/W) 2 Feb 02, 2012 10:52 AM
Sold Walkera Genius CP Brushless version 3D with 6-axis gyro Devo stretch1100 Aircraft - Electric - Helis (FS/W) 3 Jan 25, 2012 08:37 AM
For Sale Walkera Genius CP with DEVO 6 bymannan Aircraft - Electric - Helis (FS/W) 0 Nov 07, 2011 07:57 AM
New Product Walkera 6-Axis gyro UFO5# (new version with Camera~) DLY Micro Helis 6 Oct 29, 2011 01:48 PM
