Old Jan 23, 2013, 08:15 PM
ITS ME DAVID is offline
Find More Posts by ITS ME DAVID
ITS ME DAVID's Avatar
Joined Apr 2011
I actually want it for outside not inside.
ITS ME DAVID is offline Find More Posts by ITS ME DAVID
Old Jan 23, 2013, 08:38 PM
gapi is offline
Find More Posts by gapi
gapi's Avatar
North Georgia
Joined Oct 2010
My 1st Heli Setup ~ Master CP
Well I have been dialing in the MCP and learning the ways of the game.
Why am I already into it? I can thank Walkera for that.
They had the thing stroking pitch travel 100% both ways.
In the -100% pitch position it would never meet that goal because the ball linkage came down on the rotor head arms to the point of trying to pull the arms off or stripping the servo. See pic
In the +100% position it was over traveling to the point it maxed out before the servos did and I could see the servo arms flexing and hear them buzzing in protest.
The problem is I seen the over travel first and took care of that but before I could see the ball linkage arms trying to be pulled off I heard a "SNAP". After that I could almost see the swash was not level from across the room and the Ele arm was now pointed up in comparison to the others. I knew I was in trouble.
I already have servos coming and the arm could not be leveled out via jumping a cog so I did surgery on the servo and seen no signs of stripping. What I did see was a mechanism so cheap and flimsy it must have flexed and popped over one of the lower finer toothed gear cogs. I jumped it back over and reassembled. Then made sure it would not travel that far again.
Long story short I have the swash back in order with all three arms within .0015 of each other with a - 10% a +65% pitch setup.
I cannot believe it left the factory binding like that.
I checked and adjusted pitch with a very nice and useful RCLogger digital pitch gauge. Blade tracking is looking good too.
To sum it all up I cannot fly it thanks to Walkera again in their charger over cooked my battery and its puffed up like a balloon after its first charge. I contacted HeliRC Store and he told me the Walkera charger is famous for that suggesting an after market charger. I already have that but a day late. He is sending me a replacement in the event it was the battery or the charger he is taking care of the customer. Nice. I have a Turnigy Accucell 6 now. I have other batteries in rute also.
gapi is offline Find More Posts by gapi
Old Jan 24, 2013, 12:58 AM
gapi is offline
gapi's Avatar
North Georgia
Joined Oct 2010
What do you guys think of this battery?
Old Jan 24, 2013, 03:25 AM
addifromgermany is offline
Find More Posts by addifromgermany
Joined Sep 2012
Fits in and works fine, I use the same but with 45-90c rating, they are a little thicker
addifromgermany is offline Find More Posts by addifromgermany
Old Jan 24, 2013, 05:13 AM
Xermalk is online now
Find More Posts by Xermalk
Sweden, Helsingborg
Joined Jun 2012
Im trying to find the parts for a brushlesd master locally, but im having a hard time finding a governed esc.
Anyone mind listing a few common brands to help me in my search.
If i cant find one ill have to go with a turnigy plush 30A.
Edit seems the plush might have a gov.
Would any of these motors work well ?
http://translate.google.com/translat...FcPath%3D11_91
The 2 motors im primairly looking at is
Turnigy 2215H 3550kv (seems this one might be ~3200kv) and 2627 4200kv
Would these pinions work? http://www.rc-butiken.se/index.php?a...productId=4809
Their for 1/8 inch char motors. =3.175 mm.
First one is for 450 size and the other one seems it might be to much kv incase gov mode dosnt work properly.
Xermalk is online now Find More Posts by Xermalk
Old Jan 24, 2013, 06:36 AM
Joined Sep 2012
First one is for 450 size and the other one seems it might be to much kv incase gov mode dosnt work well with a plush esc.
Im flying with the Turnigy 2627 4200KV motor with the delivered 13t pinion. Fits in perfekt and has a lot of power.
Turnigy AE-30A Brushless ESC is the ESC i am using with nice softstart and gov-mode.
Both components are nicely cheap
Old Jan 24, 2013, 06:55 AM
Sweden, Helsingborg
Joined Jun 2012
Im scared of the 4200 kv with the stock pinion, considering how many walkera screws iv stripped/shatterd i wouldnt dare trust those puny 2mm head screws with a rpm of up to 5600
Even if i find a 11t pinion ill get headspeeds around 4800 rpm .
The 2215h should give me speeds between 4000 with a 13t to 5000 with a 15t.
Though, those pinions costs almost as much as the motor .
Old Jan 24, 2013, 07:10 AM
Joined Sep 2012
But in gov-mode u are usually not flying with a 100% Throttle-Line, 80% would be perfekt to give the esc headroom for the gov-mode.
I think in fact I am flying with about a little under 5000rpm
Old Jan 24, 2013, 07:44 AM
Sweden, Helsingborg
Joined Jun 2012
Noticed that the 2215 is almost twice the weight and recommends a 40a esc, so ill go for the 4200 kv and plush 30 A, if the stock pinion is to much ill pray that the 3.175mm 11T car ones fit.
Old Jan 24, 2013, 07:54 AM
Joined Sep 2012
Sorry, but the motor has a 2mm shaft, that does not fit
But in this shop you can find several pinions:
http://www.crossdata-tools.de/nanohe...Modul-0-5.html
Old Jan 24, 2013, 08:11 AM
LostTheTail is offline
Find More Posts by LostTheTail
pitch collector
Sweden, Gothenburg
Joined Jan 2013
Originally Posted by Rollmops67 View Post
As you say with 2 or 3 leds, the current drop would be much more, and the led become dimm.
And I prefer to have a bright LED as long as I fly.
Regards,
Roland
Actually, what I said was that you don't draw any higher current by using more LED's (connected in series).
You are of course right that it won't make a noticeable difference in flight time, just thought that you could use more LED's as it would not change the amount of power used.
Cheers,
Hugo
LostTheTail is offline Find More Posts by LostTheTail
Old Jan 24, 2013, 09:28 AM
mcmoyer is offline
Find More Posts by mcmoyer
450x, 180CFX
United States, TX, Burleson
Joined Feb 2012
Cheers,
Hugo
While I'm waiting for my parts to make the long boat ride, I probably should add an LED (or two or three) to aid in orientation. Is there a "Dummies Guide to Adding LED's to Your Master CP" around? Like a here's what you need & here's where you solder it, kind of thing.
mcmoyer is offline Find More Posts by mcmoyer
Old Jan 24, 2013, 09:35 AM
thwaitm is offline
Find More Posts by thwaitm
Team WarpSquad
United Kingdom, England, Royal Leamington Spa
Joined Jun 2011
I took a balance socket, the two outside wires, and soldered 3 LEDs in series (i.e. anode to cathode) I think I also have a 25mA SMD constant current diode soldered in there too but the heli is in the box in the basement so I can't check right now. I just left the wires long enough that I could place them anywhere. I used super fine (magnet) wire to keep the weight & flexibility to a minimum. Covered any exposed contacts in heatshrink/ShoeGoo.
thwaitm is offline Find More Posts by thwaitm
Old Jan 24, 2013, 10:31 AM
Sweden, Helsingborg
Joined Jun 2012
Master cp uses mod 0.6, not 0.5. Or it works just fine with a mod .5 pinion?
Old Jan 24, 2013, 10:40 AM
Joined Sep 2012
I am not sure at the moment what mod the Master needs, I took the 13t pinion that was delivered with the Turnigy motor and this is working fine.
Discussion Blade Mcpx v1 v2 vs Walkera Mini Cp vs Genius Cp vs solo pro 100 3d f.a.r.m.e.r Micro Helis 133 Oct 31, 2015 10:04 AM
Sold Walkera Genius CP with Devo 6 King.7200 Aircraft - Electric - Helis (FS/W) 2 Feb 02, 2012 11:52 AM
Sold Walkera Genius CP Brushless version 3D with 6-axis gyro Devo stretch1100 Aircraft - Electric - Helis (FS/W) 3 Jan 25, 2012 09:37 AM
For Sale Walkera Genius CP with DEVO 6 bymannan Aircraft - Electric - Helis (FS/W) 0 Nov 07, 2011 08:57 AM
New Product Walkera 6-Axis gyro UFO5# (new version with Camera~) DLY Micro Helis 6 Oct 29, 2011 02:48 PM
