Old Sep 03, 2012, 04:40 AM
zadaw is offline
Find More Posts by zadaw
Hong Kong
Joined Jan 2010
Originally Posted by Chow View Post
Odd. Let me quote TonyTypeS..
So yes motor gets warm. But it seems to have plenty of power.
What Tony said is consistent with what my vendor said as well. But it really depends on what you are comparing it with. He is not a micro heli flier and so I would not take his comments with a pinch of salt. He also said that the material looked cheap and was surprised that it was being sold for more than $80. He is used to flying high end stuff as Logos, Henseleit, Kasama, and Trex 600/700 owned by this clients. He is a video of him flying a Logo 400 that belongs to the owner of Helipal. Just look at the power of thing, especially those 3 consecutive loops at the beginning.
Logo 400SE Helicopter - F3C flight @ Hong Kong TKO (3 min 21 sec)
zadaw is offline Find More Posts by zadaw
Old Sep 03, 2012, 04:44 AM
Chow is offline
Find More Posts by Chow
Chow's Avatar
The Netherlands, NH, Nieuw-Vennep
Joined Mar 2011
I'm still confident that if you let the motor cool down in between flights it should be ok. Lot of problems with brushed motors appear when people do several flights without pausing in between. But time will tell. What I said before. I never had brushed motors suddenly stop in flight. I notice a degration in power long before the motor dies. And if I notice this I replace the motors.
Chow is offline Find More Posts by Chow
Old Sep 03, 2012, 04:53 AM
zadaw is offline
Hong Kong
Joined Jan 2010
The problems of the V400D02 are well known and that ls why we have to take V999D02's comments seriously if the same motor is used. I have used the same 7-6-6 servos in other helis and they are pretty bad as well. The V400D02 is a cult heli which has a large and loyal following despite its problems.
The V400D02 never sold well in Hong Kong. Vendors usually did not carry spares because they were usually bought by tourists. For some reason, the Master CP is really selling well in China now. I wonder whether it is because Walkera is perceived to have improved its quality since the Genius CP.
Old Sep 03, 2012, 04:57 AM
Firewolf is offline
Find More Posts by Firewolf
Firewolf's Avatar
Heliyork
Joined Nov 2009
+1 on that.
Firewolf is offline Find More Posts by Firewolf
Old Sep 03, 2012, 11:36 AM
zadaw is offline
Hong Kong
Joined Jan 2010
I am really at boiling point right now. I got 4 batteries and found that the heli would not work when I plug it in. I am sure it is the ESC as I was able to power the receiver using a BEC for my 250. I suspect the ESC was damaged when I tried to plug in the battery with the erroneous banana connector.
The battery was a third party battery and so it has nothing to do with Walkera. I am just mad of all the helis that have been sold by my vendor, why must I be the only one with this dud battery? If you buy third party batteries, make sure you check everything is alright with the connector before you plug it in.
Old Sep 03, 2012, 11:50 AM
Chow is offline
Chow's Avatar
Joined Mar 2011
Pfff, that's a case of real bad luck. Can you get a new ESC fast?
Old Sep 03, 2012, 11:55 AM
zadaw is offline
Hong Kong
Joined Jan 2010
I would think so, I don't really think this is my fault.
Old Sep 03, 2012, 11:58 AM
Chow is offline
Chow's Avatar
Joined Mar 2011
I see you are in Hong Kong. Should have an ESC soon. In my case I would be grounded for 1-2 weeks.
Old Sep 03, 2012, 12:56 PM
dkfuji is offline
Find More Posts by dkfuji
RC Helis: My Healthy Obsession
The OC, California
Joined Feb 2007
I have about 20 flights on the stock brushed motor and it seems to have the same climbout power as it did when it was new. I do not fly a brushed motor back to back so I give it ample time to cool down. So far, it has shown to be reasonably durable since the last crash was full speed reverse inverted flight into the side of my house. Damage was a bent tail boom, fractured boom support connector, bent vert fin, cracked horiz fin and a stripped elevator servo. All shafts were still straight, blades survived and skids had a serious paint scuff mark but still in one piece. Not bad really given how bad the crash was. I bent the boom back, epoxied the support and fins and replaced the gear in the servo and the heli is flying just as it did prior to the crash.
I have also installed a BL motor conversion. This heli becomes a rocket using the TA 4200 kv 3s motor on stock pinion and 18A Gaui ESC. IMO, it is no longer a beginner's CP with the conversion. Its just too quick and a the flip/roll rates are aggressive to say the least. Anyway, the tail holds solid even with full pitch climbouts inverted or not. Pretty good for a brushed tail motor set-up.
IMO, I would rather keep this particular heli stock brushed for some relaxing mild 3D flight. Just my personal taste is all.
dkfuji is offline Find More Posts by dkfuji
Old Sep 03, 2012, 01:05 PM
Xermalk is offline
Find More Posts by Xermalk
Sweden, Helsingborg
Joined Jun 2012
Actually, its kinda Walkeras fault, as they have decided to have their connectors reversed compared to whats usually used with those connectors. Its the same on the mini/gcp.
Xermalk is offline Find More Posts by Xermalk
Old Sep 03, 2012, 01:06 PM
fishfiend is offline
Find More Posts by fishfiend
Joined Jun 2008
Any chance of letting Manuel have a go ?
fishfiend is offline Find More Posts by fishfiend
Old Sep 03, 2012, 01:13 PM
Chow is offline
Chow's Avatar
Joined Mar 2011
Pffff, really need to doublecheck on my lipo's than when I get them. Expecting the Master CP from Helipal with Storm lipo's
Old Sep 03, 2012, 01:14 PM
zadaw is offline
Hong Kong
Joined Jan 2010
It is very difficult to describe what happened, but it was not a simple case of reverse polarity. The factory just got it wrong with the connector. Walkera has been using the mini/gcp connectors for years. Since they are probably the largest user of these connectors. they have the right to dictate what is usual or not. It is the others such as NE who are not conforming.
Old Sep 03, 2012, 01:27 PM
dkfuji is offline
The OC, California
Joined Feb 2007
I ordered a couple of more helis so I would have spares available before he takes a shot at her. I figure they should be here this week so that would open the door to some Manny test flights. This heli has no idea what she's in for then. LOL.
Old Sep 03, 2012, 01:28 PM
Chow is offline
Chow's Avatar
Joined Mar 2011
We need more Youtube clips so go for it
Discussion Blade Mcpx v1 v2 vs Walkera Mini Cp vs Genius Cp vs solo pro 100 3d f.a.r.m.e.r Micro Helis 134 Mar 30, 2016 10:51 AM
Sold Walkera Genius CP with Devo 6 King.7200 Aircraft - Electric - Helis (FS/W) 2 Feb 02, 2012 10:52 AM
Sold Walkera Genius CP Brushless version 3D with 6-axis gyro Devo stretch1100 Aircraft - Electric - Helis (FS/W) 3 Jan 25, 2012 08:37 AM
For Sale Walkera Genius CP with DEVO 6 bymannan Aircraft - Electric - Helis (FS/W) 0 Nov 07, 2011 07:57 AM
New Product Walkera 6-Axis gyro UFO5# (new version with Camera~) DLY Micro Helis 6 Oct 29, 2011 01:48 PM
