Old Oct 20, 2012, 05:53 AM
trumps is offline
Find More Posts by trumps
What's 3D?
trumps's Avatar
Australia, WA, Ellenbrook
Joined Feb 2008
Cheers bud, but you haven't seen her up close all being well tomorrow will be the day!
Cheers
Craig
trumps is offline Find More Posts by trumps
Old Oct 20, 2012, 06:53 AM
JIMA is offline
Find More Posts by JIMA
JIMA's Avatar
New Boston, Texas, United States
Joined Jan 2003
Good luck. If she flies as good as she looks, she will fly well indeed. Well done.
Jim
JIMA is offline Find More Posts by JIMA
Old Oct 20, 2012, 07:47 AM
owlsabie is online now
Find More Posts by owlsabie
owlsabie's Avatar
South Africa
Joined Feb 2009
Awesome Craig, good luck with the maiden
Al
owlsabie is online now Find More Posts by owlsabie
Old Oct 20, 2012, 08:10 AM
SAPSPIT is offline
Find More Posts by SAPSPIT
Make me a proper Spitfire!
SAPSPIT's Avatar
Norway
Joined Jul 2009
She looks very very good!!!! Fantastic work
Good luck with the maiden Craig
SAPSPIT is offline Find More Posts by SAPSPIT
Old Oct 20, 2012, 09:03 AM
trumps is offline
What's 3D?
trumps's Avatar
Joined Feb 2008
Thanks guys, fingers crossed
Old Oct 20, 2012, 09:05 AM
delsol is offline
Find More Posts by delsol
delsol's Avatar
Merced,Ca.
Joined Jul 2006
What a gorgeous looking plane! Can't wait to see pic's of her in the air.
delsol is offline Find More Posts by delsol
Old Oct 20, 2012, 05:09 PM
floss is offline
Find More Posts by floss
floss's Avatar
Auckland, New Zealand
Joined Sep 2005
A real standout model, well done.
floss is offline Find More Posts by floss
Old Oct 20, 2012, 10:54 PM
Longhorne is offline
Find More Posts by Longhorne
Res Ipsa Aviatur
Longhorne's Avatar
Sonoma County CA!
Joined Jul 2007
Drop dead gorgeous! I am definitely looking forward to some inflights.
Best of luck to you with the maiden,
Paul
Longhorne is offline Find More Posts by Longhorne
Old Oct 20, 2012, 11:33 PM
trumps is offline
What's 3D?
trumps's Avatar
Joined Feb 2008
Well.... i t looks like i had better get my backside in to gear and start Pete's article, because yes he has done it again!!!
Got to the field early this morning and put a couple of flights in with the Pfalz, Pup, and 109, once the thumbs were tuned the range check was done on the Heinkel .
i took it for a walk to the other side of the field because there was no way i was going to risk a down wind takeoff as the wind had started to pick up. Controls were double checked and with all ok i gave her the gun. she took off in about 10m, suprising the heck out of me, a nice climbout and circuits as i walked back to the flightline. she flew very nicely straight from the getgo, with 2 clicks of right aileron being all that was required, although this may be dialed when i get to fly her in calm air. CoG felt good, rudder and elevator were perfect for nice scale like flying, ailerons were a bit twitchy, but throws seemed in keeping with the type. no changes in attitude throughout the throttle range, so thrust line is fine, most of the flight was done at 1/2 to 2/3 throttle. nothing flashy was tried, just wanted to see that she flew straight. after 5 minutes throttle was cut to about 1/3 and she decended nicely for a cross wind landing, (didn't want to risk landing into the breeze and towards myself and the flightline) flaired her at about a foot high and she settled aboulutely perfectly with a slightly tail down attitude and about a 20m rollout. the battery took about 1400mah on the charger, this wasn't bad after the range and power checks, plus the flight. the guys got some bits of the maiden on video, but missed the landing unfortunately, such is life and i was greatful that they had a crack for me, Arlo kindly took the photos below using my not so great camera, cheers bud! Post flight checkes showed the tensioning wire between the gear legs lost tension when i landed, and will be relaced with some elastic in future, this and some expo for the ailerons was all that was found wanting, temps were acceptable with the motor being the warmest component at about 40deg C.
got another 2 flights in with her, the ailerons lost their twitchiness with the expo being added, she loops from level at full power, and i did a rather nasty barrelly roll ( have to work on that)
All in all she is a fantastic flyer, handles a bit of wind no problem, and landings are absolutely beautiful, haven't tried the flaps yet, they definately aren't needed, and are only there because i wanted them as an option.
i will post the vid of the maiden after some editing, and the subsequent flights as the guys put them up on utube.
Congratulations Peter,you have designed another beauty!
Cheers
Craig
Old Oct 20, 2012, 11:47 PM
csherman is offline
Find More Posts by csherman
Charles Sherman
csherman's Avatar
Victoria BC
Joined Sep 2009
Congratulations!
Great looking plane and great job on the build. Glad to hear it flies as well as it looks.
This will probably be my next build - love the lines of this plane.
csherman is offline Find More Posts by csherman
Old Oct 20, 2012, 11:49 PM
Banjofrog is offline
Find More Posts by Banjofrog
Geez That's A Big Fly
Banjofrog's Avatar
Australia, WA, Parkerville
Joined Sep 2011
Congrats on your maiden she is a fantastic flier and the greased landings were a treat, it was an absolute pleasure to share the sky with you with my HS123
Shaun.
Banjofrog is offline Find More Posts by Banjofrog
Old Oct 21, 2012, 12:34 AM
PETERRAKE is offline
Find More Posts by PETERRAKE
Norfolk, England
Joined Sep 2001
Craig,
Congratulations mate, a lovely looking model that sounds as if you're very happy with how she flies. There's no doubt that she looks the part.
May need to fake a few flying shots, although a couple of those you posted don't look too bad. I'm just not sure they're quite sharp enough to keep the editor happy.
Pete
PETERRAKE is offline Find More Posts by PETERRAKE
Old Oct 21, 2012, 01:04 AM
ben199 is offline
Find More Posts by ben199
ben199's Avatar
New Zealand
Joined Jul 2008
Congrats on the maiden and a great build!
-Reuben
ben199 is offline Find More Posts by ben199
Old Oct 21, 2012, 01:13 AM
Pat Lynch is online now
Find More Posts by Pat Lynch
a.k.a Maltone
Pat Lynch's Avatar
Australia, NSW, Goulburn
Joined Jan 2005
Great work Craig - I've watched your build over the months and didn't really expect a different outcome Peter must be getting rather used to ".....a touch of right trim and she was flying perfectly..."
Thanks for a great build thread and a good-looking model
Pat
Pat Lynch is online now Find More Posts by Pat Lynch
Old Oct 21, 2012, 01:39 AM
darook is offline
Find More Posts by darook
darook's Avatar
Johannesburg, South Africa
Joined Apr 2006
Congrats!!! Are all those planes scratchbuilds?
darook is offline Find More Posts by darook
Build Log Peter Rake's 48 " DH 6 scale 1/9 (No shortkit) (3. prototype build) bth Scale Kit/Scratch Built 101 Jul 22, 2016 01:56 AM
Build Log Peter Rake's 1/5 scale Chiribiri - Prototype build crawlspace Scale Kit/Scratch Built 128 Dec 12, 2014 06:35 PM
Build Log Martin K-III Kitten, Peter Rake Prototype Jeff in So Cal Scale Kit/Scratch Built 95 Mar 15, 2014 02:32 PM
Build Log Peter Rake's 36" WACO 9- prototype build Zephyr41 Scale Kit/Scratch Built 97 Jul 26, 2013 12:19 PM
Build Log Going to the races - Peter Rakes MS and Rex racer prototypes. Modelholic Scale Kit/Scratch Built 64 Jun 29, 2012 04:53 AM
