This thread is privately moderated by unclegeorge, who may elect to delete unwanted replies.
Old Jun 01, 2012, 01:45 PM
unclegeorge is offline
Find More Posts by unclegeorge
Trader Rating: 234
unclegeorge's Avatar
United States, FL, Sarasota
Joined Feb 2005
Trader Rating: 234
Sold
Glow to Gas easy with new 9CC Gas Engine
BACK IN STOCK-Our popular little 9CC gas engine!!!
Gas Engine the size of a .40 size engine! Cheaper fuel; but more power. Same as a .51 glow engine!!!
Order yours before they sell out again. If you snooze, you loose!
Quit buying expense Glow Fuel, get the same size as a.40 Glow engine that burns Gas not expense Glow fuel!
Here is your chance to get a small compact Gas engine the same size as an OS Max .46 Glow engine that burns Gasoline. The engine will pay for itself the first year!
Remember to burn gas WITHOUT ethanol or get a marine gas treatment that takes it out to save the O-Rings and Diaphragm pump in this engine.
Take a really close look at the pictures and the specs and you’ll get as excited as I did when I discovered it.
This is a new generation of small gas quality engine, it combines the advantages of both Nitro and gasoline engines, compact in size, light weight, fuel economy, reliable and powerful.
GT9 Engine Type: Gasoline Two-stroke, Air Cooled
Displacement (cc): 9.07cc
Bore x stroke (mm): 23.35 x 21.2
Carburetor: NGH made 60G needle with pump membrane
Max output: 0.8HP@15000RPM
RPM Range: 2600-15000RPM
Ignition: Auto advanced Rcexl DC-CDI with special spark plug cap
Spark plug type: 1/4 x 32 Rcexl
Ignition Power: 4.8V
Lubrication Oil: 2 cycle engine Oil API TC/JASO FD or better specs. (Mobil + M2T)
Break-in fuel oil ratio: 20:1 (5%)
General use fuel: 25:1 (4%) (Oil percentage can not less than 4%)
Recommended propellers: 10 x 6 to 12x6 (two blades)
Weight: 425g (without ignition)
545g complete
1.Size: same as .52 glow engine size
2.Mount: beam-mount
3.Carb: special smaller carb with pump and regulator by NGH
4.Muffler: special smaller anodized Pitts-style muffler with Black
5.Plug: 1/4*32 NGK
6.Exploded: almost same as a .52 glow engine. just extra special carb, muffler, CDI and Plug, and special pump regulator (not shown in the picture)
7.Use Airplane: almost same use for .52 glow engine with 40 size airplane!
I will sell this engine NIB for $187.00 plus $12 shipping by priority mail inside the US with confirmation and tracking number.
Please give me your mailing address and please refer to the item you are buying in the “Subject line” along with your mailing address in your Pay Pal purchase. My account in Pay Pal is under uncgeorge@comcast.net
Uncle George [/COLOR]
unclegeorge is offline Find More Posts by unclegeorge
Old Jun 01, 2012, 03:45 PM
Plasmajoe is offline
Find More Posts by Plasmajoe
Trader Rating: 410
United States, NC, Lexington
Joined Mar 2011
Trader Rating: 410
Is this the same engine that Hi-Models sells for $165???? or is there a difference?
http://www.himodel.com/engines/NGH_9...plane_GT9.html
Plasmajoe is offline Find More Posts by Plasmajoe
Old Jun 01, 2012, 04:06 PM
Trader Rating: 234
Joined Feb 2005
Trader Rating: 234
Joe,
It is the same engine but I choose to price mine a little less. Did you want to order one from me since it is a better price?
Let me know.Please give me your mailing address and please help me keep track of you order by typing in the item you are buying in the “Subject line” along with your mailing address in your Pay Pal purchase.
Uncle George
Old Jun 01, 2012, 04:19 PM
Sxn McM is offline
Find More Posts by Sxn McM
Trader Rating: 24
Rekitter of fine aircraft
Sxn McM's Avatar
United States, TX, Houston
Joined May 2004
Trader Rating: 24
What's the muffler bolt pattern? That muffler won't work for me, but if I can stick a Bisson on it I might have to seriously consider this.
Sxn McM is offline Find More Posts by Sxn McM
Old Jun 01, 2012, 07:54 PM
keyman923 is offline
Find More Posts by keyman923
Trader Rating: 70
Former Futaba employee
Joined Aug 2006
Trader Rating: 70
keyman923 is offline Find More Posts by keyman923
Old Jun 02, 2012, 09:16 AM
Trader Rating: 234
Joined Feb 2005
Trader Rating: 234
I couldn't read your 3 dots.
Old Jun 02, 2012, 09:23 AM
Trader Rating: 234
Joined Feb 2005
Trader Rating: 234
I will go down to the shop on Monday and measure the width of the muffler mounting holes.
Uncle George
Old Jun 02, 2012, 09:46 PM
shepster is offline
Find More Posts by shepster
Trader Rating: 10
shepster's Avatar
United States, IN, New Castle
Joined Mar 2010
Trader Rating: 10
you got conversion kits for super tigre 2000s nitro to gas ?
shepster is offline Find More Posts by shepster
Old Jun 05, 2012, 11:13 PM
2.4ghz is offline
Find More Posts by 2.4ghz
Trader Rating: 80
2.4ghz's Avatar
United States, NM, Albuquerque
Joined Sep 2009
Trader Rating: 80
uncle george, I might be a little slow and not good at math but hi models is selling theres for 165.00 and you are selling yours for 187.00 how can yours be cheaper??? im i missing something here?? I can see the numbers are different and the 2nd number on yours is higher then Hi models so I am assuming yours is higher priced. really im i missing something here??
2.4ghz is offline Find More Posts by 2.4ghz
Old Jun 05, 2012, 11:22 PM
HEATEDHAT is offline
Find More Posts by HEATEDHAT
Trader Rating: 12
United States, GA, Savannah
Joined Nov 2011
Trader Rating: 12
yea...so i wasnt the only one that caught that huh
HEATEDHAT is offline Find More Posts by HEATEDHAT
Old Jun 05, 2012, 11:25 PM
2.4ghz is offline
Trader Rating: 80
2.4ghz's Avatar
Joined Sep 2009
Trader Rating: 80
yep just checking, I had to look twice and didnt even need the calc.
Old Jun 06, 2012, 08:11 AM
Trader Rating: 234
Joined Feb 2005
Trader Rating: 234
Sorry about that. You should buy it at the cheapest price you can.
Uncle George
Old Jun 08, 2012, 04:28 PM
dr.E is offline
Find More Posts by dr.E
Trader Rating: 349
Don't cut the Yellow Wire
dr.E's Avatar
Ridgewood ,NJ
Joined Jan 2000
Trader Rating: 349
165.00 from HiModels....approx 27.00-30.00 for shipping, no warrantee or US contact if things go bad with it...... Yup , that's a real Bargain
dr.E is offline Find More Posts by dr.E
Old Jun 08, 2012, 04:33 PM
2.4ghz is offline
Trader Rating: 80
2.4ghz's Avatar
Joined Sep 2009
Trader Rating: 80
i can get it shipped to me for 4.11 and there is no warrantee with ungle george either. It is still cheaper, if you want it fast buy from uncle george I have bought from him before.
For Sale NEW ENGINE-17CC replace .90 Glow with Gas unclegeorge Aircraft - Fuel - Engines and Accessories (FS/W) 1 Apr 05, 2014 05:58 PM
Sold NIB-9CC Gas Engine the same size as >40 Glow Engine! unclegeorge Aircraft - Fuel - Engines and Accessories (FS/W) 0 May 25, 2012 10:19 AM
Sold Back in stock-9CC Gas Engine $187-replaces .40 size glow engine. unclegeorge Aircraft - Fuel - Engines and Accessories (FS/W) 1 May 22, 2012 11:55 PM
Sold Back in stock-9CC Gas Engine $187-replaces .40 size glow engine. unclegeorge Aircraft - Fuel - Engines and Accessories (FS/W) 2 May 14, 2012 02:06 PM
Sold NEW ENGINE-17CC replace .90 Glow with Gas unclegeorge Aircraft - Fuel - Engines and Accessories (FS/W) 0 May 11, 2012 09:28 AM
