Old Jun 01, 2012, 02:45 AM
Joined Aug 2011
2,3m / 88" Extra 300 Depron/fiberglas composit Scratchbuild - Extreme Light
Hey folks
After building lots of depron planes, including a 1/4 Cub, I have now started this new project:
A 2,3m Extra 300, builded in 3mm Depron, and full covered with 49g fiberglass. I beliewe in a takeoff weight about 4-5kg.
My Cub - takeoff weight 2,2kg
Description:
First step on the Extra
Description:
polledk is offline Find More Posts by polledk
Old Jun 01, 2012, 01:27 PM
Joined Jan 2009
Wow! 2.3 meters is HUGE! Good luck on the maiden!
What glue do you use between wood and foam?
djacob7 is offline Find More Posts by djacob7
Old Jun 01, 2012, 04:33 PM
Joined Aug 2011
Between wood and depron i use UHU Por or polyurethane glue - depense on where.
Old Jun 02, 2012, 05:27 PM
Joined Aug 2011
Latest pic´s from the workshop
Description:
Description:
Description:
Description:
Old Jun 03, 2012, 09:57 AM
Joined Aug 2011
More pic´s of the wing construction
Description: assembly of the box in the wing
Description:
Description:
Description: the box´s for the wing
Description: complete main bar, 250g
Old Jun 03, 2012, 06:09 PM
Joined Aug 2011
First wingsection almost done.
Weight this far is 146g/5oz
Description:
Description:
Old Jun 03, 2012, 06:55 PM
Canada, ON, Ottawa
Joined Dec 2011
Thats huge! Great work so far.
preelude is offline Find More Posts by preelude
Old Jun 04, 2012, 03:51 AM
Warbirds Lover
South of France
Hi !
Very interesting project...
Subscrived !
Dreamcatcher is offline Find More Posts by Dreamcatcher
Old Jun 07, 2012, 11:18 AM
JustFlying
rebell's Avatar
Joined Dec 2005
How is the progress?
rebell is offline Find More Posts by rebell
Old Jun 07, 2012, 04:54 PM
Joined Aug 2011
Got a few more pic´s from the work so far.
The wingpanels this far are showing 207g / 7,3OZ each.
Description:
Description:
Description:
Description:
Description:
Motor is ordered: Hacker A60-6XS
Description:
Old Jun 09, 2012, 08:58 AM
Joined Aug 2011
The maingears on the market, that will fit this size, are too stiff and heavy, so i´ll try make one myself.
Laminated in plywood.
First I have wet the 4 layers of 1mm ply, and will let them dry in the form. Them I´ll glue them with polyurethane, again in the form.
Description:
Description:
Description:
Description: "Toe-in" is builded in the form
Old Jun 10, 2012, 04:31 PM
Joined Aug 2011
Maingear is out of the form. It was still feeling wet, so into the owen for 6 hours. Now it feels dry, and strenght is feeling like it will work. weight is 106g
Description:
First wing panel is ready to be sanded, and then fiberglass. Weight incl. aileron is 216g
Description:
Old Jun 12, 2012, 02:44 PM
Joined Aug 2011
Both wingpanels are now ready to be sanded before fiberglas, so its time for the fuselage.
I´ll use same construction pricip as the Extreme Flight I´m copying, with an inner section, wich will be the connection between motor, accu, wing and maingear.
Description:
weight for inner section incl. maingear is 310g
Description:
Description:
Description:
Old Jun 15, 2012, 04:54 AM
Joined Aug 2011
Status this far
Description:
Description:
Description:
Old Jun 15, 2012, 05:40 PM
Joined Aug 2011
And - some more pic´s
Description:
Description:
Description:
Dowels in 2mm carbon
Description:
For Sale Extreme Flight 58" Extra 300 LPU Hobby Garage Aircraft - Electric - Airplanes (FS/W) 6 Mar 28, 2012 12:20 PM
For Sale Extreme Flight Extra 300 LPU Southeast MO ml0126 Aircraft - Electric - Airplanes (FS/W) 0 Mar 06, 2012 07:13 PM
Sold Extreme Flight 58" Extra 300 EDFPILOT Aircraft - Electric - Airplanes (FS/W) 11 Feb 24, 2012 07:20 PM
Wanted Mirage 2000 fiberglas/composite 90mm sdougm Aircraft - Electric - Jets (FS/W) 8 Jan 12, 2012 07:08 AM
Yippee! please can you help me find a 20"-30" extra 300 depron plan? vanepico 3D Flying 9 Nov 10, 2005 01:20 PM
