Old May 31, 2012, 11:07 AM
kad is offline
kad
Find More Posts by kad
kad
Quad Crasher
kad's Avatar
United States, NY, Poughkeepsie
Joined May 2012
New Product
Turnigy H.A.L. (Heavy Aerial Lift) Quadcopter Frame
Didn't see this already mentioned anywhere here. Looks intriguing...
http://www.hobbyking.com/hobbyking/s...ame_585mm.html
-K
kad is offline Find More Posts by kad
Old May 31, 2012, 11:23 AM
FullmoonCat is offline
Find More Posts by FullmoonCat
Rank Amatuer
FullmoonCat's Avatar
United States, ID, Boise
Joined Dec 2011
They say it's specifically for video, and then make it + configuration only. Fail.
FullmoonCat is offline Find More Posts by FullmoonCat
Old May 31, 2012, 11:28 AM
jy0933 is offline
Find More Posts by jy0933
James not bond
jy0933's Avatar
Joined May 2012
it says
Specs:
Weight: 614g (w/out electronics)
Width: 585mm
Motor Bolt Holes: 16/19/25mm
X or + Landing gear setup
jy0933 is offline Find More Posts by jy0933
Old Jun 26, 2012, 08:08 AM
lilboatsman is offline
Find More Posts by lilboatsman
United States, WI, Madison
Joined May 2012
Anyone try this thing out yet? I'm wondering how much it can lift. SLR?
lilboatsman is offline Find More Posts by lilboatsman
Old Jun 26, 2012, 09:25 AM
Tr4n5p0rt3r is online now
Find More Posts by Tr4n5p0rt3r
Joined Dec 2011
I got it a few days ago.
It is possible to mount the landing gear in X-setup. You just need 4 longer M3 screws as the delivered one in my opinion.
First I changed the tubes from the original 23cm ones to 40cm ones.
Ordered a ZYX-S to control the Quadrocopter (a few days before the new KK2 board was released...). Motors will be NTM 3035-1100kv with 11x5.5 APC-E propeller and 30A HobbyKing Blue Series ESCs.
But it will take time till I can fly it.
The Quality is great! The aluminium frame has excellent finish and the landing gear is made of carbon rods! Unbelievable for that price...
Tr4n5p0rt3r is online now Find More Posts by Tr4n5p0rt3r
Old Jun 26, 2012, 12:40 PM
Lherning is offline
Find More Posts by Lherning
Gustaff
Guatemala
Joined Aug 2008
It sounds quiet heavy, do you think it can lift a Go Pro and FPV gear?
Lherning is offline Find More Posts by Lherning
Old Jun 26, 2012, 12:55 PM
man1024 is offline
Find More Posts by man1024
man1024's Avatar
Joined Oct 2011
nice! good job HK.
man1024 is offline Find More Posts by man1024
Old Jun 28, 2012, 05:15 PM
Joined Dec 2011
That's exactly what I want to do.
So my setup should lift a GoPro with FPV transmitter easily.
Another good point about this Quadcopter is that the weakest point will be the aluminium tubes.
So if the quad crashes they will be bent. And I paid around 8$ for all four of them.
That is ways cheaper then all the other parts of the quad and you can buy aluminium tubes nearly everywhere.
Old Jun 29, 2012, 09:00 PM
Joined May 2012
A GoPro, yes. An SLR? I'm assuming probably not. Probably have to go with a 6 prop machine, yes?
Old Jun 29, 2012, 10:45 PM
dutchcommando is offline
Find More Posts by dutchcommando
making crashing a lifestyle!
dutchcommando's Avatar
The Netherlands, UT, Soest
Joined Feb 2012
i've got me one also.
to me it looks like they designed it to be + and thought in the last minute that a X type would be better for apv/ap.
when putting the landing gear on as X the gear sits very tight to the nuts for the arms.
if used in + one can use the threads inside the gear and have room enough..
bit it is a nice frame once it's all bolted together!
the stock gear is reused for my Flathexa, i cut it in half... lol
the HAL will be getting the new KKv2 board once it arrives.
HK 30A esc's
park 450 (C2830) 850 KV motors
for props i will try 10X5 or 11X4.7 and maybe 9X5
lipo's will be 3S, i have several 3000, 3600 and 5000 mAh 30C lipo's, so any of those will be used..
i will be using a 500 heli type landing skid.
the use of the HAL is yet to be determined.. maybe FPV, or light AV. or maybe just bashing around
dutchcommando is offline Find More Posts by dutchcommando
Old Jun 30, 2012, 05:09 AM
Joined Dec 2011
With a hexacopter it should be no problem.
Maybe the HAL can do it too with enough power, but because of the lever arm of the tubes the frame has to carry a quite heavy load.
When I have everything together I can try how much the HAl can lift.
@ dutchcommando
I bought the HAL from Turnigy because it is a cheap possibility to try out some things.
The aluminium tubes can be replaced easily and they cost not that much compared to a CF tube.
Old Jun 30, 2012, 04:26 PM
Joined May 2012
I look forward to hearing about the tests. Looks like it's quickly becoming a popular quad for the price.
Old Jul 01, 2012, 12:48 AM
Joined Feb 2012
i got mine because it was a HK freebie from a mate of mine.. LOL
Old Jul 01, 2012, 03:00 AM
gitit20 is offline
Find More Posts by gitit20
gitit20's Avatar
Joined May 2012
Wow that does look nice :0 I am sure it could be fitted with some carbon fiber tubes to lower the weight even more and be stronger... and less then 35 bucks WOW
gitit20 is offline Find More Posts by gitit20
Old Jul 02, 2012, 07:00 AM
icah is offline
Find More Posts by icah
Hungary, Pest County, Tököl
Joined Oct 2010
Nope! I have crashed mine and the only thing that was bent was the motor mount plate. NO harm to the arms at all.
I have made my flight tests and also check vibrations on the frame, check here for description and videos: http://www.rcgroups.com/forums/showthread.php?t=1665406
Any questions are welcome but I can tell you this is the best frame I have met until now for AP in the price range below 150$.
icah is offline Find More Posts by icah
New Product Turnigy Talon Carbon Fiber Quadcopter Frame CrashingDutchman Multirotor Talk 510 Jan 20, 2015 01:05 AM
Sold AD-6 Heavy Lift V2?AD-6 Heavy Lift frame+Photo higher Pro Mount-200 iranbarkley Aircraft - Electric - Multirotor (FS/W) 7 Jan 15, 2012 02:32 PM
For Sale X 450 full CF frame and Heavy lift camera mount hemanthtguru Aircraft - Electric - Multirotor (FS/W) 1 Dec 11, 2011 10:50 PM
Discussion Heavy lifting quad, where's the limit? Trnquill Multirotor Talk 3 Sep 17, 2011 04:14 PM
Discussion MK heavy lift hexa nickwad Multirotor Talk 0 Sep 12, 2011 10:52 AM
