Old May 30, 2012, 07:38 PM
Keithhs is offline
Find More Posts by Keithhs
Building toys since 1941
Extreme southeast Kansas
Joined Aug 2007
Albatros Micro EP Tx-R binding
I just bought a new Albatros Micro EP Tx-R.with the adapter to use with any transmitter. My transmitter is a Spektrum DX7 which is a direct plug in. It appears that I now have to bind the planes receiver to the transmitter. The instructions say to "push the bind button". I would prefer to not cut the new plane open. I am thinking that if I knew where the bind button was on the receiver I could cut a small hole in the fuselage and reach in with a small rod and hold the button down while binding it. A picture of the receiver board would be great or even a description of where the bind button is located on the board. Thanks....
Keithhs is offline Find More Posts by Keithhs
Old May 30, 2012, 08:27 PM
Digital Don is offline
Find More Posts by Digital Don
Digital Don's Avatar
United States, IL, Manteno
Joined Dec 2006
The reference to a 'bind button' is for separate Tactic receivers. When you use the AnyLInk with the Albatros, it automatically binds to the receiver in the Albatros.
Since you're using a Spektrum transmitter, you'll have to 'remap' the AnyLink so the channel assignments match. Page 5 of the manual explains how to do this.
After you've done that, select the model memory you want to use, then turn your transmitter OFF. Next plug the AnyLink into the trainer port, and then into the transmitter's charger socket. The transmitter will activate, the AnyLInk's light will come on, and it should beep twice. Plug the battery into the plane and you should be good to go.
Remember that on the current FlyZone micro planes, you have to 'arm' the speed control before the throttle will respond. You do this by pushing the throttle stick full up until the plane 'beeps' then full down and it will beep again.
Also, the rudder will be on the left stick as it is for 4-channel planes. If you want to change the rudder over to the right stick (where it is on most 3-channel planes), this page will tell you how to do it.
Hope that helps!
Don
Digital Don is offline Find More Posts by Digital Don
Old May 30, 2012, 11:05 PM
Keithhs is offline
Joined Aug 2007
Thank you very much for that concise and easy to understand explanation...
Old May 31, 2012, 01:27 AM
Joined Dec 2006
You're welcome. Have fun with the new bird!
Don
Old May 31, 2012, 04:34 PM
Keithhs is offline
Joined Aug 2007
Worked perfect...Thanks again, Don...
Discussion Flyzone Albatros TX-R airplane - Don't buy it unless you have a computer radio aeajr Beginner Training Area (Aircraft-Electric) 8 Jun 20, 2012 12:29 PM
Sold Great Planes Gee Bee R-1 EP Rx-R LPU Melbourne, Florida fltekdiver Aircraft - Electric - Airplanes (FS/W) 6 May 03, 2012 06:57 PM
Sold Great Planes Ultra-Micro 30mm F-86 Sabre EDF, TX-R with ANYLINK! Roswalt Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 15 Feb 24, 2012 06:42 AM
Sold Great Planes Ultra-Micro 30mm F-86 Sabre, TX-R w/ANYLINK Roswalt Aircraft - Electric - Jets (FS/W) 5 Feb 24, 2012 06:42 AM
Discussion will my pz micro cessna.tx bind.to.the new.stuff? mike93 Micro Ready-to-Fly 2 Feb 11, 2012 11:54 PM
