Old Oct 05, 2012, 09:19 PM
SpadCat2000 is offline
Find More Posts by SpadCat2000
United States, AZ, Lake Havasu City
Joined Feb 2010
The Photos....
The balsa ship project in the background is a Sig Liberty Sport that I picked up today for next to nothing.
SpadCat2000 is offline Find More Posts by SpadCat2000
Old Oct 07, 2012, 07:39 AM
jetcaptain is offline
Find More Posts by jetcaptain
Have Fun! Land, Sea or Air
jetcaptain's Avatar
United States, TX, Austin
Joined Jul 2006
Looking great SpadCat! That Sig looks like a fun project. Why can't I find good deals like that?
jetcaptain is offline Find More Posts by jetcaptain
Old Oct 08, 2012, 07:32 AM
wim5150 is offline
Find More Posts by wim5150
illinois
Joined Jun 2001
SpadCat what's the plane parked in the puddle ?
wim5150 is offline Find More Posts by wim5150
Old Oct 08, 2012, 02:07 PM
jetcaptain's Avatar
Joined Jul 2006
wim5150,
He posted the details of the photos on the post just before that one.
http://www.rcgroups.com/forums/showp...&postcount=195
Hope this helps.
Chris
Old Oct 08, 2012, 08:39 PM
Joined Feb 2010
In an earlier post, I wrote that I had not tried to bring a foamie's finish up to the level of a balsa ship, and even though the Attacker photo was pinned right next to the shop door, I had forgotten about it. If the Midwest material (it might have been called "Glass Koat" but I could easily be wrong) was still available, it would be very simple and easy to make foamies look great.
The Attacker was a EPS ARF that was of a very high quality and a good flyer. I would buy another one if they became available.
I am now in process of painting the wing and it is coming along a lot faster than the fuse. Will post pics when ready.
SpadCat
Old Oct 09, 2012, 09:01 PM
Joined Feb 2010
Hi Chris,
Yea!! FINALLY done with most of the painting! Just need to decide what I want for final trim such as Air Force insignias and or N numbers and color of control surfaces. Also need to paint the intakes and exhaust black.
I found that I had to cut the paint much more than I thought, and once I did that, the painting was easy. Just had to be careful about runs. If the Pat flies as good as I think it will, I may build another one that will turn out much nicer. The right side is the bad side, and I might paint the turtle deck red (that would hide the more obvious flaws).
Lon
Old Oct 09, 2012, 09:48 PM
jetcaptain's Avatar
Joined Jul 2006
Looks really nice SpadCat! Do you happen to have a pic of the gear setup?
Old Oct 09, 2012, 10:07 PM
Joined Feb 2010
I pulled the gear out before the paint process. Once I get the control surfaces installed, then I will reinstall them which is only a 5 or 10 minute task.
SpadCat
Old Oct 11, 2012, 06:43 AM
Baseman is offline
Find More Posts by Baseman
Radian, Polaris, Mistaken ID.
Baseman's Avatar
United States, MO, Lee's Summit
Joined Nov 2010
Really Great work!
Hi Chris,
Lon
Baseman is offline Find More Posts by Baseman
Old Oct 11, 2012, 07:02 AM
wim5150 is offline
illinois
Joined Jun 2001
Good looking Pat Spad. Thanks for the info on the Attacker.
Old Oct 11, 2012, 07:24 AM
Leadfoot is offline
Find More Posts by Leadfoot
Knuckle dragging pilot
Canada, ON, Kitchener
Joined Feb 2001
Looks great Lon! I've gotten a bit sidetracked with some other projects, but will definitely be getting back to this one.
Steve
Leadfoot is offline Find More Posts by Leadfoot
Old Oct 11, 2012, 09:35 PM
Joined Feb 2010
Hey Guys,
Here are a couple of shots with the gear up and down. With more work, one could make the wheel wells nicer.
SpadCat
Old Oct 12, 2012, 12:05 AM
Joined Feb 2010
After a bit of thinking, the best and easiest way to make the wheel wells nicer would be to use a hole saw and cut the wells out all the way through the top of the wing, and then use bi-glass tape to cover the hole. I did this at the other end of the retacts and the paint covered the bi-directional glass tape very nicely. I did brush on several coats of Minwax to help with adhesion.
SpadCat
Old Oct 12, 2012, 07:18 PM
jetcaptain's Avatar
Joined Jul 2006
Hey Guys,
SpadCat
Me likey!! Way to go Lon!
Old Oct 13, 2012, 01:33 AM
Joined Feb 2010
Thanks, Chris, I am glad you like it. Still like your Air Force Thunderbird theme better, but not too unhappy with my sport finish, even if it is kind of atypical.
Got some work done on the ailerons. Instead of a spar, I glued balsa strips to the inside and outside edges which really stiffened them up. I am not going to taper the rear of the ailerons like I usually do, as I want as much "bite" as I can get.
It looks like next weekend should finally be maiden time, Yea! Then after that, I can finally get back to finishing the Dirty Birdy .20.
SpadCat
Question Balsa sheeting foam core wings vs just glassing. erh7771 Scratchbuilt EDFs 74 Mar 14, 2016 10:40 PM
Discussion Making 3" foam sheet out of two thinner sheets? bugdude The Builders Workshop 12 Jun 03, 2012 11:49 AM
Discussion one sheet dollar tree foam board flying wing 63 nova The Builders Workshop 1 Mar 12, 2012 04:18 AM
Build Log OSSP (one sheet sport plane) ray foley Foamies (Scratchbuilt) 27 Feb 11, 2012 10:28 PM
Discussion Full 3d hot wire cut foam trainer/sport plane acdcrocks4 Foamies (Scratchbuilt) 3 Sep 20, 2011 06:11 PM
