Old May 30, 2012, 03:25 PM
jetcaptain is offline
Find More Posts by jetcaptain
Have Fun! Land, Sea or Air
jetcaptain's Avatar
United States, TX, Austin
Joined Jul 2006
Build Log
"The Patriarch" Sheet Foam Sport Plane
The Patriarch is similiar to the Great Planes Patriot. It is made with 6mm Depron and pink foam. However, the model can be made entirely out of depron if desired.
The Patriarch
Wing Span : 47"
Length: 43" (spinner tip to exhaust cone)
Motor: Grayson Hobby Supermega Jet Outrunner
Prop: APC E 7x5
Batt: 3S 2200 mah
Weight: 32 oz as flown
jetcaptain is offline Find More Posts by jetcaptain
Last edited by jetcaptain; Nov 16, 2012 at 06:37 PM. Reason: Changed recommended engine
Old May 30, 2012, 03:27 PM
jetcaptain's Avatar
Joined Jul 2006
Taping The Plans Together
Started taping the plans and cutting out parts. Wow, this thing take up my whole kitchen!
Old May 30, 2012, 08:13 PM
tonytiger20 is offline
Find More Posts by tonytiger20
tonytiger20's Avatar
USA, MS, Picayune
Joined Jan 2011
We'll be watching
tonytiger20 is offline Find More Posts by tonytiger20
Old May 31, 2012, 12:12 AM
jetcaptain's Avatar
Joined Jul 2006
All the patterns have been cut out. Next will be to 3M 77 the patterns and then start cutting all those parts out!
Old Jun 01, 2012, 01:09 AM
jetcaptain's Avatar
Joined Jul 2006
Cutting and Cutting and Cutting.....
All the parts have been cut for the Patriarch. I almost forgot how much fun cutting depron was. Started taping all the parts together to check fit. I found a few areas where I will need to go back and adjust the plans. Oh well, that's scratch building for you! It's almost starting to look like a plane.
Old Jun 01, 2012, 01:02 PM
jetcaptain's Avatar
Joined Jul 2006
Building the Fuselage
Started the fuselage construction today. More depron cutting for the fuse side doublers, and then gluing them on. Currently dry fitting all the formers and will get it all lined up before using CA to glue everything together.
Old Jun 01, 2012, 01:28 PM
dedStik is offline
Find More Posts by dedStik
Redacted per NSA "suggestion"
dedStik's Avatar
United States, VA, Virginia Beach
Joined Feb 2012
Looking good so far.
dedStik is offline Find More Posts by dedStik
Old Jun 01, 2012, 03:50 PM
Razors edge 29 is offline
Find More Posts by Razors edge 29
QuAd FaNaTiC
Razors edge 29's Avatar
Canada
Joined Aug 2009
Subbed
Razors edge 29 is offline Find More Posts by Razors edge 29
Old Jun 02, 2012, 11:14 AM
jetcaptain's Avatar
Joined Jul 2006
Installed Fuselage Top Plate
I was able to get all the former's glued yesterday. Added the fuse top plate last night and sanded to rough shape this morning. I made it a little more curvy than the original. Next up is adding the push rods while the bottom is still open
Old Jun 04, 2012, 10:28 PM
jetcaptain's Avatar
Joined Jul 2006
Making the inlets
Finished making the inlets for both sides and they were glued on. Messed up one side inlet when I had a snafu on the band saw and had to make a new piece. All is well though.
Finished adding some carbon to stiffen the vertical stabilizer, beveled the rudder and added hinges. It is ready to install on the fuselage.
I also ran out of UHU Creative. I have tried several other glues, but nothing compares to UHU for sticking depron together. I have read that foam -tac by Beacon is similar, but I can't seem to find a store that has it in the Austin, TX area.
Progress will be a little slow since I realized I do not have any more carbon rod to stiffen the wing and the horizontal stabilizer. Will need to place a order for that as well.
Old Jun 08, 2012, 04:38 PM
jetcaptain's Avatar
Joined Jul 2006
Cowling and Canopy
Glued and rough sanded the cowling and canopy. I used Beacon 3 in 1 advanced craft glue. It's not as good a UHU, but it gets you by in a pinch. Still need to order some carbon rod for the wings and a 1.5" spinner. Next will be putting some carbon stiffeners in the horizontal stabilizer. After that, both the horizontal and vertical stabilizers will be epoxied on.
Old Jun 09, 2012, 06:14 PM
jetcaptain's Avatar
Joined Jul 2006
Install the vertical and horizontal stabilizers
The Patriarch is coming along. Installed some stiffeners in the horizontal stabilizer and hinged the elevators. Glued in both the vertical and horizontal stabilizers in place. Also glued on the canopy. Will install the control horns and servos next, while I wait for some carbon for the wings.
Old Jun 16, 2012, 11:36 PM
jetcaptain's Avatar
Joined Jul 2006
Wing Complete!
My order from BP Hobbies came in this week (carbon rod and spinner). I have nothing but good things to say about the service and shipping. Will order again from these guys.
Since my carbon rod came in, I was able to work on the wing this week. Just finished installing the aileron servo tonight. So the wing is pretty much finished besides making the mountings to attach it to the fuselage.
The next item will be to install the motor and cowl.
Old Jun 17, 2012, 08:04 AM
QuAd FaNaTiC
Canada
Joined Aug 2009
Looks damn good sir!
Question Balsa sheeting foam core wings vs just glassing. erh7771 Scratchbuilt EDFs 74 Mar 14, 2016 10:40 PM
Discussion Making 3" foam sheet out of two thinner sheets? bugdude The Builders Workshop 12 Jun 03, 2012 11:49 AM
Discussion one sheet dollar tree foam board flying wing 63 nova The Builders Workshop 1 Mar 12, 2012 04:18 AM
Build Log OSSP (one sheet sport plane) ray foley Foamies (Scratchbuilt) 27 Feb 11, 2012 10:28 PM
Discussion Full 3d hot wire cut foam trainer/sport plane acdcrocks4 Foamies (Scratchbuilt) 3 Sep 20, 2011 06:11 PM
