Old May 30, 2012, 08:17 AM
stevo1957 is offline
Find More Posts by stevo1957
Australia, NSW, Baulkham Hills
Joined May 2004
Thunder Tiger Easy Trainer 40 conversion
Hi guys,
I'm in the process of researching what i will need to do for conversion of a Thunder Tiger Easy Trainer 40 to electric.
A big thanks to Scirocco who has already provided me with some valuable info via PM.
Thought I'd post some questions for the other experts though............
Regarding prop clearance.
I'd like to run a 12" prop with a Turnigy G46 670kv on 4S.
Measuring the existing clearance from the installed nitro engine, I have 18cm from centre shaft to ground.
If I fit a 12" prop, I will only have cearance of around 3cm (just over an inch.)
Is it possible to mount the electric motor higher up, so say the shaft is 1/2" above the position of the current shaft of the installed nitro engine? (Hope you follow) That way, I will have 1 1/2" clearance which I'm reading should be ok. (The runways at my flying fields are pretty good in terms of smoothness and level.)
Will this create any handling issues? I note the shaft of the nitro motor on the stock mount is slighty upwards from centre of the side of the fuse.
Appreciate your input.
Cheers,
Steve
stevo1957 is offline Find More Posts by stevo1957
Old May 30, 2012, 11:57 AM
Kimber is offline
Find More Posts by Kimber
Hobby King Hater
Kimber's Avatar
USA
Joined Mar 2005
It is similar to our Tower 40 trainer, but appears to be a couple pounds heavier.
We have a .32 size, 800kv on 4 cells. The plane is just under five pounds. With
an 11/6 we pull just over 500W and just over 10krpm. It flies with authority with
flights in the 12 minute range. The battery is a 5000mah BTW.
We did use one size lager wheels and adjusted the nose gear to the highest setting
we could.
We use a pod for the battery to minimize cutting on the air frame.
Battery change is quick and connecting it in from the back of the
wing so you are never in the area of the prop.
Kimber is offline Find More Posts by Kimber
Old May 30, 2012, 06:46 PM
Joined May 2004
Thanks Kimber.
I can probably get a little more height by adjusting the nose wheel a bit, but that would mean the front will be slightly higher than the rear.
With a tri landing gear setup, is this likely to be an issue? I'm thinking not seeing as some use a tail dragger config but would appreciate further advice.
Cheers,
Steve
Old May 30, 2012, 08:08 PM
Kimber is offline
Hobby King Hater
Kimber's Avatar
USA
Joined Mar 2005
Brad re-bent the main gear to make it sit level.
Old May 30, 2012, 09:27 PM
scirocco is online now
Find More Posts by scirocco
scirocco's Avatar
Australia, ACT, Kambah
Joined Feb 2001
Hi Steve,
with 3cm clearance on the 12" prop, I'd definitely stick with the original thrust line.
I'd still try it with the 12" prop before mucking around too much with the gear - a trike isn't going to have the noseover risk that a taildragger has. You can still keep the 1/2" or so you could get with a bigger nosewheel as a future option jic.
scirocco is online now Find More Posts by scirocco
Old May 30, 2012, 11:59 PM
Joined May 2004
Thanks Al,
I'l give the 12x8 prop a go first then.
I'm just about to order what I need for the conversion but note that Hobbyking have the Turnigy Plus 60A ESC's on backorder.
Can anyone recommend a good budget priced alternative that will do the job?
(I will be getting the G46 670kw Turnigy motor.)
Cheers,
Steve
Old May 31, 2012, 05:42 AM
scirocco's Avatar
Joined Feb 2001
Originally Posted by stevo1957 View Post
Thanks Al,
Cheers,
Steve
I really rate the Plush ESCs, especially the 40 and 60 that will handle 6S. Maybe you can split your order so you can get the motor installed while you wait for the Plush to come back into stock.
Old May 31, 2012, 06:08 AM
Joined May 2004
I tend to agree Al. The Plush ESC line get good reviews.
I'm in no screaming hurry to get the ocnversion done, so might just order everything and take my chances. They are a popular item at HK so hopefully will be restocked regularly.
Cheers,
Steve
Old Jun 01, 2012, 06:24 PM
scottie52 is offline
Find More Posts by scottie52
United States, PA, Sunbury
Joined Jul 2009
Kimber is the plane in the photo the one with a 60 in wingspan.
And if so what esc did you use?
scottie52 is offline Find More Posts by scottie52
Old Jun 01, 2012, 08:46 PM
Kimber is offline
Hobby King Hater
Kimber's Avatar
USA
Joined Mar 2005
62", Great Planes Silver Series 45A.
Full throttle is 31A.
Old Jun 02, 2012, 10:04 AM
Joined May 2004
Hi guys,
Regarding props........I note there are Master Airscrew Electric only props (MA1208NE) or APC 12x8 Thin Electric props.
I ordered a MA one from HK but these are on back order. Given it is now the only item in my order out of stock, I am thinking of getting them to remove it from the order, so the other items can be shipped.
If I do edit the order, I'll need to source another prop and was just wondering what the difference between the 2 brands is.
Alternatively, if anyone in Oz has one they'd like to sell, please let me know.
Cheers,
Steve
Old Jun 02, 2012, 11:30 AM
Kimber is offline
Hobby King Hater
Kimber's Avatar
USA
Joined Mar 2005
Correction, we have a 12/6 on our plane.
Old Jun 02, 2012, 06:37 PM
scirocco's Avatar
Joined Feb 2001
Hi guys,
Cheers,
Steve
In my observation of electric models, MA vs APC E is about 1 in 10. I haven't used MA, but I know the APC works well. If it were my order, especially holding it up, I'd remove it and pick up an APC locally.
Old Jun 03, 2012, 05:04 AM
scottc39 is online now
Find More Posts by scottc39
scottc39's Avatar
USA, MN, Shakopee
Joined Sep 2004
http://www.hobbypartz.com/60p-dye-1015-60a-esc.html
this esc from hobbypartz is the same as the plush and uses the same program card to, i use three of them.
larger wheels will give you more clearenc if you dont have 3" wheels now.
scottc39 is online now Find More Posts by scottc39
Old Jun 03, 2012, 08:14 AM
Joined May 2004
Thanks for the info Scott.
The Turnigy Plush is actually backin stock and on its way to me.
Thanks for the link though - I haven't seen that online shop before. They sell at reasonable prices by the look of things.
Cheers.
Steve
Build Log Thunder Tiger Trainer 40 vdubin64 Beginner Training Area (Fuel) 22 Aug 08, 2012 10:31 PM
For Sale Thunder Tiger-Tiger Trainer-Kit nice New in box still t.korb Aircraft - Electric - Airplanes (FS/W) 3 Feb 26, 2012 09:50 AM
For Sale Thunder Tiger-Tiger Trainer-Kit nice New in box still t.korb Aircraft - Fuel - Airplanes (FS/W) 0 Feb 13, 2012 11:02 AM
For Sale Thunder Tiger-Tiger Trainer-Kit nice New in box still t.korb Aircraft - Fuel - Airplanes (FS/W) 0 Feb 06, 2012 01:03 PM
