What is the main shaft of the Helios made of? Titanium? I opted for drilling a second hole where the gear is located, a little higher than the current one, so the gear would sit a fraction higher on the shaft, thus reducing the almost 1 mm play I had on the main shaft. Despite using a new drill, I was only able to make a small pit in the shaft, not drill through and through. The pit is deep enough for the screw in the gear to get a "lock" so it works, but I was not expecting it would take so much effort to make a tiny hole.
It was worth it though, with the reduced play the heli handles much less "rocky" when touching the cyclic. I hope to be able to test outside soon if it also helps with the handling there. Btw, mine has a good punch on the throttle, so I don't see the need for a stronger motor. What might cause the heli to descend when "mocking" about could be the swash binding with the main shaft, as the servos have almost insane throws on "CH2" mode, or full rates. A stronger motor will not really help then. |
Latest blog entry: Vintage Kyosho Buggies, why I love 'em...
I think your comparison is quite spot on. Though the Helios is somewhat smooth, but the touchy rudder does make it a little harder to fly, the rocking/porpoising makes it appear less smooth, and on mine at least, the throttle is also a little jumpy, it's hard to find a setting where the heli will keep steady altitude. The 270 is very smooth. And with a minor mod, replacing the receiver for the 260's version, will be much less "mellow". It's a shame the 270 is still quite expensive for it's class, and replacement parts are not the quality you would expect for the price. If not, it would have been the best entry level heli, as it's so smooth, even close to the ground, when in ground-effect, making landings and take offs, the things beginners struggle most with, much easier.
Btw, does the Helios package come with 2 spare links, or just one? I got with mine a spare tail blade, screw driver, 2 spare main blades, and one link. |
Same would apply to the 9958, with some practice you can get around some of it's handling traits, but also not fully reduce them. There is a fine line between challenge and ease of use. No doubt a car that wants to constantly go left is a challenge to keep on the right track, but is it fun for everyone?
![]() Some will find the Helios more interesting due to that, others will see it as a flaw. And both are right, I think. Btw, I get the impression the rocking got less when I reduced the play on the main shaft, so perhaps there is hope. |
Just completed a first full flight indoor, after fixing the play on the main shaft and perfectioning trim for good hands free hover. Rocking was indeed much less present. I was able to do smooth circuits at several different speeds, including quite slow. The heli was easy to move around and was very "point and shoot" now. Landings also went fine, not as solid as the 270, but managable. Take offs are a bit rough, the little "bumps" under the left skid don't seem to give it enough sideways angle to assure straight take off.
The throttle curve could be better, even with some practice it's hard to keep the heli at steady altitude. The tail is twitchy, although not as bad as the first version Trex100, so it might partially solved by some getting used to. I like that the TX has voltage indicator for the battery, buy why no numbers for the throttle percentage instead of that graphic indicator, which is much harder to judge? I know I won't be constantly looking at it, but throttle percentage can help with judging a fading main motor, or bad battery. This throttle "gauge" helps little there. So far I don't regret getting one, I hope to be able to test it outside again soon, now that it's well trimmed, and with zero play on the main shaft. |
United Kingdom, England, Redcar
Joined Jan 2006
Quantification ( real word ? lol ) is personal and judged on your own personal experience and skill level and all should be accepted as correct ( to a point of course)
The car analogy is wrong as what the example points to as a lack of experience on the drivers part , the correct analogy would be that during driving the car accelerates randomly ( the purpoising effect for sake of argument ) or randomly accelerates or slows down or its back end slips during turning , if any of those happened on a new car you would return it to the dealership , if those same problems occured on multiple models the manufacturer would force a recall of the problematic model. "WE" have multiple problems across the same model , the twitchy tail is an issue and whoever flew this previously before accepting the model for manufacture should be sacked. The porpoising and some of the other issues 'may' be hardware related and fixable by the end user but realistically why should they ? these issues should have been sorted at the source , for sake of argument i think James had these models and issues were supposed to be resolved before manufacture , they obviously werent. Putting it into perspective , my personal experience is 6ch helis and downwards along with planes and quads , now i have on my Helios some seriously pathetic issues that you would expect to find 5 years ago on the budget helis , today we have moved forwards and should not accept these type of issues especially after mass production has started. |
Comparing the Helios to a Lambo or Ferrari is giving it too much credit. These are high performance cars, that require proper training before someone can get behind the wheel with confidence. I would consider at least a 6 channel when talking about a"Ferrari-class". The Helios is considered much more entry level with it's 45 degree flybar design. It doesn't porpoise because of bad stick movements or a bad pilot. It's because the heli responds different to stick movements than most helis in the same class. You can adjust to that, no doubt, but you have to understand no everyone is willing to adjust to something that is not present in most similar helis on the market. Btw, I still haven't heard an answer to my question if people that are having much porpoising have checked the play on the main shaft. I might be a link in the chain amplifying the effect. As I stated before, I get the impression my Helios responds much smoother after reducing the about 1 mm play, and as a result is now much easier to fly, at least inside, as I don't have to work around any rocking any more. It just follows my commands. |
My current ranking: #1 Solo Pro 260 or 270 (can't decide which one, the 260 screams outside in both speed and agility, the 270 is so smooth and is much better inside although it can handle a breeze better than the 260) #2 Bravo SX, with it's great looks and decent speed. Short flight times and being noisier cost it some points, which explains second place #3 Helios 100. Has to prove itself outside, but first results, after reducing play on main shaft, look promising #4 9958. Lovely heli to make "roller coaster passes" outside. Inside it boasts good handling on landing and take off, only surpassed by the 270, but it's less direct, and lacks throw. #5 Trex100s (first version). Almost impossible to get rid of TBE, tail hold is weak, and very fragile canopy. Very smooth sounding though, and well built. But only the second version (100x) seems to be worthy of the Align pedigree. 100s is best left as shelf queen, or converted to x-spec. |
Joined Jan 2006
Tried a small collared washer that i found in my spares box , still the same issue.
I dont think that the issue is mechanical i am starting to think that most of the problems are power related ie bad power management between motor and servos, only one real way to find out and that is swap the board with one from one of my v911's and see what happens, that will have to wait for now though. |
| Thread Tools | |
| Build Log helios build thread | krikkens | Hand Launch | 66 | Oct 24, 2012 08:28 PM |
| For Sale Helios DLG kits | Wave Glider | Aircraft - Sailplanes (FS/W) | 1 | Mar 06, 2012 10:09 PM |
| Discussion FW5 Vs. Helios DLG Launching Sound | Beetle-Jet | Hand Launch | 20 | Jan 09, 2012 01:12 AM |
| Sold Helios 90e pattern ship NIB | tommy s | Aircraft - Electric - Airplanes (FS/W) | 3 | Nov 24, 2011 10:25 PM |
| Sold Hyperion Helios 90 | flyingtomg | Aircraft - Electric - Airplanes (FS/W) | 5 | Sep 15, 2011 09:04 AM |
