Thanks for the review, Flyingboats. I'm considering getting one and dropping a V911 RX into it. I like having the variety of canopy colors and I like having the variety in flying performance.
Latest blog entry: Fitting a Bravo SX fuselage to a GW 9958...
Finally received my Helios from BG. According to the manual the USB charger light will be off when the battery is full, but mine goes straight off when I connect the battieries. Does Benma ship these helis with lipos fully charged? I thought these always came at storage voltage, 3,85 volt.
Latest blog entry: Vintage Kyosho Buggies, why I love 'em...
Ah, classic case of manual vs reality.
Had my first flights, very twitchy rudder. It is possible to turn smooth but hard as the sticks provide little feedback. On forward flight there is tendency to slide right as well, adding some left trim helps, but it seems odd, as the handsfree hover was ok before adding left trim. I can see the rocking/porpoising people mentioned, it's indeed quite pronounced. No wonder as the heli is quite tail heavy. Did someone already experiment with a shorter tail? As adding weight in the nose seems like a real no-no on an already heavy (relatively seen) heli. It really likes to pick up speed in a turn, and as such reminds me of the roller-coaster like flying the 9958 does. I tried full thows, but these are insane for such a simple transmitter, with no expo and other control adaptation options. I might see what happens if I move the control rods to the inner holes on the servo arms, while still selecting high rates. Might be a usable compromise between more throw than "beginner mode" but the twitchy full rate mode. |
My theory is that is due to a heavy flybar, so shortening the tail may not help, but if you are willing to experiment, please keep us posted.
I thought the paddles are not that heavy, and perhaps even lighter than a flybar with just weights? Or am I wrong?
I also like it when a heli can stop well, but it looks a little odd to see the heli behave like an invisible string is holding it and has it rocking back and forth on nearly every stick input. I know the odd behavior that 45 degree flybar systems can have, but haven't seen one behave like this. Especially not after flying the Solo Pro 270, which has ultra smooth response. |
Joined Sep 2012
Btw, why does the TX use a fake antenna, when it only makes it less convenient the store it? If it really has no function at all, except make ik look like a more capable TX, I think it will come off pretty soon...
![]() Just finished trimming mine out, it really needed some adjusting. After that it does a decent handsfree hover. Just a thought, but the main blades on mine are curved downwards a little, instead of coning upwards. Could that explain the rocking? A little V-shape coning adds to a heli's stability, but the Helios has inverted V when seen from the side. And how common is a mm of play on the main shaft? Seems like the holes are drilled not precisely, I think I will turn the gear 90 degrees, then drill a new hole. Too much play on the main shaft could explain the right sideways tracking when giving forward elevator, and perhaps also the rocking as the shaft slides up and down on cyclic input... |
Another flight with my Helios with v911 rx and msr paddles. It may or may not be evident in the video, but the Helios is eager to move once you give an input, but still can change direction quickly when you want to. I think the only thing missing is a more powerful motor, I may put in a SP 270 motor and see.
| Thread Tools | |
| Build Log helios build thread | krikkens | Hand Launch | 66 | Oct 24, 2012 08:28 PM |
| For Sale Helios DLG kits | Wave Glider | Aircraft - Sailplanes (FS/W) | 1 | Mar 06, 2012 10:09 PM |
| Discussion FW5 Vs. Helios DLG Launching Sound | Beetle-Jet | Hand Launch | 20 | Jan 09, 2012 01:12 AM |
| Sold Helios 90e pattern ship NIB | tommy s | Aircraft - Electric - Airplanes (FS/W) | 3 | Nov 24, 2011 10:25 PM |
| Sold Hyperion Helios 90 | flyingtomg | Aircraft - Electric - Airplanes (FS/W) | 5 | Sep 15, 2011 09:04 AM |
