Old May 30, 2012, 12:40 AM
depronair is offline
Find More Posts by depronair
Sittin' on my hands
depronair's Avatar
United States, WA, Seattle
Joined Jan 2005
What are the specific challenges that come with building and flying airliners?
I read in the scale forum a thread that was entitled "what is scale flying?" and there was alot of good discussion about level of detail in the build, philosophy, and how flying scale is every bit as important as the build itself..
Im currently building an aircraft in CAD with plans to scratchbuild a 'liner after seeing so many awesome scratchbuilds on here. I can't help but notice after reading some build threads and watching some youtube vids, that there just seems to be certain problems and solutions for airliners and large transport. (trying to emulate slow graceful flight from a high wingload, dealing with instability, how to make one appear to fly like a 200 ton machine vs a rolly and tippy foam tube, etc)
And Id like to know what type of sacrifices you guys can tolerate to make on a build to help make it fly more scale-like...
Alright, discuss! Hopefully this will help generate a list of techniques to help us all build better flying airliners.. pooling info into one thread.. etc..
depronair is offline Find More Posts by depronair
Old May 30, 2012, 04:06 AM
Keenan smith is offline
Find More Posts by Keenan smith
was geht , müssen unten kommen
Keenan smith's Avatar
United Kingdom, London
Joined Dec 2010
Me and airbuzz sacrifice some Strength to Build our planes light
Pros: Light wing loading and scale like apperance in the air and the ability to use less powerful cheaper Power systems (take Olles A340 for example he used GWS Brushed EDF75's)
Cons: there has to be almost no Wind to fly and the planes tned to be more vunerable to hangar Rash and usually end up becoming a Hangar Queen
Keenan...
Keenan smith is offline Find More Posts by Keenan smith
Old May 31, 2012, 07:56 PM
payne9999 is offline
Find More Posts by payne9999
Balsa&Tissue
payne9999's Avatar
United States, OR, Beaverton
Joined Jan 2011
I have an extremely lightly loaded 80" DC-6B and it can be flown very scale like. The problem is the wind. A heavier version would be fine though as larger planes can tolerate a higher wing loading. It depends on the size you want to build and how much weight is just right.
The thing about liners and any multi-motor plane is you have to be good with your left hand. These planes fly by their throttles (more like real planes) and not elevator. They very often require good rudder control (coordinated turns). On my Six I use throttle to control ascent and descent and elevator only for minor corrections and at the very end as the wheels are about to touch the elevator stick comes way back (slight flare). Multi-motor planes will teach you throttle management unless you already learned it from a really twitchy tip stalling warbird.
Dave
payne9999 is offline Find More Posts by payne9999
Old May 31, 2012, 08:44 PM
demondriver is offline
Find More Posts by demondriver
Up-Out-&-Gone
demondriver's Avatar
United States, SC, Charleston
Joined Mar 2007
Hi Depron-Air Both Keenan & Dave are right on the money! Airliner & cargo planes is designed to fly like any other aircraft it's just the overall design does no lend itself to aerobatics or really tight turns but other than that how you build & fly your airliner is up to you, the 6 most important factors to building a sucessfull RC airliner Are:
1 Correct CG location
2 A good airfoyle design for the wings
3 weight AKA light weight
4 control surface travel
5 enough thrust aka proper EDFs ESC's & batteries
6 structural strenght
7 scale design (trying to match the real thing)
if you stick to these rules you can do no wrong!
demondriver is offline Find More Posts by demondriver
Old Jun 01, 2012, 04:16 AM
MrADT is offline
Find More Posts by MrADT
Scope Creep Specialist
MrADT's Avatar
Joined Jul 2011
Originally Posted by demondriver View Post
if you stick to these rules you can do wrong!
You mean no wrong?
MrADT is offline Find More Posts by MrADT
Old Jun 01, 2012, 06:12 AM
Up-Out-&-Gone
Joined Mar 2007
Originally Posted by MrADT View Post
You mean no wrong?
Ha-Lol Thanks Boss!
Latest blog entry: Foam Safe Spray paint!
Old Jun 01, 2012, 01:09 PM
Sittin' on my hands
depronair's Avatar
Joined Jan 2005
Haha, good stuff..
Payne- your 6 is amazing! It flies like its a much larger machine than it really is.
K, yup, building light to allow use of lower power systems is beneficial.. Neffwaffe's airliners teach us all about the benefits of "light"
DD- Sir, I learn from all your vids.
You mean no wrong?
Ha-Lol Thanks Boss!
Rofl! DD, you should be a super hero named Captain Airliner
Old Jun 01, 2012, 01:17 PM
Sittin' on my hands
depronair's Avatar
Joined Jan 2005
Im totally with everyone that says airliners need to be built light, but I have a few other ideas/concerns that I personally would like to experiment with and tune into an aircraft when it comes time to construct one:
- ability to rotate slowly - if that means larger elevators so they can become effective before stall speed, its a scale sacrifice Im willing to make.. And of course delicate throttle usage helps this.. Jamming the stick to 100% probably wouldnt help acheive slow rotations..
- slightly rounder than scale leading edge - for higher AOA to help with nose high flares and being able to rotate the nose for a distance before mains leave the ground
-thicker airfoil at wingtips - for more effective lift at the tips, creating stability (winglets will help mask the thick airfoil at the tips)
- 3axis gyros to help keep rock solid attitude during climbs, turns and descents.. to help combat the dreaded foamy dance when there is slight gust
Of course these are all just goals and theories at the moment. If some of these ideas seem "lofty" please tell me what you think.
Old Jun 01, 2012, 03:07 PM
Balsa&Tissue
payne9999's Avatar
Joined Jan 2011
You hardly need elevator to rotate. As soon as the plane gets to a sufficient airspeed it will just take a bump of elevator to initiate a climb. Look at the videos of my six, it climbs too steeply. Once it gets to flying speed I just tap the elevator with a little "up" and once it initiates a climb I am at neutral elevator. If I want to climb slower I have to reduce throttle and feed in some down. My six has a fairly scale elevator and it is too much. I use about half stick on the elevator to make a last second stall on landing right before the wheels touch but that is the only time I use that much stick. In fact I have a fair amount of expo on the elevator to prevent porpoising. Some planes are different but I think a scale elevator will suffice in most cases.
Except with certain jet liners higher angles of attack are probably not needed either. On big heavy full size jetliners they do this so the AOA is high enough to fly level (maintain lift) and keep the nose level so the pilots are not looking up into the sky instead of where they are going. Most heavy aircraft are made this way. With my six it is just 2 degrees and the only time it flies nose up is when intentionally climbing or on the last bit of final approach. The full size DC-6 has 6 degrees of positive wing incidence.
The Concorde is a good example of a plane that needs high AOA in order to fly slowly enough to land. During normal flight (cruise) the nose/cockpit is in a normal position. During landing they had to design the nose/cockpit area so it could droop down just so the pilots could see. A light model of this plane would probably fly a little nose high on approach but probably not as severely as the full size plane.
A well made light liner does not really need gyros unless your area of flying is notorious for gusty winds. Scale may be a factor though because bigger planes can handle heavier wing loading and more wind. Park flyer sizes will be much more difficult to fly on a breezy day. My original DC-6 is 60" wingspan and 32 ounces (ready to fly weight), by these specifications it is a park flyer. My current DC_6 is 80" and 76 ounces and can handle the wind OK.
Dave
Old Jun 01, 2012, 03:53 PM
Ottopilot is offline
Find More Posts by Ottopilot
Cheatlines are mandatory
Ottopilot's Avatar
Seattle, WA
Joined Aug 2010
The idea behind the large elevator is to become effective before the wings- to raise the nose first... The idea is so that it doesnt lift off right away- I want the nose to lift off the ground and stay there for a stretch before the mains lift off- like a real airliner. And this is where perhaps a rounder leading edge might help too.
I agree that gyros are not needed, but the key phase where I think they are needed is near stall- the point where many rc model airliners get very tippy.
Edit: sorry this is my other account
Ottopilot is offline Find More Posts by Ottopilot
Old Jun 01, 2012, 06:02 PM
Joined Dec 2010
thicker tip foil is a no no and trying to disguise it with a winglet will make it look worse!
Kind regards
the Overly scale purist...
Old Jun 01, 2012, 07:49 PM
Up-Out-&-Gone
Joined Mar 2007
Haha, good stuff..
Thanks Payne! More Like Captain Moron . . . . . . . .More "ON" than Off LMAO!
Old Jun 03, 2012, 11:32 AM
MrADT is offline
MrADT's Avatar
Joined Jul 2011
Ha-Lol Thanks Boss!
Any time.
I agree that this type of takeoff would look more scale, but as others have said, you can use less elevator, which is probably a better plan than making a non-scale elevator, if scale looks are what you're concerned about.
Old Jun 03, 2012, 11:35 AM
Joined Dec 2010
BTW im offering up my cad work...
Old Jun 04, 2012, 05:51 PM
Joined Dec 2010
ohh and another advantage of light weight airliners is the need for a throttle Jokey approach is mitigated
For Sale More are already Here...THE ENGINES ARE COMING! THE ENGINES ARE COMING! wifeswarrior Aircraft - Fuel - Engines and Accessories (FS/W) 8 Jul 28, 2012 11:01 AM
Question Question about AR500 rx that comes with PZ Corsair (Corsair now comes with the AR600) njsnel Radios 15 Mar 12, 2012 06:11 AM
Discussion I just saw that ad with a jet airliner landing its nose wheel in a Nissan truck bed. Miami Mike Chit Chat 11 Oct 28, 2011 07:41 AM
Help! What are these that came with the HK 929MG servo? jsec1992 Electric Plane Talk 6 Oct 19, 2011 03:05 AM
Discussion What are the stick on velcro strips that came with my lipo for? Skalek Batteries and Chargers 1 Sep 16, 2011 03:11 PM
