Old Jun 18, 2012, 08:57 PM
UAVJOE is offline
Find More Posts by UAVJOE
Sr. Ext. UAS Pilot, NMSU FTC
UAVJOE's Avatar
United States, NM, Las Cruces
Joined Feb 2012
Sunday I had a bit of trouble attempting to launch the plane. I tried the hand launch via the leading edge toss. however, it was my first attempt launching a plane with out a fuse and no luck. It cartwheeled and broke the motor mount off. I will get it glued and I will try again next time with a home built catapult system. I will go over the design and build of it in 2 weeks I will be away for work for 2 weeks so the project is on hold.
UAVJOE is offline Find More Posts by UAVJOE
Old Jun 18, 2012, 09:10 PM
pheonix3 is offline
Find More Posts by pheonix3
Perth, Western Australia
Joined Jun 2009
Hiya Joe,
bad luck on the maiden launch... :-( I'm sure you'll have it up a flying again. I would consider that it's weight would make it a very fast flying plane and quite difficult to launch. A catapult should do wonders. With the wingloading you report, I would recommend hand launching...
Good luck with the next round of testing. I'll keep an eye on your progress here, as I am potentially interested in this airframe for a UAV also.
Cheers
Matt
pheonix3 is offline Find More Posts by pheonix3
Old Jul 02, 2012, 12:44 AM
ECODRONES is offline
Find More Posts by ECODRONES
UAV Operator
ECODRONES's Avatar
Brazil, SP, Caraguatatuba
Joined Jun 2012
Hi,
Good work, congrats!
I'm from Brazil, and planing build a wing (like Zagi 1500mm), to some test with imagery and FPV. I would like know which model of Cam, do you planing take images from terrain?
Maybe I will do a worklog of my buiding, will see...
Thanks in advance, best regards.
P.S. sorry my poor english....
ECODRONES is offline Find More Posts by ECODRONES
Old Jul 02, 2012, 06:23 AM
perelo is offline
Find More Posts by perelo
Sweden, Dalarna County, Mora
Joined Oct 2010
@So_Bad
I would recommend the Canon Powershot S100, a small, lightweight camera with good performance.
//Per, Sweden
perelo is offline Find More Posts by perelo
Old Jul 02, 2012, 07:19 AM
UAV Operator
ECODRONES's Avatar
Joined Jun 2012
Originally Posted by perelo View Post
@So_Bad
//Per, Sweden
Thanks, Perelo.
I need a good Cam, lightweight, good lens, and that had firmware MOD to it. Because I could to set shooting interval, etc. I will read about this Canon S100.
Does anyone know whic camera Sensefly and Gatewing X100, are using? In these UAV camera and the GPS are connected? I do not understand how pictures are get cordinates if it's not connected.
Thanks!
Old Jul 02, 2012, 07:53 AM
perelo is offline
Joined Oct 2010
Gatewing= Ricoh GR 5
Sensefly= Canon IXUS 220 HS
Last edited by perelo; Jul 03, 2012 at 04:06 PM. Reason: Looked up the Canon camera
Old Jul 02, 2012, 09:18 AM
UAVJOE is offline
UAVJOE's Avatar
Joined Feb 2012
I have an older model Canon Elf Power shot. It has a 10MP res.
I have been away on business and I will be getting the repairs completed this week some time and also completing the construction of my launcher. I have received my bungee cord and all I need to do is build the rail system. I will let you all know as soon as I get more work completed on it.
Old Jul 03, 2012, 02:58 AM
aForcefulThrust is offline
Find More Posts by aForcefulThrust
aForcefulThrust's Avatar
United States, LA, New Orleans
Joined Jun 2012
Wow this plane really looks amazing! I'm building a hexa right now, also using a 1w booster on my 2.4 for it. This really makes me want to get an airplane too haha. Best of luck to your catapult launch system!
aForcefulThrust is offline Find More Posts by aForcefulThrust
Old Jul 09, 2012, 08:01 AM
UAVJOE is offline
UAVJOE's Avatar
Joined Feb 2012
Well, I just completed my Catapult system for flying wings. I will test it out next week end. I is 5 ft long. I hope it slings the plane into the air for me.
I am using 3 bungees attached to a shuttle. It then goes around pulleys and then down to the bottom of the launcher. Here are some pictures.
Old Jul 09, 2012, 09:56 PM
UAV Operator
ECODRONES's Avatar
Joined Jun 2012
Thanks Perelo and UAVJOE.
Well, I will trying first pics, with my Nikon S3100. To do some images test.
Anyone has expertyse about Cameras? It's my Nikon is good?
Here specs: http://tinyurl.com/7qmu4eq
Thanks!
Old Jul 09, 2012, 10:00 PM
UAV Operator
ECODRONES's Avatar
Joined Jun 2012
Nice job JOE. Your work with PVC pipes, inspired me to make a stand for supporting my plane when working on it in the workshop.
Thanks!
Old Jul 10, 2012, 09:45 PM
Meez is offline
Find More Posts by Meez
3D Crazy
Meez's Avatar
Putrajaya, Malaysia
Joined May 2010
Ptreyx using Canon S90 and S95.
Cropcam using Pentax W90.
Thanks for the info on Gatewing and Sensefly camera.
Meez is offline Find More Posts by Meez
Old Jul 11, 2012, 12:21 PM
Tom Harper is offline
Find More Posts by Tom Harper
Lift is cheap - Drag sucks
Tom Harper's Avatar
Socorro, NM
Joined Jul 2004
Joe,
Launcher looks great - does it work?
Tom
Tom Harper is offline Find More Posts by Tom Harper
Old Jul 11, 2012, 01:34 PM
UAVJOE is offline
UAVJOE's Avatar
Joined Feb 2012
I moves but I have not tested it with a plane yet. I will be heading to the flying field this weekend if the weather gets better.
I will report back.
Originally Posted by Tom Harper View Post
Joe,
Tom
Old Jul 13, 2012, 09:22 PM
saabguyspg is offline
Find More Posts by saabguyspg
saabguyspg's Avatar
Calgary Canada
Joined Jun 2006
H everyone I am trying to use a canon hs300 on my x5 airplane but can not for the life of me get a non blurred picture
I turned off the stabilization in the camera
Cranked up the Iso
I can see the screen go blurry and actually gets jello while in ground tests
I have balanced the prop and removed the folder
I never had this issue with the Pentax optio 90 because it's a fixed lens
My question is "if these extending barrel cams are so sensitive why do these companies use them?"
Or is there something I am missing?
saabguyspg is offline Find More Posts by saabguyspg
Build Log x5 flying wing from bevrc.com (maiden video on page 1) saucisse FPV Talk 443 Mar 26, 2016 06:49 AM
Whoops! Anyone need something from BEVRC.com flyandi Trader Talk 1 May 11, 2012 05:29 PM
Discussion Is it just me or the bevrc.com is blanked? I wanna get a X8 wing!! tpnitro FPV Talk 8 Apr 03, 2012 11:14 AM
Sold "BNF" BEVRC SkyWalker v5.1 - $175 nk4787 FPV Equipment (FS/W) 2 Mar 21, 2012 01:04 PM
Discussion Skywalker V5 from Bevrc wootenelli Power Systems 0 Dec 15, 2011 10:00 PM
