Old May 29, 2012, 11:06 PM
Kahnx is online now
Find More Posts by Kahnx
Registered DSer
Kahnx's Avatar
Australia, VIC, Hadfield
Joined Mar 2003
How do I modify the trainer switch for Head tracking on Futaba TX?
I recently bought a used Futaba 10CG to get the extra channels I need for P&T head tracking using FatShark Dominator goggles. I will direct solder a Dragonlink TX to the internal pins on the TX circuit board, leaving the trainer port free for inserting the trainer cable to the Fatsharks.
The trainer switch is spring loaded, and the trainer function is not software re-assignable AFAIK. The circuit board under the switch has both the trainer, and the adjacent switch attached to it, so I cant easily/simply swap it over for a non-spring-loaded one.
So my question is: How have others implemented Fatshark head tracking on a Futaba TX with a Dragonink fitted?
At worst/simplest case I could simply rig up some sort of mechanism (elastic band) to hold the trainer switch in position, but I'm sure that there must me more elegant solutions out there.
Any suggestions, experiences, pics welcome.
Roger.
Kahnx is online now Find More Posts by Kahnx
Old Aug 02, 2012, 06:16 AM
subsonic is offline
Find More Posts by subsonic
If it's to be, it's up to me.
subsonic's Avatar
Sydney, Australia
Joined Jan 2007
Roger,
Did you ever figure out a solution for this? I'm setting up a HT for my 10C too, using the trainer port for input to the radio. The HT is only active when I hold the spring loaded s/w. Not exactly ideal
Sub.
subsonic is offline Find More Posts by subsonic
Old Aug 02, 2012, 06:51 AM
LKJ is offline
LKJ
Find More Posts by LKJ
LKJ
Lars k Jensen
Denmark, Central Denmark Region, Tostrup
Joined Apr 2006
I use F9 and i bought a switch from another Futaba radio and then did a little solder for change from PCB to PCB.
This one fitted my F9 its is sold out but i am sure you can find one from another dealer.
http://shop.lindinger.at/product_inf...ducts_id=89196
Lars
LKJ is offline Find More Posts by LKJ
Old Aug 02, 2012, 07:10 AM
subsonic is offline
subsonic's Avatar
Sydney, Australia
Joined Jan 2007
Hmm. I'm staring down an old Futaba radio on the shelf. Maybe I could rob a switch or two...
Seems a shame though. Dam thing should be assignable to any switch!
Old Aug 02, 2012, 01:22 PM
McCleary.11 is offline
Find More Posts by McCleary.11
McCleary.11's Avatar
United States, OH, Delaware
Joined Mar 2006
I use a rubber band on my 9cap to keep the trainer switch activated. It works well, but looks tacky!
McCleary.11 is offline Find More Posts by McCleary.11
Site Sponsor
Old Aug 03, 2012, 12:45 AM
typicalaimster is offline
Find More Posts by typicalaimster
typicalaimster's Avatar
United States, CA, San Diego
Joined Jan 2005
I ordered a switch from Tower Hobbies and swapped it out on my 7CAP. I've been told you can order the parts and send it in to Futaba and have them swap it out if you're not handy with a soldering iron.
typicalaimster is offline Find More Posts by typicalaimster
Old Aug 03, 2012, 12:59 AM
subsonic is offline
subsonic's Avatar
Sydney, Australia
Joined Jan 2007
My Ghetto solution.
Trouble with replacing it with a normal switch is that I really like the momentary one to use as a kill switch on my 50CC. It's much harder to accidenally kill the ign with a momentary switch because you get a second or so before the engine stops completely.
If I were so inclined, I'd probably just swap the two shoulder switches over, but till then, I'll see if I like how the zip tie works.
Discussion how do I add a on off switch Rhondas Power Systems 6 Apr 22, 2012 03:50 PM
Discussion How do I slow down on throttle/rudder/evelator trainer? AndrejaKo Beginner Training Area (Aircraft-Electric) 15 Mar 06, 2012 01:56 AM
Question How do i asign a switch for rate mode and hh mode on futaba 8fg? jcervantes11 Radios 9 Oct 31, 2010 10:10 AM
Question How to use a switch on Futaba tx to set up-trim for takeoff? Danny Troy Radios 8 Jun 16, 2007 10:35 PM
This is how to put throttle on trainer switch on futaba 9C tic High Performance 23 Jan 03, 2005 05:07 PM
