Old May 29, 2012, 01:25 PM
Joined May 2012
f35 VTOL vertical takeoff, straight flight, vertical landing
f35 VTOL vertical takeoff, transition to straight flight, vertical landing, Moreno Lippi, Florence, Italy
F 35 VERTICAL TAKE OFF (1 min 55 sec)
f35vertical is offline Find More Posts by f35vertical
Old May 29, 2012, 06:01 PM
v22chap's Avatar
Goshen, Indiana, United States
Joined Jan 2003
congratulations... looks like it flies pretty good for an airplane
Tell us more about what you use to control it .
v22chap is offline Find More Posts by v22chap
Old May 29, 2012, 07:10 PM
RCvertt's Avatar
Joined Aug 2007
Looks awesome!
Flight time?
RCvertt is offline Find More Posts by RCvertt
Old May 30, 2012, 06:58 AM
Winging it Ò>
leadfeather's Avatar
Joined May 2006
Congratulations! that is quite an accomplishment.
Please share details of how the jet is stabilized and controlled if you can.
leadfeather is offline Find More Posts by leadfeather
Latest blog entry: Quick Stick
Old May 31, 2012, 11:54 PM
RCvertt's Avatar
Joined Aug 2007
Old Jun 01, 2012, 05:43 PM
Joined May 2012
Thanks for the compliments, they are about 3 years that I'm working at VTOL. I followed various paths and configurations. This is the most simple and effective. Model f35 hobby king, hobby swang 68 mm fan rotating in 3 positions (horizontal, vertical and 45 degrees), 4-cell lipo 2250 Ryno, 8 servos, gws around 3, with batteries weight model 1050 grams, 1300 grams static thrust fan, radio tunirgy 9 channels, power consumption in hovering 55 amps, for a complete flight autonomy of translations, about 2.5 minutes. Moreno.
F35 VTOL CRASH (0 min 38 sec)
Old Jun 01, 2012, 06:26 PM
will3kgt's Avatar
Grand Blanc, MI
Joined Jan 2007
will3kgt is offline Find More Posts by will3kgt
Old Jun 01, 2012, 11:11 PM
RCvertt's Avatar
Joined Aug 2007
Great info and blooper reel. Thanks for sharing. Very respectable flight time. Your hard work has paid off.
Old Jun 02, 2012, 02:30 AM
Joined May 2012
I currently have 3 models in this spot, I try to travel with another smaller f35 harrier and fans that mounts 4 55 m. , Equipped with autopilot ARDUINO MULTI-WII
harrier primo volo hovering (0 min 57 sec)
Old Jun 02, 2012, 03:26 AM
Team30 Micro EDF
NitroCharged's Avatar
Adelaide, Australia
Joined Apr 2004
I'm loving it Moreno! Your work is paying off well!
NitroCharged is offline Find More Posts by NitroCharged
Old Jun 02, 2012, 07:01 AM
RCvertt's Avatar
Joined Aug 2007
You have a nice VTOL air force going on there.
... harrier and fans that mounts 4 55 m...
Really like that harrier you're building. Really cool to see the landing gear go up as it's hovering.
55mm fans units you say? I thought they might be at least 60mm.
What battery do you use for the Harrier. I'm guessing four 55mm fans at 50 amps each pull about 200 amps total
Have you had a chance to fly the harrier in forward flight conventionally yet? I would have thought the harrier would be easier to build than the F35 but you got the F35 flying really good first.
Keep up the good work!!!
Old Jun 02, 2012, 08:44 AM
Joined May 2012
I must point out: the f35 flying with a 68 mm. and takes 55 amps. the Harrier flies with 4 fans 55 and absorbs 26 amps each. flies with 2 packs of 4-cell 2250. the harrier weighs 1650 grams. The Harrier has not yet made the shift from vertical flight to horizontal flight. the conditions are good. I wonder if they are the first in the world to perform vertical takeoff, vertical landing straight flight model with a fan.
Moreno
Old Jun 02, 2012, 03:18 PM
RCvertt's Avatar
Joined Aug 2007
... the Harrier flies with 4 fans 55 and absorbs 26 amps each. flies with 2 packs of 4-cell 2250. the harrier weighs 1650 grams...
Sounds good.
Good luck with the transition attempt. When it makes it, it'll be the first electric one I know of. I have seen some come very close but not quite as smooth as what is being done with the Wii boards now.
But don't take to long. At 100$ they are practically giving that Harrier away on the HobbyKing site and I've always wanted to try flying a jet. Hmmm, where did I put that credit card...
Old Jun 02, 2012, 03:46 PM
max fox's Avatar
Joined Sep 2011
Hello Moreno, in my opinion, you are the first in the world to have completed the vertical takeoff, horizontal flight and vertical landing. This is the beginning of a new era, because most accomunerà aircraft lovers and those helicopters. Hello Massimo. P.S I think you will pass the story .....
max fox is offline Find More Posts by max fox
Old Jun 02, 2012, 05:30 PM
v22chap's Avatar
Joined Jan 2003
Moreno
Very cool harrier .. and yes I think you are the first with electric fan ... full scale bird to do VTOL ... some have done test bed birds ... but to do the full scale is the trick .
Keep them going .. and good luck with your work ,, keep us all posted
Discussion f35 vertical take off , vertical landing f35vertical Electric Ducted Fan Jet Talk 22 Oct 14, 2012 10:39 AM
Discussion f35 vertical take off , vertical landing f35vertical Electric Ducted Fan Jet Talk 13 Jun 21, 2012 03:13 PM
Discussion f35 vertical take off, vertical landing. f35vertical Electric Motor Design and Construction 6 May 30, 2012 03:20 AM
Question Throttle durring takeoff, flight, and landing rasterburn Beginner Training Area (Aircraft-Electric) 41 Mar 31, 2012 09:11 PM
Discussion My New RC HobbyZone Champ Flight Video-Takeoff to Landing newtorcplane Electric Plane Talk 5 Jan 22, 2012 04:25 PM
