Ok
Just making sure |
Latest blog entry: Estes Rubber Band Condor gets powered...
I am having issues interfacing the TX with software. I am doing what manual says but it keeps linking, then un linking. I also tried windows XP compatibility mode and no dice.
Any ideas? |
Pontiac/Auburn Hills, Michigan USA
Joined Dec 2008
![]() Max www.parkrcmodels.com www.skyartec-usa.com |
Set up 0 pitch at mid stick in idle up tonight; much better but gain is way too low. Need to adjust software but can't link up
Joined Dec 2008
Other than these ideas we don't have much more to offer on this issue. Computer software support is simply next to impossible without having the computer in hand or having a professional remote into your computer and configure it remotely. There are so many variables and conflicts from other hardware and software and device drivers that make support of computer issues using email problematic- again check with your dealer. Regards Max www.parkrcmodels.com www.skyartec-usa.com |
Joined Dec 2008
It flew okay tonight; it has 13 degrees of positive pitch out of the box - way too much
Joined Dec 2008
Thanks for all the help
I got in the software, updated, linked and it's writing to TX. Is the firmware update a good idea now? I see what you mean by the software settings I'll have to re adjust curves Ect Mine is Chinglish version I assume that (-) expo is actually softening around mid stick and not more aggressive like (-) is to specktrum My logic is that it came stock with (-) expo which would be odd for stock settings Also The gyro was at 30 in normal and 25 in reverse. The heli seemed like it was in rate mode which would make sense via the settings in software. I am assuming that reverse in the software is referring to idle up? Translation is off I think lol |
Anyone?
Joined Dec 2008
I suggest you load in the X3V.ini file from the defaultsettings folder, making sure to pick either Mode 2 or Mode 1 depending on your peference. This way you can start from the factory settings for all the tabs ( or if you made changes and want to go back to the original factory settings) The reason I mention this is that you must make sure you press the write button after you load in a config file.
Here is my advice that has served me well for such situations on firmware upgrades. If it isn't broke don't fix it. I haven't upgraded the firmware on my personal Tx because I don't seem to have any issues. The factory, will often get a slightly newer version the transmitter or the receiver unit with very minor changes to the chipset; then instead of changing out the complete Tx, it can just get a firmware upgrade. Also looking at the setup; I see no way of saving the older firmware settings; it is my policy that if I cannot go back to the original I don't upgrade unless everything else has failed This is just my opinion and of course the final decision is up to you; however I haven't received a notice from the factory that the upgrade to the firmware is mandatory.on the Sky706V series Regards Max www.parkrcmodels.com www.skyartec-usa.com |
Fair enough
Thanks |
Joined Dec 2008
Max www.parkrcmodels.com |
| Thread Tools | |
| New Product skyartec new flybarless video | skyartec | Micro Helis | 5 | Jul 20, 2012 12:52 AM |
| Discussion Skyartec wasp v3 | MADLOO | Electric Heli Talk | 5 | Feb 01, 2012 05:55 AM |
| Discussion Skyartec Wasp V4 Servo question | andione1983 | Electric Heli Talk | 1 | Nov 07, 2011 07:45 AM |
| Build Log My First CP Heli: WASP V3 by Skyartec | bobepine | Micro Helis | 80 | Sep 30, 2011 12:20 AM |
| FAQ How about SKYARTEC WASP-V1? | ryu0215 | Micro Helis | 3 | Aug 13, 2006 09:03 AM |
