Old May 29, 2012, 01:04 PM
TheBeastTamer is offline
Find More Posts by TheBeastTamer
Closed Account
Joined Jan 2012
Where to find nice good quality parkflier size short or full kits?
I am looking for some kits to build while it is windy and hot. I know of dave blum but already have a cessna 182 and getting a 185. Anyone know of other parkflier or smaller kits? If you have any for sale let me know. I like short kits and full kits. Need at least a short kit because I suck at cutting ribs and formers and all the nice shaped parts. Also how do you fix a bend in a fuselage(pic below).
TheBeastTamer is offline Find More Posts by TheBeastTamer
Old May 29, 2012, 01:20 PM
BMatthews is online now
Find More Posts by BMatthews
B for Bruce
BMatthews's Avatar
The 'Wack, BC, Canada
Joined Oct 2002
Stevens Aero has some really nice designs in their line of laser cut kits.
The offset is caused because your fuselage ends were not the same length. I know you don't want to hear it but the only way to fix this is to split the joint at the tail. With the joint cut apart line up the fuselage over the top view of the plan and force the sides to line up over the plan. One of the sides will stick out past the other. That is very much OK. You'll trim the long one back or leave things alone depending on how it all lines up when you add the tail surfaces.
When you do all this rear joint cut and pulling to line stuff up it is highly likely that some or all of the cross braces will snap their joints. In fact you'll likely need to do it anyway. Of course this means you'll need to reglue or make up new cross pieces to get good joints.
To avoid this for next time always "erect" the sides and join them over a top view of the plan or at least over a center line. And never expect the sides to join together perfectly at the tail post. The slightest amount of difference in length or misalignment at the central cabin assembly will create a mis-match in lengths at the tail post. Simply accept it and glue the posts together so they sit right over the centerline and are vertical. If you try to slide them to line up in any manner you end up with offset sides or the whole rear section having a twist. So accept centered and vertical and resort to sandpaper or shims to correct anything that is slightly out afterwards.
BMatthews is online now Find More Posts by BMatthews
Old May 29, 2012, 02:18 PM
DeeBee1 is offline
Find More Posts by DeeBee1
DeeBee1's Avatar
United Kingdom, England, Brighton
Joined Apr 2007
Both these manufacturers make some nice kits that are fairly quick to build while still requiring some care.
http://www.parkscalemodels.com/shop/
http://www.mountainmodels.com/
DeeBee1 is offline Find More Posts by DeeBee1
Old May 29, 2012, 09:04 PM
Nergall is online now
Find More Posts by Nergall
Nergall's Avatar
United States, GA, Lilburn
Joined Aug 2009
Seems like Park Flyer kits are easy to find.
Here's a couple more:
http://www.richuravitch.com/
http://www.patscustom-models.com/
What about the large scale kits?
Nergall is online now Find More Posts by Nergall
Old May 29, 2012, 09:12 PM
Closed Account
Joined Jan 2012
Thanks everyone. Im looking at the cheaper options. Im on a budget. Anyone have one for sale?
Old May 29, 2012, 09:24 PM
WAGliderGuy is online now
Find More Posts by WAGliderGuy
Airliner Builder
WAGliderGuy's Avatar
United States, WA, Seattle
Joined Feb 2010
http://www.hobbyhangar.com/
http://www.estarmodels.com/
http://manzanolaser.com/index.html
I highly recommend Pat Tritle's kits, I have built his Porter, C180 which fly fantastic and I am in the middle of building his 60'' DC-6B. Pat is always happy to help and he has a large line of models. They are so light that you could easily fly one of his many 1/8 scale 50-55'' offerings on a baseball diamond.
Ethan
WAGliderGuy is online now Find More Posts by WAGliderGuy
Old May 29, 2012, 09:28 PM
B for Bruce
BMatthews's Avatar
Joined Oct 2002
On a budget? Then it's simple. Learn to cut out your own parts accurately and build from downloaded plans.
It's not hard. And there's a few tricks. There's been at least 2 threads just about cutting out ribs accurately and other parts from plans in the last week or so.
Old Jun 20, 2012, 03:18 PM
DAVE GRABEN is offline
Find More Posts by DAVE GRABEN
DAVE GRABEN's Avatar
United States, TX, Rhome
Joined Jul 2005
Ethan
Are the folks at Hobby hangar still in business? I've tried email and the phone but don't get through
DAVE GRABEN is offline Find More Posts by DAVE GRABEN
Wanted full size servo with short casing rc4life85 Aircraft - General - Radio Equipment (FS/W) 0 May 25, 2012 12:44 AM
Sold No Longer Produced Global Tecate Biplane Kit NIB Nice Quality! $125.00 SHIPPED! stevster Aircraft - Fuel - Airplanes (FS/W) 6 Apr 30, 2012 08:43 PM
Wanted 4 or 8 Avroto 2814 Short Shaft or same quality motor... leoli0205 Aircraft - Electric - Multirotor (FS/W) 1 Mar 23, 2012 07:36 AM
Help! Where to find a magnetic balancer for props sized 13" or above? wizprod Multirotor Talk 5 Mar 06, 2012 09:55 AM
Found Wood Airplane kit, full or short kit, HOB, Tritle, Manzano, AerodromeRC (STILL LOOKIN mtdoramike Aircraft - Electric - Airplanes (FS/W) 10 Nov 19, 2010 04:27 PM
