Old May 29, 2012, 08:33 AM
WesMc is offline
Find More Posts by WesMc
WesMc's Avatar
United States, SC, Williamston
Joined Jan 2012
Question
spektrum dx8 telemetry setup...
Question: when hooking up telemetry, the unit plugs into the DATA/BATT port on the receiver, so then where do I plug in receiver battery?
WesMc is offline Find More Posts by WesMc
Old May 29, 2012, 08:45 AM
freechip is offline
Find More Posts by freechip
Surface, Air & Water Rc Toys..
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
You can always use ANY free port or if none are free then use a Y harness.
If you have a DSMX receiver then YES you want to connect the telemetry in the DATA port in order to get FLIGHT LOG information on the telemetry.
If you are using a DSM2 receiver without a DATA port but instead it's labeled BATT/BND you can still use that port for telemetry but it's recommended to remove the signal wire from the data cable as it may cause issues when powering on the system. System MAY go into bind mode.
freechip is offline Find More Posts by freechip
Old May 29, 2012, 08:48 AM
WesMc is offline
WesMc's Avatar
Joined Jan 2012
I have no empty port, so Y harness in DATA/BATT port?
Old May 29, 2012, 08:57 AM
AndyKunz is online now
Find More Posts by AndyKunz
AndyKunz's Avatar
Illinois
Joined Sep 2001
Correct.
AndyKunz is online now Find More Posts by AndyKunz
Site Sponsor
For Sale Spektrum DX8 w/Telemetry & TWO RX Amichai Aircraft - General - Radio Equipment (FS/W) 9 Nov 22, 2011 12:39 PM
Sold Spektrum TM1000 Telemetry system from DX8 set NEW! HD Hucker Aircraft - General - Radio Equipment (FS/W) 2 Oct 10, 2011 09:57 PM
Sold Spektrum Telemetry TM1000 for DX8 mmclaug858 Aircraft - General - Radio Equipment (FS/W) 2 Sep 25, 2011 04:40 PM
Sold Telemetry for Spektrum DX8 mmclaug858 Aircraft - General - Radio Equipment (FS/W) 3 Sep 19, 2011 07:59 PM
