Old Feb 12, 2013, 10:27 PM
1Eye is offline
Find More Posts by 1Eye
1Eye's Avatar
Cyprus, Limassol, Pareklisia
Joined Mar 2012
Flight vid L-59
As requested by pavcon:
HK L-59 Stumax fan 10s (5 min 34 sec)
1Eye is offline Find More Posts by 1Eye
Old Feb 14, 2013, 04:10 AM
urrl is offline
Find More Posts by urrl
In the pipe 5 by 5...
urrl's Avatar
United States, FL, Hollywood
Joined Aug 2010
L-59 total loss of control yesterday. Suddenly the motor and all servos failed.
L-59 near crash onto busy highway (2 min 7 sec)
urrl is offline Find More Posts by urrl
Old Feb 14, 2013, 11:57 AM
nerv is offline
Find More Posts by nerv
nerv's Avatar
Joined Jan 2007
wow, and it's heading down to the high way.....Good save!
nerv is offline Find More Posts by nerv
Old Feb 14, 2013, 01:24 PM
Anastasios is online now
Find More Posts by Anastasios
Joined Jun 2008
Originally Posted by vettster View Post
refer to the pictures on page 68 post 1006
I used the intake ring aswell but had to cut a flat spot so the hatch would close. The intake was inserted into the intake ring. Worked perfect.
A couple more pics on page 67.
My L-59 weight about 3.5kgr without batteries.My edf unit is an Extreme RC with Wemotec rotor , HET 700 size motor and with 8 cell Lipo produce 3.7 to 4kgr of thrust. The problem is that my 8cell 5000mAh 40C weight 1.1kgr with total weight 4.6kilos. I would not have any problem durring the flight as I would have 4 kilos of thrust but would It be heavy the jet at landing or not? If I use only the 6cell Lipo the model would weight about 290gr less but the thrust from 4kilos would reduced to 2.5kilos and I think that the jet would be underpowered. I am not going to change my HK Lipos to less mAh as I already have the 5000mAh Lipos and the cost for replace them is too high. Which is your jet weight ready for flight? Do you have to suggest anything about it?
Anastasios is online now Find More Posts by Anastasios
Old Feb 14, 2013, 01:52 PM
Joined Jun 2008
Originally Posted by urrl View Post
Do you know your total weight ready to fly ? I am asking you because my total weight is 4.6 kilos and I do not know if it is too much for this jet?
{My thrust is 4 kilos plus but I do not know if I have to go much faster for landing which would be a problem.}
Old Feb 14, 2013, 01:59 PM
urrl is offline
urrl's Avatar
Joined Aug 2010
I don't have a scale to weigh my jet but perhaps next I am at the hobby shop they will weigh it for me. I doubt it will be that unstable upon landing. The only thing you may need to worry about with that weight is do you have enough runway.
Old Feb 14, 2013, 03:48 PM
nerv is offline
nerv's Avatar
Joined Jan 2007
Mine with 6S 5300genace, wemo fan, ARC36-65-1 and a big heavy HW 150A opto ESC weighs 8lb12oz, or 3968g. The static thrust is not that much, around 5lb by pushing against the scale(probably not that accurate), but it flies fine with decent speed. I just took it out for a spin during lunch break after watching Urrl's video , my flying field is like 6min from my work.
Old Feb 14, 2013, 04:24 PM
urrl is offline
urrl's Avatar
Joined Aug 2010
Nerv have you posted any pics or videos yet?
Old Feb 14, 2013, 04:43 PM
nerv is offline
nerv's Avatar
Joined Jan 2007
Here are two pics I just took when I got home, my L-39 is just hiding in my trunk and ready for take off.
Here's my first flight sometime last year and also my first video on youtube : How NOT to land a jet, lol.
CMP L-39 first flight, and How NOT to land a jet :-) .MTS (3 min 51 sec)
Old Feb 15, 2013, 01:01 AM
Mannyman535 is offline
Find More Posts by Mannyman535
edf flyer
Mannyman535's Avatar
United States, CA, Marina
Joined Feb 2009
http://youtu.be/9HMB3P1IoMc
Call me next time. Ill come out to fly with u
Mannyman535 is offline Find More Posts by Mannyman535
Old Feb 15, 2013, 09:23 AM
Joined Jun 2008
How do you succeed only 3968g? I have an Extreme alloy-Wemotec fan with a HET 700 size 1680kv motor , Turnigy 120HV esc , Turnigy full metal retracts and HK 8cell 5000mAh 40C Lipos with a final weight of 4.8kg. The fan unit produced 3.7kg in the open and 2.9kg only inside the jet. I have lost 0.8kg of thrust and I could not find them. I do not know if 2.9kg of thrust are enough for a 4.8kg model.
Old Feb 15, 2013, 11:30 AM
nerv is offline
nerv's Avatar
Joined Jan 2007
Hey Manny, will you able to come out during lunch time? I found the best time to fly in Tomcats is around 12 to 2pm during weekdays. No air traffic, little wind, and sun is on your back.
Hey Anastasios, I actually consider mine a heavy 6s setup because of all the epoxy I dumped on the retract mount on the wing after the crash landing, probably weighs half pound lol..... I think yours should fly fine, the thrust is not the problem, it's the weight...Urrl has a good post on things you need to prepare for successful maiden, very useful.
Old Feb 15, 2013, 12:14 PM
Boostoman is offline
Find More Posts by Boostoman
Boostoman's Avatar
Oman, Masqat
Joined Apr 2010
thanks for sharing your vids. I would like to know what thrust/watts you are were flying with. Plus what retracts were you using.
thanks
Boostoman is offline Find More Posts by Boostoman
Old Feb 15, 2013, 01:21 PM
nerv is offline
nerv's Avatar
Joined Jan 2007
wemo 90mm, with arc36-65-1 6S 5300genace, around 2.25kw, and 5-6lb of thrust with all the ducting installed. The retracts are the original CMP retracts designed for this model, I don't see anybody sells them anymore...They are OK if you have nice run way, not OK for grass take off.
Old Feb 20, 2013, 06:39 AM
Joined Jun 2008
Originally Posted by Force10 View Post
Thank you everyone for your quick replies I really appreciate the support
Loopsy
My setup
HET -700-68-1400 Motor
Changesun 12 blade fan
YEP 120 amp ESC
2 X 4S 5000MAh battery ( 8cell Setup)
+AOA present using landing gear from HK which is recommended for this aircraft did not modify the LG in anyway so AOA should be ok spring in the nose gear is strong enough and bounces back.
Now after putting some though I think there could be 2 issues one is because the grass field is not level enough it bounces quite a bit and hence may be loosing speed that is required for takeoff, second I don't know but it feels like that power is not enough it makes quite a bit of noise but takes bit of effort even to start moving.Having said that i know this power combination has been used by quite a few people on this thread and is working fine
It just feels like there is something not right
Is it possible to tell me the weight of your L-59 ready to fly? I am asking you because mine with HET 700 68 1680kv motor , Extreme RC housing with Wemotec rotor , 8 cell 5000mAh HK Lipo and Turnigy full metal retracts weights 4.8 kilos and I think that it is heavy.
Sold Freewing L-39 Albatross BNF 85.00 radman615 Aircraft - Electric - Jets (FS/W) 2 Dec 07, 2011 09:48 PM
Help! Blitzworks Albatross 55mm L-39 Esc Programming manual anyone? fly_right Micro EDF Jets and Power Systems 1 Dec 05, 2011 07:20 AM
Sold Great Planes L-39 Albatross w/Battery and RX porcia83 Aircraft - Electric - Jets (FS/W) 10 Sep 18, 2011 08:44 PM
L-39 Albatross for 90mm fans Tim H. Electric Ducted Fan Jet Talk 24 Oct 14, 2002 07:42 AM
