Old Jan 10, 2013, 02:21 PM
urrl is offline
Find More Posts by urrl
In the pipe 5 by 5...
urrl's Avatar
United States, FL, Hollywood
Joined Aug 2010
Originally Posted by ditchit View Post
What's your 6S fan/motor combo Urrl?
It's a 5 blade ChangeSun fan with what I believe to be a 1900kv motor.
Came with the plug N play L-39 from here:
http://www.scaleflying.com/Aero-L-39...an_p_2523.html
Same type motor/fan combo I am using now in my L-59.
The 8S is a 6 blade fan, link here:
http://shop.rc-electric-jets.com/Wem...IDIHET1500.htm
I used the 8S in both the L-39 and the BAe Hawk
My CMP BAe Hawk Maiden Flight (2 min 0 sec)
CMP BAe Hawk (1 min 58 sec)
L-39 jet 8S speed test flight (0 min 37 sec)
urrl is offline Find More Posts by urrl
Old Jan 11, 2013, 01:58 AM
AdMan is offline
Find More Posts by AdMan
AdMan's Avatar
Australia, SA, Ingle Farm
Joined Feb 2010
Does anyone have somewhere in mind I might be able to get some nav lights for this baby? Is there a particular size I need and colours etc? Ive seen one set on HK but not sure if they will be long enough or are the correct lights for this model. Surely someone here has done the same thing with theirs!
Cant finish the wing off until Ive put the LEDs in.
Thanks!
AdMan is offline Find More Posts by AdMan
Old Jan 11, 2013, 02:06 AM
DominicM is offline
Find More Posts by DominicM
DominicM
DominicM's Avatar
Fleet, Hampshire, UK.
Joined May 2003
These are about as good as you can get in the wing. Fit perfectly.
http://www.hobbyking.com/hobbyking/s...dProduct=17189
Demo of mine here on a bright day...
Hobby King L59 lighting system test (0 min 50 sec)
DominicM is offline Find More Posts by DominicM
Old Jan 11, 2013, 02:13 AM
AdMan is offline
AdMan's Avatar
Joined Feb 2010
Wow they are amazingly bright considering the sun! All your lights come from HK?
Thanks for the quick reply.
Old Jan 11, 2013, 02:25 AM
DominicM is offline
DominicM
DominicM's Avatar
Joined May 2003
These are the other lights I am using. Haven't flown the model yet but I'm doubting they will be visible on a bright day. They are cheap though. Need to find a much bigger strobe really. Bit pointless unless they show up in flight if you ask me.
http://www.valley-electronics.co.uk/...?productID=968
Old Jan 11, 2013, 12:50 PM
urrl is offline
urrl's Avatar
Joined Aug 2010
I use these type day time strobes for my L-59
http://www.hobbyking.com/hobbyking/s...ght_Unit_.html
Hobbyking L-39 Lighting (0 min 58 sec)
I have 4 of the 12 set cluster LEDs for the "headlights" on the front wing tanks on order.
I don't want any lights that can't be seen at least on a cloudy day.
Old Jan 11, 2013, 08:42 PM
Force10 is offline
Find More Posts by Force10
Australia, NSW
Joined Mar 2011
http://www.youtube.com/watch?v=dYNpfwcLnPk
Urrl I have the same strobe lights but they don't seem to be that bright even in dark I'm using 1 cell battery to power it , how many cells are you using as yours seem to be bit brighter
Force10 is offline Find More Posts by Force10
Old Jan 11, 2013, 10:02 PM
urrl is offline
urrl's Avatar
Joined Aug 2010
For the Xenon daytime strobes I'm using a 3.7 volt 500mAh battery used in a 120SR heli
Old Jan 11, 2013, 10:18 PM
bwoollia is offline
Find More Posts by bwoollia
bwoollia's Avatar
United States, CO, Colorado Springs
Joined May 2008
It's funny, we all want super bright lights for our models but on the real thing they really aren't noticeable until nighttime!
bwoollia is offline Find More Posts by bwoollia
Site Sponsor
Latest blog entry: Crash Compilation
Old Jan 12, 2013, 04:37 AM
Anastasios is offline
Find More Posts by Anastasios
Joined Jun 2008
For power on my L-59 I use an extreme rc alloy EDF body , a HET 700 size 1680kv motor and a Wemotec Midi fan rotor. With 8 cell Lipo it produce 4 kilos plus of thrust. I am going to move the fan unit about 4cm forward but I have problem with the thrust line. The thrust line must be paraller with the line that connect the leading with the trailing edge of the wing or not? If I had fit the EDF unit in it's former position the thrust line would be upthrust and not paraller with the wing line. Is it right or wrong? Which would be the right thrust line of the EDF unit? As the unit it's lower than the inlet tube if I fit an inlet ring on the EDF body and make a gap between the inlet ring {lip} and the inlet tube about 3cm would I have any problem?
Anastasios is offline Find More Posts by Anastasios
Old Jan 12, 2013, 12:46 PM
vettster is offline
Find More Posts by vettster
"Take Off" eh!
vettster's Avatar
Canada, ON, Beeton
Joined Aug 2008
refer to the pictures on page 68 post 1006
I used the intake ring aswell but had to cut a flat spot so the hatch would close. The intake was inserted into the intake ring. Worked perfect.
A couple more pics on page 67.
vettster is offline Find More Posts by vettster
Old Jan 12, 2013, 05:32 PM
urrl is offline
urrl's Avatar
Joined Aug 2010
New L-59 body came in today. I must admit it was boxed well. No damage. I will probably start work when the landing gear and lighting arrive.
Old Jan 14, 2013, 05:13 AM
AdMan is offline
AdMan's Avatar
Joined Feb 2010
Im loving those lights!
Where those pilots come from too? :O
Old Jan 14, 2013, 06:10 AM
DominicM is offline
DominicM
DominicM's Avatar
Joined May 2003
Yeah. Good spot. Where do those pilots come from Urrl? Links please?
Old Jan 14, 2013, 08:10 AM
JeffT is offline
Find More Posts by JeffT
Sweden, Skåne County, Lövestad
Joined Apr 2002
Hi,
Finally started building my L59 that was sleeping in its box since...Last September I think
Now, when it comes to install the fan I just discovered that HK sent me an incomplete CS 12 fan. There is only one shaft adapter on the box (the 5mm one), no screws, nothing. The grub screws I can find some, But he thing is that I need the 8mm adapter, since the HET 700-68 motor I bought has a 8mm shaft (made a mistake when I ordered it).
I contacted the HK customer service, but guess what? Of course they just gave me the usual blurb. In short: "Dear valued customer, bla bla bla, sorry we cannot do anything about your problem..."
Once again Hobbyking proves how much they DO NOT care the least about the people, us, who so unwisely spend their money there.
Just added a picture of how came my fan, so you know...
Jeff
JeffT is offline Find More Posts by JeffT
Sold Freewing L-39 Albatross BNF 85.00 radman615 Aircraft - Electric - Jets (FS/W) 2 Dec 07, 2011 09:48 PM
Help! Blitzworks Albatross 55mm L-39 Esc Programming manual anyone? fly_right Micro EDF Jets and Power Systems 1 Dec 05, 2011 07:20 AM
Sold Great Planes L-39 Albatross w/Battery and RX porcia83 Aircraft - Electric - Jets (FS/W) 10 Sep 18, 2011 08:44 PM
L-39 Albatross for 90mm fans Tim H. Electric Ducted Fan Jet Talk 24 Oct 14, 2002 07:42 AM
