Old Nov 22, 2012, 04:51 AM
ravikoth is offline
Find More Posts by ravikoth
RAVI KOTHARI
Joined Nov 2005
this is what i am using, fit great , Look great.
http://www.hobbyking.com/hobbyking/s..._6_Green_.html
Originally Posted by AdMan View Post
Has anyone put in some pilots for this amazing model? Im struggling to find anything, dont really know anything about dimensions either.
ravikoth is offline Find More Posts by ravikoth
Old Nov 23, 2012, 12:10 AM
AdMan is offline
Find More Posts by AdMan
AdMan's Avatar
Australia, SA, Ingle Farm
Joined Feb 2010
Dont suppose I could get a picture from you!
AdMan is offline Find More Posts by AdMan
Old Nov 23, 2012, 02:59 AM
Boostoman is offline
Find More Posts by Boostoman
Boostoman's Avatar
Oman, Masqat
Joined Apr 2010
I thought I would like to share what I did with the canopy. I used a lollipop stick and some hot glue for the front of the canopy. used a small piece of Balsa and a plastic canopy lock. I
I used thin double sided tape to stick both the pieces together.
http://images.search.yahoo.com/image...mb=2SEAPPvShnJ
wish they pre-installed it at the factory it would of been alot easier
I also cut out the pilot seating area since it comes too low into the battery tray. i did this so that i can install larger 8S batteries in the future. but i can install the pilots for display.
Boostoman is offline Find More Posts by Boostoman
Old Nov 23, 2012, 03:08 AM
Boostoman's Avatar
Oman, Masqat
Joined Apr 2010
I was wondering if anyone can help me. I have trying to fit the rear thrust tube and it seems that the thrust tube hole on the fuselage is too small for the supplied trust tube. has anyone faced this issue?
p.s yes i am inserting the smaller diameter side into the fuse.
here are some pics to illustrate my issue.
Old Nov 23, 2012, 07:49 AM
420flyboy is offline
Find More Posts by 420flyboy
Mile High EDF
420flyboy's Avatar
United States, CO, Denver
Joined Jul 2011
Found some struts that will work.
http://www.pw-rc.com/product_info.php/products_id/2866
L-39 scale wheels and struts.
You just have to gently persuade the thrust tube to fit through the rear of the fuselage , little trimming maybe
420flyboy is offline Find More Posts by 420flyboy
Old Nov 23, 2012, 11:14 AM
Lmeano_from_MO is offline
Find More Posts by Lmeano_from_MO
Fast Jets for Fast times
Lmeano_from_MO's Avatar
St. Peters MO.
Joined Nov 2007
AdMan,
I used these from Parkzone T-28 pilots like what Herb pointed out in his build. Cheap, lightweight and with a little paint look great. Here is the size comparison to one Ravikoth picked out, it looks a little big.
I opened the wing and strengthened the retract mount area and will add glass to reinforce the nose and bulkhead because it also looks weak. The tails are on for a visual on this great looking bird. I have the fuse to work on next. I will also move the CS12 fan forward and get the thrust line corrected.
Lmeano_from_MO is offline Find More Posts by Lmeano_from_MO
Old Nov 23, 2012, 02:53 PM
loopsy is offline
Find More Posts by loopsy
Joined Oct 2006
As I mentioned before, HERB made a few nice pictures concerning the gear-modification which you can find in his build-thread.
My own modification follows his example, as I also cut open the lower monocote
to gain access to the "inner" wing. I however use a mix of plywood/CFK tape
to reinforce, as some corners are simply too tight to attach plywood and
CFK/glassfibre does the job even better.
Herbs excellent build thread and the modification you can find here:
http://www.rcgroups.com/forums/showt...6&pp=75&page=4
good luck !
When mine is finished, I will post some pictures.
loopsy is offline Find More Posts by loopsy
Old Nov 24, 2012, 04:16 AM
Force10 is offline
Find More Posts by Force10
Australia, NSW
Joined Mar 2011
I'm almost finished, was just doing taxi test today and notice that when the jet is static it takes about 30% throttle to start moving, is that normal since this is the heaviest jet that i have not sure all my previous foamies will move at may be 5-10% throttle.
Also i have changed the retracts to rc-lander with braking system not sure how to hook up the brakes as the manual is not very clear
Force10 is offline Find More Posts by Force10
Old Nov 24, 2012, 10:26 AM
urrl is offline
Find More Posts by urrl
In the pipe 5 by 5...
urrl's Avatar
United States, FL, Hollywood
Joined Aug 2010
Just ordered L-59, full metal retracts, 5 Turnigy MG servos from Hobbyking. I guess I will be using the 8S system I have.
urrl is offline Find More Posts by urrl
Old Nov 24, 2012, 10:34 AM
Mile High EDF
420flyboy's Avatar
Joined Jul 2011
Nice it's a good looking jet , parts fit well .
I'm using 8s also on wemotec 1600kv.
Old Nov 24, 2012, 01:34 PM
CSI is offline
CSI
Find More Posts by CSI
CSI
I promise, just ONE more order
CSI's Avatar
Del Rio Intl, Texas, United States
Joined Feb 2004
420FB,
Nice find on those Struts. I have also ordered a set, although I really am only after the nosewheel strut. I just didn't like using the 2-wheel T-45 setup that my Lander kit has.
Force10....I have the same retracts with brakes. I have a pretty good idea about how they are supposed to be set up but not to that point yet. I will post pictures when I do get to that stage. I had to do a little trimming to the mounting plate to get these retracts to fit in place. Nothing major, just minor trim here and there. I am considering adding in some new cut out walls and making the wheel opening a bit smaller. They just look way to large with these retracts in place.
Ken
CSI is offline Find More Posts by CSI
Old Nov 24, 2012, 07:42 PM
Force10 is offline
Australia, NSW
Joined Mar 2011
Originally Posted by CSI View Post
420FB,
Ken
Thanks Ken look forward to seeing some pictures when you are ready mate
Old Nov 25, 2012, 06:31 PM
Mile High EDF
420flyboy's Avatar
Joined Jul 2011
So let me see if I have this right
CG 55mm back at 240mm from the middle out.
Or
74mm back from the leading edge near duct ?
Looks like its right about where the ducts start.
Any help ?
Old Nov 25, 2012, 07:44 PM
vettster is online now
Find More Posts by vettster
"Take Off" eh!
vettster's Avatar
Canada, ON, Beeton
Joined Aug 2008
Or
Any help ?
You dont need help...you got it!
vettster is online now Find More Posts by vettster
Old Nov 25, 2012, 07:49 PM
Mile High EDF
420flyboy's Avatar
Joined Jul 2011
Thanks again
I know you know
Sold Freewing L-39 Albatross BNF 85.00 radman615 Aircraft - Electric - Jets (FS/W) 2 Dec 07, 2011 09:48 PM
Help! Blitzworks Albatross 55mm L-39 Esc Programming manual anyone? fly_right Micro EDF Jets and Power Systems 1 Dec 05, 2011 07:20 AM
Sold Great Planes L-39 Albatross w/Battery and RX porcia83 Aircraft - Electric - Jets (FS/W) 10 Sep 18, 2011 08:44 PM
L-39 Albatross for 90mm fans Tim H. Electric Ducted Fan Jet Talk 24 Oct 14, 2002 07:42 AM
