Old Sep 14, 2012, 10:56 AM
alanjets is offline
Find More Posts by alanjets
alanjets's Avatar
Ripoff britain
Joined Jan 2011
We will get plenty of vids to watch .Pav i went for the het 700,68,1125kv lower amp draw but my packs are old and one cell has gone only had 2.5 mins flight and had to land .hope to get some 5000 65-130 packs this weekend and we will get some more videos on youtube.I used the sniper xl retracts out of the one that crashed had to straighten them but they are ok for this i will get the scales out ,The c/g was around 60mm and i tryed slowing it up in the air with no bad problems no tip stall at all
alanjets is offline Find More Posts by alanjets
Old Sep 14, 2012, 12:31 PM
alanjets is offline
alanjets's Avatar
Ripoff britain
Joined Jan 2011
just had it on the scales and AUW is 4.3 thort it took abit to get off it was on duff batterys and it lands real slow at that weight
Old Sep 14, 2012, 01:05 PM
vettster is offline
Find More Posts by vettster
"Take Off" eh!
vettster's Avatar
Canada, ON, Beeton
Joined Aug 2008
Congrats! Alan.
I was at the field when i decided to move my batts back about 1cm more. Dont know where the CG is now..but the plane is BANG On.. I wouldnt doubt that 60mm is the place to be. 55mm is very good for the novice or if your a bit nervous on the maiden.
vettster is offline Find More Posts by vettster
Old Sep 14, 2012, 01:47 PM
pavcon is offline
Find More Posts by pavcon
Κύπρος, Λευκωσία, Πέρα Χωριό
Joined Jan 2010
as fo rthe cg I believe the sweet spot is 58mm..
now that I'm going ot use the metal shroud I might need to drop the internal bec and use an external life to help balance the plane.. btw after flying this plane I almost regreted that I used this fan on this plane
http://www.rcgroups.com/forums/showp...postcount=2861
pavcon is offline Find More Posts by pavcon
Old Sep 14, 2012, 02:21 PM
alanjets is offline
alanjets's Avatar
Ripoff britain
Joined Jan 2011
must admit for a plane got some weight it flys real nice
Old Sep 17, 2012, 02:43 PM
rexmexx is offline
Find More Posts by rexmexx
Joined Jul 2010
Originally Posted by Gaz-b View Post
I hope this helps.
Hi Gaz, are you using those struts on your picture in your L-59? Maybe on grass as well? Do they fit without major extension on the wheelwells?
Thanks, Chris
rexmexx is offline Find More Posts by rexmexx
Old Sep 17, 2012, 05:15 PM
pavcon is offline
Joined Jan 2010
on another update my metal shroud arrived inland today.. shoul dhave it soon
Old Sep 17, 2012, 06:59 PM
Gaz-b is online now
Find More Posts by Gaz-b
Gaz-b's Avatar
Norwich,UK
Joined Feb 2006
Thanks, Chris
No extension to the wells I treated the retracts as materials and machined something to fit the wells from them.
Gaz-b is online now Find More Posts by Gaz-b
Old Sep 19, 2012, 05:49 AM
CrocEnd is offline
Find More Posts by CrocEnd
CrocEnd's Avatar
Darwin
Joined Aug 2002
vettster
Plane been ordered and payed FOR you know whats guner happen now
Croc
CrocEnd is offline Find More Posts by CrocEnd
Old Sep 19, 2012, 06:07 AM
vettster is offline
"Take Off" eh!
vettster's Avatar
Canada, ON, Beeton
Joined Aug 2008
Originally Posted by CrocEnd View Post
vettster
Croc
Way to go Croc! Im very jelious
Winter will be here in another month.. Ill have plenty of time to get myself one thouse engines
Looking forward to your build. Suggest you do it in your blog.
Strongly recommend you Glass the top and bottom of the wings where they join together for this project. I would also use the intake to beef up the intake rings..but cut off the remaining 80% off ducting.
Good luck
Old Sep 19, 2012, 12:00 PM
jcdfrd is offline
Find More Posts by jcdfrd
3DHOG
jcdfrd's Avatar
USA, CA, Aromas
Joined Sep 2010
hey Vett could you explain what in the heck your talking about here
not quite understanding what your saying "cut off 80% of the ducting???"
thanks
jcdfrd is offline Find More Posts by jcdfrd
Old Sep 19, 2012, 01:57 PM
pavcon is offline
Joined Jan 2010
dissappointing perforance after replacing the CS12...
nothing to do with the first 2 flights when the fan blown.
L-59 with LAnder 9 stator shroud (2 min 59 sec)
have to find what's to blame
maybe the exhaust tube that as far as I reeber it was like this one
end points are ok.. amps at 86.. used to be 100 ? ?? have to do it all over again..
Old Sep 19, 2012, 03:07 PM
jcdfrd is offline
3DHOG
jcdfrd's Avatar
USA, CA, Aromas
Joined Sep 2010
Pav
it looked a tiny bit tail heavy just enough to not allow it to get on step, did you re cg it after adding the heavier alloy housing? it sounded good though.
a couple of times in the video it appeared like when you cut the power the nose came up immediately.......a sign of tail heavy also it appeared to be dragging her tail around as you flew...... also a sign of tail heavy... just my observations....the pilot would have a much better feel for these things
Old Sep 19, 2012, 05:26 PM
vettster is offline
"Take Off" eh!
vettster's Avatar
Canada, ON, Beeton
Joined Aug 2008
thanks
Kero John...Think Kero
Old Sep 19, 2012, 05:30 PM
pavcon is offline
Joined Jan 2010
Pav
I was the pilot.. I think I answered those concerns..
the power felt lacking fro the ground..
it looks tailgeavy because I was keeping elevator up cause I was feeling insecure with so much lack of power..
Sold Freewing L-39 Albatross BNF 85.00 radman615 Aircraft - Electric - Jets (FS/W) 2 Dec 07, 2011 09:48 PM
Help! Blitzworks Albatross 55mm L-39 Esc Programming manual anyone? fly_right Micro EDF Jets and Power Systems 1 Dec 05, 2011 07:20 AM
Sold Great Planes L-39 Albatross w/Battery and RX porcia83 Aircraft - Electric - Jets (FS/W) 10 Sep 18, 2011 08:44 PM
L-39 Albatross for 90mm fans Tim H. Electric Ducted Fan Jet Talk 24 Oct 14, 2002 07:42 AM
