Old Jul 02, 2012, 05:53 PM
SlayerNZ is offline
Find More Posts by SlayerNZ
Spektrum Fan Club
SlayerNZ's Avatar
New Zealand, Southland, Gore
Joined Jan 2011
Originally Posted by pavcon View Post
just 1.6gks?? and I thought I was on the edge with 2.2
People are using HXT900 in these so im pretty sure these will be fine.
If you ar worried and dont mind non digital, try these
http://www.hobbyking.com/hobbyking/s...g_0_14sec.html
SlayerNZ is offline Find More Posts by SlayerNZ
Old Jul 02, 2012, 06:03 PM
pavcon is offline
Find More Posts by pavcon
Κύπρος, Λευκωσία, Πέρα Χωριό
Joined Jan 2010
good option...
thanks
pavcon is offline Find More Posts by pavcon
Old Jul 03, 2012, 10:16 AM
bwoollia is offline
Find More Posts by bwoollia
bwoollia's Avatar
United States, CO, Colorado Springs
Joined May 2008
+1
I like to aim for 3.0+kg on high powered models.
bwoollia is offline Find More Posts by bwoollia
Site Sponsor
Latest blog entry: Crash Compilation
Old Jul 03, 2012, 01:19 PM
bwoollia is offline
bwoollia's Avatar
Joined May 2008
Here's the results from running my DPS 90mm 10S unit on 9S. I think I may replace this unit. I'm sure I can get the spec'd 3400W out of it on 10S, it's just very heavy for an already tail heavy unit. Every gram of extra weight on this EDF is two grams on the airframe because I have to add lead to the nose. Seeing as this jet will never be a speed demon, I think I'll go the CS-12 route on 8S or 10S.
Here are the results in a nutshell:
2200W @ 69A and 32V.
Thrust wasn't measured.
The ESC is the Castle 80A ICE2 HV which is mounted in the rear of the battery compartment, it's temperature didn't rise above 44C (111F). This is after a total of about 45 seconds of ground running at full throttle.
Site Sponsor
Old Jul 03, 2012, 02:10 PM
Gaz-b is offline
Find More Posts by Gaz-b
Gaz-b's Avatar
Norwich,UK
Joined Feb 2006
If you are changing the fan I would go Jetfan every time.
Gaz-b is offline Find More Posts by Gaz-b
Old Jul 03, 2012, 03:13 PM
SlayerNZ is offline
Spektrum Fan Club
SlayerNZ's Avatar
Joined Jan 2011
Why not shift the fan forward? thats what im planning to do when my new fuselage arrives.
I had a dummy set up with my damaged fuse and it looks like it will balance ok with 10 cells
Old Jul 03, 2012, 03:41 PM
bwoollia is offline
bwoollia's Avatar
Joined May 2008
Moving it forward about 3cm would be a fair amount of work - moving it further than that would be a headache. I'm not sure if the CG shift would merit the effort since the fan is quite a ways back there. I'll probably hold off until I try the new struts, and I may try and find a nice paved surface to fly from.
I can probably shift the ESC a bit further forward and maybe add a pilot or two which will help. My AUW of 4440g is a bit on the heavy side, but it should still fly well on the 9S setup (and 10S later) with the large wing area and flaps. I really think the struts weren't helping me out on the grass surface.
Site Sponsor
Old Jul 03, 2012, 04:02 PM
vettster is offline
Find More Posts by vettster
"Take Off" eh!
vettster's Avatar
Canada, ON, Beeton
Joined Aug 2008
Thats what I did last night
Does this mean you tried to fly it?
vettster is offline Find More Posts by vettster
Old Jul 03, 2012, 04:09 PM
bwoollia is offline
bwoollia's Avatar
Joined May 2008
Yep
http://www.rcgroups.com/forums/showp...&postcount=322
Site Sponsor
Old Jul 03, 2012, 04:10 PM
pavcon is offline
Joined Jan 2010
why not use 10S and get the extra weight in the nose?
Old Jul 03, 2012, 04:31 PM
TragedyTrouser is offline
Find More Posts by TragedyTrouser
United States, FL, Vero Beach
Joined Mar 2008
Think 10s is the way to go as well. 10s will give you the extra nose weight you need, lower amps on the ESC and a extra pound of thrust from 8s. Im getting 3300 watts @ 77amps on a Change Sun 12 blade on 10s
TragedyTrouser is offline Find More Posts by TragedyTrouser
Old Jul 03, 2012, 04:41 PM
bwoollia is offline
bwoollia's Avatar
Joined May 2008
It will be 10S soon. I just have an 80A HV ESC in my little hands right now which might be marginal for 10S with this setup, so I'm running 9S. When I get a larger ESC the extra cell will get dropped in. The extra weight in the nose will be negligible - I'm using a 2200mAh 3S for a receiver battery for extra weight, plus 150g or so of lead.
Site Sponsor
Old Jul 03, 2012, 05:11 PM
pavcon is offline
Joined Jan 2010
dear god that's too much.. and 2200mah are tooooo little
you iwll need very high c rating apcks for this one
just go 4000mah 10s and use a small life for the receiver or a 2s 1300lipo
iit will be plenty enough
150g of lead are TOOOOOOO much for this model
Old Jul 03, 2012, 05:24 PM
vettster is offline
"Take Off" eh!
vettster's Avatar
Canada, ON, Beeton
Joined Aug 2008
Wow! im really surprised that this plane is so tail heavy. im glad you posted it. Im at the point of adding all the components now, so I can move them around first before any thing become permanent.
And im going with 7s!!
Old Jul 03, 2012, 05:27 PM
jcdfrd is offline
Find More Posts by jcdfrd
3DHOG
jcdfrd's Avatar
USA, CA, Aromas
Joined Sep 2010
+1!!!!!
trade the lead for MAH
jcdfrd is offline Find More Posts by jcdfrd
Sold Freewing L-39 Albatross BNF 85.00 radman615 Aircraft - Electric - Jets (FS/W) 2 Dec 07, 2011 09:48 PM
Help! Blitzworks Albatross 55mm L-39 Esc Programming manual anyone? fly_right Micro EDF Jets and Power Systems 1 Dec 05, 2011 07:20 AM
Sold Great Planes L-39 Albatross w/Battery and RX porcia83 Aircraft - Electric - Jets (FS/W) 10 Sep 18, 2011 08:44 PM
L-39 Albatross for 90mm fans Tim H. Electric Ducted Fan Jet Talk 24 Oct 14, 2002 07:42 AM
