Old Jun 15, 2012, 01:26 PM
alanjets is offline
Find More Posts by alanjets
alanjets's Avatar
Ripoff britain
Joined Jan 2011
Originally Posted by pavcon View Post
btw there are some good wing servos on hk .. on new items.. the corona ones.. though they are not really required as bwoollia says they have somereally good specs for the money
they look like hitec servos even the print on the side
alanjets is offline Find More Posts by alanjets
Old Jun 15, 2012, 02:31 PM
SCALEFAN is offline
Find More Posts by SCALEFAN
Done it all
United States, CA, Corona
Joined Feb 2006
Is this what you are talking about?
http://www.hobbyking.com/hobbyking/s...5kg_0_10s.html
SCALEFAN is offline Find More Posts by SCALEFAN
Old Jun 15, 2012, 02:46 PM
bwoollia is online now
Find More Posts by bwoollia
bwoollia's Avatar
United States, CO, Colorado Springs
Joined May 2008
I'm putting this servo all around (except the elevators, which I'm using a couple of digitals I had lying around). This is my all-time favourite EDF analog servo - tons 'o torque and fast enough. They hold the barn door elevons tight on my 200km/h 70mm Mirage. They're also much lighter than the new Coronas, with just a little bit less torque.
http://www.hobbyking.com/hobbyking/s...idproduct=8752
Turnigy 380MG Micro Servo (Metal Gear) 3.6kg / .15sec / 15.6g
If I want a digital servo, I'll use this one:
http://www.hobbyking.com/hobbyking/s...idproduct=8761
BMS-385DMAX Digital Servo (Metal Gear) 4.2kg / .15sec / 16.5g
And if I need a lot of torque for something like an all-flying stab, I'll use this one:
http://www.hobbyking.com/hobbyking/s...dproduct=11627
TGY-390DMH High Performance MG Digital Servo (Extra Strong) 5.4kg / .11sec / 22.5g
bwoollia is online now Find More Posts by bwoollia
Site Sponsor
Latest blog entry: Crash Compilation
Old Jun 15, 2012, 03:24 PM
pavcon is offline
Find More Posts by pavcon
Κύπρος, Λευκωσία, Πέρα Χωριό
Joined Jan 2010
They lookk but the hitec equivalent has 3.0 and 3.5kgs of torque at 4.8 and 6 volts
pavcon is offline Find More Posts by pavcon
Old Jun 16, 2012, 11:16 AM
Gaz-b is offline
Find More Posts by Gaz-b
Gaz-b's Avatar
Norwich,UK
Joined Feb 2006
This is the elevator linkage I have made recycled raptor 50 flybar seesaw and blade grip ball the piano wire has brass sleeves soldered to the ends to increase the diameter and give the screws something to grip.16g so probably removing one servo has not saved weight but the tailplane and elevators will be clean.
Gaz-b is offline Find More Posts by Gaz-b
Old Jun 16, 2012, 06:52 PM
bwoollia's Avatar
Joined May 2008
I have modified the intake collector to fit the DPS 90mm fan. I cut two slits down 80% of the length of the collector, fit it over the fan and wrapped a couple of layers of fibreglass and un-diluted finishing resing. Seems very strong and it's a perfect fit! On to the ducting...
Site Sponsor
Old Jun 16, 2012, 07:08 PM
Gaz-b is offline
Gaz-b's Avatar
Norwich,UK
Joined Feb 2006
been thinking mine might get retracts after all as the wings already have the covering cutout and it should be able to cope with a bit more weight than the Hawk as wing area is 22% larger.
Old Jun 16, 2012, 08:18 PM
bwoollia's Avatar
Joined May 2008
Thrust tube - the stock one clearly doesn't fit either my EDF nor the plane it came with. Replace it with mylar? Nope! Let's cut it and re-use it!
I split the tube from end to end, making it essentially a flat sheet. Since it's too large at the tail end, it will roll over itself just like mylar would. At the EDF end, there is a split where motor wires will exit the thrust tube, I'll clean up the holes with tape.
Test fit, and marking where to cut for the tail end:
Finished product!
Site Sponsor
Old Jun 17, 2012, 01:50 AM
pavcon is offline
Joined Jan 2010
nice bwoola ...
can't wait for your maiden.. keep us up to date with your build
Old Jun 17, 2012, 08:19 AM
choopi is online now
Find More Posts by choopi
choopi's Avatar
New Brunswick
Joined Feb 2006
Between the two gear, wonder witch one would fit the best?
http://www.hobbyking.com/hobbyking/s..._45_L_59_.html
http://www.hobbyking.com/hobbyking/s...dProduct=24333
choopi is online now Find More Posts by choopi
Old Jun 17, 2012, 08:33 AM
pavcon is offline
Joined Jan 2010
Originally Posted by choopi View Post
they are exactly the same except from the nose. the length of the mains are exactly the same.. so ... the second ones also have brakes..
still there are wheels thatyou can replace later with brakes for the first set...
Old Jun 17, 2012, 08:37 AM
choopi's Avatar
New Brunswick
Joined Feb 2006
Also was looking at that fan! 12 blades, 1900kv, on 8s,10s that would pull 200amps! 8s-10s with 12 blades, I would see more a 1200kv motor.
HobbyKing Daily - 90mm Alloy EDF Unit (2 min 22 sec)
Look like the fan in question: http://epf.com.tw/category.php?id=19
according to the site, 1600kv on 10s 120amp
Old Jun 17, 2012, 11:08 AM
pavcon is offline
Joined Jan 2010
Yes choopi. As i said on a comment on youtube it seems that scott got it wrong. These fans look impressive but i beliee there are better solutions out there
Old Jun 17, 2012, 11:19 AM
Gaz-b is offline
Gaz-b's Avatar
Norwich,UK
Joined Feb 2006
Well I have just placed an order for these they look like albatros gear might have to shorten them a touch but that's what this hobby is about.
http://www.hobbyking.com/hobbyking/s..._20_class.html
Old Jun 17, 2012, 11:58 AM
bwoollia's Avatar
Joined May 2008
I think you might be okay with those, Gaz-b. There is lots of room for longer legs, and the ones I have are probably a bit too short for scale. My wing tanks will have grass stains on them likely.
Site Sponsor
Sold Freewing L-39 Albatross BNF 85.00 radman615 Aircraft - Electric - Jets (FS/W) 2 Dec 07, 2011 09:48 PM
Help! Blitzworks Albatross 55mm L-39 Esc Programming manual anyone? fly_right Micro EDF Jets and Power Systems 1 Dec 05, 2011 07:20 AM
Sold Great Planes L-39 Albatross w/Battery and RX porcia83 Aircraft - Electric - Jets (FS/W) 10 Sep 18, 2011 08:44 PM
L-39 Albatross for 90mm fans Tim H. Electric Ducted Fan Jet Talk 24 Oct 14, 2002 07:42 AM
