Old Oct 07, 2012, 11:49 AM
Eagle34 is offline
Find More Posts by Eagle34
TEAM HILLBILLY
Eagle34's Avatar
Pass Christian, MS
Joined Jan 2010
Eagle34 is offline Find More Posts by Eagle34
Old Oct 27, 2012, 06:23 PM
3D Peter is offline
Find More Posts by 3D Peter
3D Peter's Avatar
Joined Oct 2011
hi folks,
Im about to finish assembly of my extra, please tell how heavy a motor for this plane should be (with all the equipment like x-mount and prop adapter) to get the CG on the right place
many thanks in advance
Pete
3D Peter is offline Find More Posts by 3D Peter
Old Oct 27, 2012, 06:41 PM
groovejet is offline
Find More Posts by groovejet
How many planes is too many?
groovejet's Avatar
Australia, VIC, Melbourne
Joined Aug 2007
Hi Pete,
The recommended motor is approx. 140g plus about 25g of accessories. A spinner is probably about 25g too. I did some tail mods to increase tail stiffness and using a 166g motor plus about 22g of accessories and no spinner, my 204g lipo is as far forward as I can get it to be hands-off neutral. I suggest that you mount your ESC and receiver as far forward as practical and don't add to much tail weight due to heavy servos or servo cable extensions. I suspect that the use of a spinner is the easiest way to ensure that you are not too tail heavy, assuimng that your motor is at least 140g before attaching about 25g of accessories to it. Bear in mind that individual kits will vary a bit, so you may find that your kit is easier to balance.
groovejet is offline Find More Posts by groovejet
Old Oct 27, 2012, 07:37 PM
3D Peter is offline
3D Peter's Avatar
Joined Oct 2011
thanks groove
my preferred motor for the SW 48 foamies is 155g with all the accessories, but Im afraid it could be not enough, I have the option to use a 190g drive but I dont like this option due to the increased AUW, well see
my servos are savox sh-0255mg, about 16g each
maybe I just cut off the tailwheel and replace it with a simple carbon rod glued to the end of the fuse if I get trouble with CG, I like this option more than adding additional dead weight by using a spinner
Pete
Old Oct 27, 2012, 10:15 PM
vinay2070 is offline
Find More Posts by vinay2070
vinay2070's Avatar
India, KA, Bangalore
Joined Sep 2009
Pete, Savox servos are my favourite. Infact Iam planning to use them on my 30CC MXS-r (Align DS610 made by Savox). BTW 16g each and 3.9 KGCM at .13 Sec is very very good IMO.
vinay2070 is offline Find More Posts by vinay2070
Old Oct 28, 2012, 10:13 AM
3D Peter is offline
3D Peter's Avatar
Joined Oct 2011
yep, Ill always go with savox now, we tested the Hitec HS-82MG against the savox sh-0255mg over a perioud of 60-70 3D flights on a SW MXS
after that amount of flights the hitecs were worn out and got a lot of play and got loose, the savox worked like on the first flight, almost no signs of wear
savox rocks!
on my new WM 70" edge Ill go with savox as well
Pete
Old Oct 29, 2012, 07:40 AM
3D Peter is offline
3D Peter's Avatar
Joined Oct 2011
whats the average AUW for this palne?
I guess my extra will be about 1260g at least, min. 70g more than my skywings, but on the other hand, this model is bigger than the SW palnes, so it is not surprising that it is a bit heavier
Old Oct 31, 2012, 06:48 PM
3D Peter is offline
3D Peter's Avatar
Joined Oct 2011
hallo folks,
could someone of you measure the exact location of CG on his own plane, please?
the manual says 105-115 from LE, is this true or could it be a little bit more to the tail and still fly OK?
I dont think Frank wrote wrong data in the manual, but I noticed that CG location in the Skywing manuals was a little nose heavy and I could move it much more back than the manual said and my MXS still flew nicely, so I wondered if it could be the same with the WM Extra?
cheers
Pete
Old Nov 04, 2012, 11:41 AM
7oneWo1f is offline
Find More Posts by 7oneWo1f
AMF Years
7oneWo1f's Avatar
Joined Nov 2011
Hello guys, I finally finished a video of my son's tour of the Winner's Model factory with Mr. Frank Liu. It is on my blog here at rcgroups: Tour of model RC airplane factory (home video).
I hope others enjoy watching it as much as I did (it was interesting to me because I wasn't able to be on the tour).
7oneWo1f is offline Find More Posts by 7oneWo1f
Old Nov 12, 2012, 02:44 PM
CNJ3 is offline
Find More Posts by CNJ3
China, Guangdong, Zhuhai
Joined Nov 2010
Hey guys,
55in Slick360 now is annouced. I created a new thread here:
http://www.rcgroups.com/forums/showthread.php?t=1769101
CNJ3 is offline Find More Posts by CNJ3
Old Nov 19, 2012, 01:46 AM
Lomchevac is offline
Find More Posts by Lomchevac
AKA Boomhauer
Lomchevac's Avatar
Arkansas
Joined May 2008
Canopy
Anyone have a canopy (blue) they want to part with? Mine ejected off and blew into the Arkansas river. If anyone knows if 3dhs's extra canopy fits let me know and I will order one. Or if someone sells canopies for WM planes.
Troy
Lomchevac is offline Find More Posts by Lomchevac
Old Nov 19, 2012, 06:05 AM
3D Peter is offline
3D Peter's Avatar
Joined Oct 2011
cnj3 sells canopies for WM planes
Im quite sure that the 3dh canopy will not fit
Old Nov 19, 2012, 09:54 AM
CNJ3 is offline
Joined Nov 2010
Troy
Hi Troy,
We have canopy as spare part instock, please PM me for service details, thanks.
Old Nov 19, 2012, 03:35 PM
AKA Boomhauer
Lomchevac's Avatar
Arkansas
Joined May 2008
Thank you for the responses. I'll get with you CNJ3.
Old Nov 19, 2012, 03:51 PM
JDMCARPETS is offline
Find More Posts by JDMCARPETS
KING of PING!
JDMCARPETS's Avatar
United States, PA, Lancaster
Joined Nov 2008
CNJ3 can you produce these? http://www.dailymail.co.uk/news/arti...illed-car.html
JDMCARPETS is offline Find More Posts by JDMCARPETS
New Product Winner's Model Extra EPP 3D feda 3D Foamies 57 Sep 08, 2014 11:41 PM
New Product EasyTiger Models Ultra Corsair 48in WS FieldofDreamsFlyer Electric Warbirds 14 May 24, 2012 06:23 PM
New Product Another EPP Yak55m -- Winners Model 49" Yak55m SEPP feda 3D Foamies 7 Jan 06, 2011 11:27 PM
Alert Vendo Radiocraft Extra 330LX 35% *NUEVO PRECIO* cochesalido Mexico 28 Oct 31, 2007 09:51 PM
