The Netherlands
Joined May 2012
I did yesterday my first FPV outdoor test with the Tonka. It is really fun to do! With the test I got a 500mW 5.8 GHz video transmitter mounted on the rear bed (I know, the antenna should be higher. But I wanted to test the Tonka
)But the distance of the video signal was disappointing. Something around 250 meters in plain sight. And when an object was between the VTx and the RTx, then the signal was almost gone. So that’s why I soon gonna test a 1.3GHz video transmitter. So that hopefully the video uplink goes through some objects. As I mentioned earlier, I configured Dual Rate settings on my Spektrum DX6i. That’s working really fine! For normal driving the max speed is around 10km/p (sounds slow, but when driving FPV. Then it is really fast enough) And if I flip the Dual Rate switch, then I can drive max 20km/p with limited steering. The top speed is then 20km/p, I experience that's really fast when I drive FPV. I'm using two 2200mAh 3S lipo's connected parallel to power everything in the Tonka. I ain't disappointed of the runtime of this setup. After 30 minutes driving, only 2000mAh was used. So I think that I can safely drive for around 45 to 60 minutes. Depends on surface and how fast I'm driving. Here is the movie of my first outdoor FPV test drive:
The Netherlands
Joined May 2012
After my first test run, I wasn’t totally satisfied about the position of the camera. Because the visibility of Ken isn’t really good in the movie. So that’s why I gonna change the position of the pan/tilt system a little bit backwards.
I’m also busy with a extra antenna mount for the 1.3GHz antenna. And so I keep working on this project.
| Thread Tools | |
| Discussion FPV Tonka Summit | replayreb | Video Piloting (FPV/RPV) | 3325 | Today 11:16 AM |
