Old May 28, 2012, 08:48 PM
trevorcgross is offline
Find More Posts by trevorcgross
United States, NY, Hamburg
Joined Mar 2012
How many flights would you normally(on average) have before you crash?
trevorcgross is offline Find More Posts by trevorcgross
Old May 28, 2012, 10:01 PM
Efliernz is offline
Find More Posts by Efliernz
I'll fly anything...
Efliernz's Avatar
Hamilton, New Zealand
Joined Jan 2007
Whats a crash???
I've had one bad landing (no damage) within the last 150 flights.
Pete
Efliernz is offline Find More Posts by Efliernz
Old May 29, 2012, 10:12 AM
John141 is offline
Find More Posts by John141
Underwater Helicopter Badge
John141's Avatar
South Africa, WC, Cape Town
Joined Mar 2011
I agree, you shouldn't think like that. If you are going to put a valuable camera on a multicopter, make sure it has GPS with at least GPS Hold and RTL functionality and RTL failsafe. Then use good quality ESCs and motors, and test everything on the ground. Fly over bushes or thick grass and *never* near people when you are learning.
The only quad of mine that I've crashed heavily was a Gaui 330, and I was a beginner at the time. Its a good model to learn on, because it handles crashes very well. Work your way up from there.
Final advice: never panic. Panic leads to crashes, in every area of aviation.
John141 is offline Find More Posts by John141
Old May 29, 2012, 10:18 AM
Tarro is offline
Find More Posts by Tarro
Long Island, New York
Joined Jun 2008
It totally depends on the type of flying you are doing. I have been practicing very low level forest flying, the chances are a lot higher.
Low Level Aerial Reconnaissance. (7 min 28 sec)
Tarro is offline Find More Posts by Tarro
Reply With Quote  (Disabled)
Old May 29, 2012, 12:34 PM
Hogster is offline
Find More Posts by Hogster
HeliAP'er!
Hogster's Avatar
Surrey, UK
Joined Aug 2003
I haven't had any pilot-induced crashes for several years now. I learned the ropes of flying model helicopters with little indoor ones back in 2003 where I crashed quite often
I wouldn't go as far as John in saying if you're going to put a valuable camera up in the air you need a highly automated system - my tricopter is flown under pure manual control (aside from rate-feedback stabilisation which is mandatory on a multi-rotor platform!), and it carries a 300 camera. My hexacopter will be the same and it will carry a 550 camera. Confidence and experience is worth more than clever electronics – I wouldn't advise flying something with a high degree of autonomy unless you are a competent manual pilot to start with, otherwise if you suddenly need to take manual control you won't stand a chance ...
On a different note, I've had three crashes in the last 18 months which were caused by equipment malfunction – one potential case of severe interference (old 35MHz system, still not entirely sure if interference was the cause), one motor failure (no strain relief on motor wires by default, and a wire broke off inside the motor), and one structural failure due to poor design (on my part!).
So I would say practice is the key if you're worried about crashing .... don't run before you can walk. Don't fly too far from you until you've gained sufficient confidence, and always give gentle control inputs if you suddenly lose orientation – as John mentioned, don't panic! Also pay close attention to the quality of the components you use in your models – buying the cheapest equipment might save you money in the short term, but if it fails it will cost you vastly more in the long run!
My 2p!
David
Hogster is offline Find More Posts by Hogster
Old May 29, 2012, 12:41 PM
rcbif is offline
Find More Posts by rcbif
Do a Barrel Roll!
rcbif's Avatar
United States, OH, Medina
Joined Jun 2005
We try not to crash
But my last aerial video related crashes were equipment failure.
One was the lock screws loosening off my motor despite thread lock resulting in my motor falling off and tricopter falling 20ft.
The other two were 72mhz glitches that caused me to loose control of the tricopter.
Both issues have been fixed, and hopefully they wont happen again.
I can honestly say, in my 5 years of flying parkflyers (planes), I've had only one crash. Flying my supercub when it was snowing, and I had a bit of a depth perception issue when landing, resulting in me crashing into a poll
Other than that, I do push my aircraft every now and then, but I make sure there is a way out.
Keep your flight at it's simplest. Dont go pushing yourself to do different crazy things. It will eventually happen on it's own, either intentional or accidental, and you will slowly pick up on it. And as stated, dont panic if you start to loose it. Just focus on orientation, and flight. The only thing you have to loose is flying time and some money.
rcbif is offline Find More Posts by rcbif
Old May 30, 2012, 07:31 AM
Berkie is offline
Find More Posts by Berkie
Great Southern Land
Berkie's Avatar
Australia, VIC, Melbourne
Joined Feb 2007
If one form of "panic" is to not be able to think straight when I get the model topsy turvey then I do "panic"
I have had many crashes, but on the last one I noticed I started to think out loud saying "left, left" when I needed the plane to go left. I found it helped to lessen the panic.
Next time (and there will be) I'll make it more forceful, "nose up, nose up, more power, go right, go right". I think this will help get rid of the attitude of "she's a goner, I can't do anything about it"
Kev
Berkie is offline Find More Posts by Berkie
Discussion How many unbuilt kits have you hoarded? Killionaire Fuel Plane Talk 58 Jul 06, 2014 04:08 PM
Discussion How many helicopters have you played? Aaron qin Electric Heli Talk 35 Apr 22, 2012 05:41 PM
Discussion how many of you guys have facebook? andione1983 Australia 46 Mar 04, 2012 06:54 PM
Rant How many 3 MM motor shafts have you ..... Bill Smudge Electric Plane Talk 12 Feb 29, 2012 02:50 PM
Poll How many of you would actually prefer the planet was warmer? Kcal Life, The Universe, and Politics 35 Dec 07, 2011 09:04 PM
