Old May 28, 2012, 03:44 PM
wattflyer6161 is offline
Find More Posts by wattflyer6161
United States, AZ, Phoenix
Joined Jun 2007
Help me Identify/Replace this Brushless Motor
I recently burned out this motor that was being used in my Trojan, and was wondering if anyone could help me find it online or possibly have one for sale. I purchased it used so I don't know that much about it, all the can says is Hyperion Hp-Z3013-14. Also, if someone has a motor that would work in its place, let me know. I have been using this with a 36amp thunderbird ESC, and a 3 cell 2200 with props around 10x7. Also, if someone would like to purchase this motor, let me know. It just needs to be rewound but I don't think I'd be able to do that. Or, if someone is willing to rewind it, let me know what you would charge.
Thanks!
wattflyer6161 is offline Find More Posts by wattflyer6161
Old May 28, 2012, 03:55 PM
Lnagel is offline
Find More Posts by Lnagel
Senile Member
Lnagel's Avatar
Moab, Utah, USA
Joined Apr 2003
Here are the specs for the motor. It's rated at 22 to 32 amps with a 40 amp burst. It weighs 110 grams and has a Kv of 1085. Just look for a replacement motor with similar specs.
Larry
Lnagel is offline Find More Posts by Lnagel
Old May 28, 2012, 06:23 PM
Dr Kiwi is offline
Find More Posts by Dr Kiwi
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
If you don't need the narrow nose/glider shape, this should be pretty close: http://www.innov8tivedesigns.com/pro...roducts_id=516
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old May 28, 2012, 06:34 PM
JimNM is offline
Find More Posts by JimNM
WAA-08 THANK FRANK!
JimNM's Avatar
Las Cruces, New Mexico, United States
Joined Jun 2002
http://www.allerc.com/hyperion-gs301...kv-p-5159.html
try here...
With the reverse mount in place, I suspect that he does not need the tapered bell as that is designed to fit in the narrow nose of gliders.
Data sheet here...
http://aircraft-world.com/prod_datas.../z3013spec.htm
JimNM is offline Find More Posts by JimNM
Discussion Help me identify this plane I inherited in 1997 PsychoDragon Classic Pattern Flying 13 May 24, 2012 09:54 AM
Found Can someone help me identify this? wing881 Aircraft - Sailplanes (FS/W) 22 May 20, 2012 07:48 AM
Question Can someone help me identify this car indycobra Off-road Cars 7 Apr 05, 2012 12:23 PM
Help! Help me identify this Comparf Extra..... trevoryoung00 Giant Scale Airplanes 1 Dec 06, 2011 09:24 PM
Discussion Someone help me identify this MWC board WiseDuck Multirotor Talk 5 Dec 04, 2011 09:37 AM
