Old Jul 18, 2012, 05:14 AM
home of the best antennas
United States, VA, Herndon
Joined Nov 2011
Originally Posted by GFTbak View Post
Hi KondorFpv
I ordered same set like luca (but in green if possible)
(2450 - 1sma 90° en 1straight - green)
How long takes shipping to Belgium?
greetz (-> nice selection BTW)
Yes, I see the order in the database,
I will build them this afternoon and ship them tomorrow.
I just am on top of orders ATM.
Shipping Italy-Belgium is like 4-5 days normally, I have already shipped a few to Belgium and Netherlands and that's the average time. If it goes wrong 7-8 days.
KondorFPV is offline Find More Posts by KondorFPV
Old Jul 18, 2012, 05:15 AM
Joined Nov 2011
Gregor, this nice set is heading your way to Austria.
Old Jul 18, 2012, 10:03 AM
Joined Nov 2011
Hello Kris.
Your antennas have been made and individually tested as usual.
These are your green anteannas, you asked for 2450 (lawmate ch3), as you can see the SWR on 2450 is as low as is humanly possible 1.15:1
www.fpvlr.com - your custom fpv antennas
Old Jul 18, 2012, 10:08 AM
België, Vlaams Gewest, Geraardsbergen
Joined Mar 2010
Originally Posted by KondorFPV View Post
Hello Kris.
Your antennas have been made and indivitually testes as usual.
most fantastic service ever!!!!!
thanks
GFTbak is offline Find More Posts by GFTbak
Joined Nov 2011
And if you ever wonder why people are weary of 5.8 antennas being put together without testing equipment ( I use a different swr meter for the 5.8 frequency, not the one in the picture), you can see why in the picture.
It happens often (1 in 3 or 1 in 4 ) that I can't tune the antenna in a satisfactory way, and that's using the same gigs, the same connectors, same coax etc.
It's the mistery of 5.8, sometimes all it takes is half a millimeter mistake, a bigger than normal blob of solder and NO amount of glue will help me tune the 5.8 antenna, even if I get it down to 1.7:1 - 1.6:1 SWR , which is useable... this is what happens to those sub-standard antennas.
4 heads chopped off, and that's easily a full day of work thrown in the bin.
Old Jul 18, 2012, 10:17 AM
Joined Nov 2011
thanks
You are welcome,
my helper already packed them and tomorrow morning it will ship out.
Old Jul 18, 2012, 12:28 PM
Joined Nov 2011
I am introducing a very light weight Yagi for 980-1010 mhz (ch 1 and ch2 of 900mhz
foxtec/sunsky tx)
cnc cut out of g10 for perfect spacing, the elements are 2mm aluminum, enamel coated and the feeding dipole is made of 1.6 mm copper.
The weight of the antenna including a 30cm long coax and SMA male connector is only 21 grams that's a breeze even for an antenna tracker with micro servos.
Gain is adequate between 8 and 9 dbi (simulation shows 8.5dbi)
It's comparable with a 8dbi patch but the patch weights 1500grams (1.5kg).
This one of course is more fragile as the elements can bend easily if it falls or it's hit but they bend right back to position, so no worry.
Old Jul 18, 2012, 09:33 PM
Australia, VIC, Melbourne
Joined Aug 2011
Hello Brett,
your antenna set is ready..
Please let me know how they compare.
You are my first customer from "down under" so I don't know how long it takes for the package to get to you.
Just arrived right now so approx 10 days. Look good. Hopefully I can check them out this weekend and see if distance improves.
Cheers
Brett
BrettAltea is offline Find More Posts by BrettAltea
Old Jul 19, 2012, 01:27 AM
Joined Nov 2011
Cheers
Brett
cool beans! Australia 10 days shipping? I'll take that any day!
Let me know how they work!
Tony.
Old Jul 19, 2012, 06:27 AM
Joined Nov 2011
Newest addition to our offerings is this 12 turn antenna, just test flown this morning without an optimized pinwheel on the tx side... 10.8km before snow effect convinced me to turn back, and that's on 200mw foxtec tx..
My area has a pretty high noise floor on 5.8 , since the wind turbines communicate on this frequency, so you might be able to get more - 15-16 km in a clean area.. that's my estimate on 200mw system
Old Jul 19, 2012, 10:50 AM
Joined Feb 2011
Hi KondofFPV,
I just placed an order online for the 5.8 antennas. I'm using hobbyking 5.8GHz system (Foxtech 200mw) on channel 7, which should be 5925mhz?
If possible, use blue color shrink and 1 straight and 1 90° connectors.
Nathan
gsnathan is offline Find More Posts by gsnathan
Old Jul 19, 2012, 11:59 AM
Aerial Photography
Canada, BC, Vancouver
Joined Jun 2012
Would it be possible to make a custom order? If you could I would really appreciate that. I have a helical antenna already but I am just not sure how well I built it. It is 15 turn 1.3ghz but it is not a huge cannon because I spaced the turns close to each other, don't know how good that is.
Anyways, would you be able to make a custom helical antenna for 1.3ghz for me?
I need as many turns as is reasonable (for most gain I assume), RHCP, long SMA cable, 1320Mhz, and a sturdy (ideally thick plywood) reflector base where I could screw in my clamp.
Please let me know if this is possible at this moment or if not when you will be able to make one. Thanks.
kdrcguy is offline Find More Posts by kdrcguy
Old Jul 19, 2012, 02:44 PM
Joined Nov 2011
Originally Posted by gsnathan View Post
Hi KondofFPV,
Nathan
Yes Nathan, I see the order.
Check back on here to see when they are ready and shipped.
Old Jul 19, 2012, 02:54 PM
Joined Nov 2011
Yes I have a few requests in that respect.
If the turns are closely spaced than it can't be too good.
Normally for any helical the turn pitch angle is beween 12° and 14° to work.
That would really make a 1320 mhz helical about 75cm long at least.
75cm is very very long and a problem to ship. My cnc working area is 52cm x30cm, that means the most I could safely make is a 9 turn.
It's also important for these antennas to use a thick wire for reasonable wideband operation.
If you want we can continue this conversation in private messages
Old Jul 23, 2012, 05:39 AM
Joined Nov 2011
Several antennas are on the way,
John, the 12 turn helical from a few posts above is coming to Virginia,
The purple set with the 8 turn helical for Tecnodrone is coming too,
and Nathan, your blue 5.8 set is ready, I am happy with SWR on these, you will love them too. You are the first customer from the Asian continent, and with this I have all 5 inhabited continents accounted for.
I am happy to have at least one my antennas in each continent
Build Log New "TOBA" F3B/F from RCRCM available through www.soaringusa.com target Multi Task F3X 202 Mar 04, 2013 02:28 AM
New Product www.circular-wireless.com: home of the 100/200Km world range record antennas sircana Video Piloting (FPV/RPV) 148 Jan 13, 2013 06:14 AM
New Product www.HobbyWireless.com New FPV wireless store riosouza Video Piloting (FPV/RPV) 11 May 22, 2007 12:40 PM
new antenna from www.Azarr.com Fred Bronk Parkflyers 8 May 05, 2001 03:21 PM
