Old Jul 08, 2012, 08:15 AM
KondorFPV is offline
Find More Posts by KondorFPV
home of the best antennas
United States, FL, Boca Raton
Joined Nov 2011
Originally Posted by aeroseb View Post
Hello Kondorfpv, Can you tell me the building differences between your pinwheel antenna and the Terrybuid's ones (from france). Thank you.
Hello aeroseb,
unfortunately I don't have terrybuild's antennas in my hand to compare, so I really don't know what to answer to that. Maybe there is a difference with the helicals, as you can see materials and design are different, G10 (vetronite) cnc cut for consistency.
I am also trying to use a plastic tube over the coax for the pinwheels, hopefully I can keep that up depending on materials availability.
KondorFPV is offline Find More Posts by KondorFPV
Old Jul 08, 2012, 08:18 AM
Joined Nov 2011
Originally Posted by BrettAltea View Post
Just ordered a pair of 5.8ghz SPW tuned for 5760mhz. Currently using a CP and SPW from BevRC which I'm not overly impressed, though they're only half the price, with so will be good to compare. Will let you know if they're much better or not when I recieve them.
That's great, I welcome a challenge...plus fair comparisons are a good and constructive thing.
You use sma connector for immersion rc or fatshark gear, correct? not rp-sma as with foxtec gear.
Old Jul 09, 2012, 08:34 AM
Joined Nov 2011
Hello Brett,
your antenna set is ready..
Please let me know how they compare.
You are my first customer from "down under" so I don't know how long it takes for the package to get to you.
www.fpvlr.com - your custom fpv antennas
Old Jul 10, 2012, 01:33 AM
Joined Nov 2011
Parnassus, here is your atenna set, as you requested 30cm long cable for the helical.
Old Jul 10, 2012, 12:44 PM
Joined Nov 2011
I have changed the matching method of my helicals, in favour of Jason's Hecker's tapered transformer.
I find this method to be more consistent, and less time consuming.. SWR stays low on all 5.8 range, super consistent!
Another note, starting from today you can choose the color of the tube, so the antenna matches your plane.
available colors are: baby blue, green, purple, yellow, ... pink ..
Lorenzo, this is your sweet set:
Old Jul 11, 2012, 03:08 PM
Joined Nov 2011
Hello Max, here's your green set,
as you requested the tx antenna is 6cm long. RP-SMA connectors for FOXTEC gear.
Let me know how you like them!
Old Jul 11, 2012, 04:16 PM
Sonicfury405 is offline
Find More Posts by Sonicfury405
Joined Jul 2012
Looks great! Thanks!
Sonicfury405 is offline Find More Posts by Sonicfury405
Old Jul 11, 2012, 11:24 PM
LandoV2 is offline
Find More Posts by LandoV2
USA, CA, Irvine
Joined Apr 2009
[QUOTE=KondorFPV;22071590]Hello Orlando,
your custom antennas are ready, these in the picture are your actual antennas. Heading to the post office. 7-8 business days and they'll be in cali...
Hi Marc, received my antennas today (7 days from Italy to Cali) and they look great, can't wait to test them this weekend.
Orlando
LandoV2 is offline Find More Posts by LandoV2
Old Jul 12, 2012, 04:57 AM
Joined Nov 2011
[QUOTE=LandoV2;22140739]
Originally Posted by KondorFPV View Post
Hello Orlando,
Orlando
Great Orlando,
7 days is good , that confirms the 7-8 days that I am getting to US and Canada destinations.
Old Jul 12, 2012, 01:05 PM
Joined Nov 2011
And... Luca, here is your 2450 mhz set.
Low 1.2:1 swr at 2450...
Old Jul 16, 2012, 04:00 AM
Joined Nov 2011
Hello Christopher, these are your antennas in the first pic (rg-405 semi-rigid cable for fatshark mounting),
and
Enzo, these are yours in the second pic.
Old Jul 17, 2012, 06:22 AM
Joined Nov 2011
Just to explain the deal with the "soft bend" as opposed to the 90° connector.
I am currently building the antennas with RP-SMA connector with a bend in the coax line. What I do is I remove the plastic sheeting from the rg-316 for a bit more than 1"
or about 3cm , and I bend to 90° than I let the solder flow in the cable shield to have a firm and solid bend, than I use the plastic tube over the whole thing.
I am doing this because I received a batch of bad 90° rp-sma connectors, where the antennas resonate at much higher frequency with the same size lobes. So I discarded those connetors and I am waiting for a different brand of connectors to try out.
The antennas you see with a 90° connetor itself are the ones with SMA connector.
I have those and they work fine.
This explains the differences you see in the pics between some antennas with 90° connector and a soft 90° bend...
Old Jul 17, 2012, 10:18 AM
kdrcguy is offline
Find More Posts by kdrcguy
Aerial Photography
Canada, BC, Vancouver
Joined Jun 2012
You have a nice selection and I love the ability to choose the connector.
I, however, would be much more interested if you would have a RHCP helical antenna for 1.3ghz that is tuned to the proper frequency and properly matched. 1.3 is a popular frequency and a lot of people use it, including myself.
I can make my own CL and SPW, but a helix is not as easy, and even more difficult to match. Regardless of that, I made a 15 turn helix and matched it and it seems to work fine, but I would like something that is professionally made.
kdrcguy is offline Find More Posts by kdrcguy
Old Jul 17, 2012, 12:25 PM
Joined Nov 2011
a 15 turn 1.2-1.3ghz would be a HUGE cannon, that can't be shipped around the world too easily. a 6-7 turn Helical would be definitely something that's on the drawing board. If I recall correctly the 100km record was made with a 6 or 7 turn Helical on that frequency.
I will look into it soon.
Old Jul 18, 2012, 12:38 AM
GFTbak is offline
Find More Posts by GFTbak
België, Vlaams Gewest, Geraardsbergen
Joined Mar 2010
Hi KondorFpv
I ordered same set like luca (but in green if possible)
(2450 - 1sma 90° en 1straight - green)
How long takes shipping to Belgium?
greetz (-> nice selection BTW)
GFTbak is offline Find More Posts by GFTbak
Build Log New "TOBA" F3B/F from RCRCM available through www.soaringusa.com target Multi Task F3X 202 Mar 04, 2013 02:28 AM
New Product www.circular-wireless.com: home of the 100/200Km world range record antennas sircana FPV Talk 148 Jan 13, 2013 06:14 AM
New Product www.HobbyWireless.com New FPV wireless store riosouza FPV Talk 11 May 22, 2007 12:40 PM
new antenna from www.Azarr.com Fred Bronk Parkflyers 8 May 05, 2001 03:21 PM
