Espritmodel.com Heli Air
Old May 28, 2012, 11:03 AM
Joined May 2012
Ebay 320amp brushed esc and car starter
Hey,
I put this to aircrafts because i think you aircraft guys use the most powerful escs, might be wrong too.
I found a 320amp esc for brushed motors on ebay, here is a link:
Link to ebay
Actually there are few different 320 amp rated escs.
But could it really handle as much as 320 amps, that is the question, for 30 dollars, I personally don't think so. But what do you think/know?
Other question is can I drive a car starter motor with it? Is the speed control system capable of controlling a starter type motor? How much output voltage, is it same as the input?
If the starter draws roughly 200 amps at startup (2 kW starter, 2000 W / 12 v = 166 amps), it actually doesn't have to handle 320 amps. I know starter draws good amount of amps when rpm=0, but if it is rated at 2kW?
Let me know what do you think.
And btw,
I really don't need answer ''starter won't last'', I know and i don't care
Thanks for your help!
narxer is offline Find More Posts by narxer
Old May 28, 2012, 03:36 PM
Senile Member
Lnagel's Avatar
Moab, Utah, USA
Joined Apr 2003
The Ebay listing states that the ESC is for a car 540 motor. Those pull 30 to 40 amps at the most. IMHO, if you put 320 amps through that ESC the printed circuit board copper traces would instantly vaporize.
Larry
Lnagel is offline Find More Posts by Lnagel
Old May 28, 2012, 03:49 PM
Joined May 2012
Damn,
Any other suggestions, I would like to control a car starter with ESC. I read somewhere that someone had put heavy-duty FETs in series and it worked. Any open source plans for high amp ESC?
Old May 28, 2012, 04:00 PM
Senile Member
Lnagel's Avatar
Moab, Utah, USA
Joined Apr 2003
That would be heavy-duty FETs in parallel to increase current capacity. You might try searching for speed controlers for marine trolling motors. Good luck.
Larry
Old May 28, 2012, 07:07 PM
Wake up, feel pulse, be happy!
C₄H₁₀'s Avatar
Joined Aug 2009
Those RC car ESCs are rated a little funny and tend to work under different application-specific rules than planes. It's not uncommon to see ratings in the hundreds of amps because there will be moments when huge amounts of throttle are applied and the motor isn't able to follow, resulting in very brief spikes of truly massive current.
Running 320A through it for any significant length of time would fry the ESC pretty fast. The continuous capability of the one on eBay is probably in the range of 60A or so.
I know you can get some seriously big brushed ESCs (several hundred amps), but they do cost a lot. They're German-made and I can't for the life of me remember the name.
C₄H₁₀ is offline Find More Posts by C₄H₁₀
Old May 29, 2012, 06:08 AM
homo ludens modellisticus
Ron van Sommeren's Avatar
near Nijmegen, Netherlands
Joined Feb 2001
All controllers are also available without water-cooling, 6s to 24s LiPo, 100/200/300/400A
http://fightercatracing.com/index.ph...com_virtuemart
@C4H10
www.$inu$leis$tung$$teller.de , sinusoidal commutation not trapezoid
Vriendelijke groeten Ron
diy motor tipsDrive Calculator
diy motor groupCumulus MFC
• Get a life ... get a 3$ Wattmeter
Ron van Sommeren is offline Find More Posts by Ron van Sommeren
Old Aug 20, 2012, 06:28 AM
Joined Aug 2011
Do you know someone who mosfets on pcb?
schematics?
djgorandj is offline Find More Posts by djgorandj
Old Aug 20, 2012, 11:31 AM
Dieselized User
gkamysz's Avatar
Chicagoland
Joined Feb 2000
Ron we need a brush ESC here.
The rating of the ESC will depend on the load placed on the motor. If the load is small it's possible a 50A ESC will do. If the load is large, you may need a 200A ESC or larger.
http://kellycontroller.com/kdz242001...spm-p-939.html
Greg
gkamysz is offline Find More Posts by gkamysz
Latest blog entry: A tiny diesel engine AE 0.1CC
Found --found/closed/thanks rcfanatic--Brushed r/c car ESC that can handle 11.1 lipo fly_right Cars - Cars and Parts (FS/W) 6 Apr 14, 2012 07:39 PM
For Sale Rc car and truck for sale ebay link dillywilly300ex Cars - Trucks and Parts (FS/W) 0 Apr 06, 2012 08:57 PM
Discussion Replacment brushed ESC for the NitroRCX drift car. B dog Electric Power Cars 5 Mar 06, 2012 08:20 PM
Discussion help , need pwm ESC for fwd/rev brush electric car barb wire Car Talk 12 Jan 27, 2010 08:53 PM
