This thread is privately moderated by puplover, who may elect to delete unwanted replies.
Old May 28, 2012, 10:54 AM
puplover is offline
Find More Posts by puplover
Trader Rating: 54
puplover's Avatar
United States, VA, Gainesville
Joined Oct 2007
Trader Rating: 54
For Sale
Sterling SCHWEIZER SGS 1-34 R/C Sailplane, ARC, vintage
I built this vintage Sterling Models sailplane kit SGS 1-34 (# FS 26) back in the mid 70s after seeing a fellow modeler (Bill Baker) fly one at our old Quinapoxit flying field in Holden, Mass. So I bought and built one and got as far as what you see in the pix. I did have to fix some dings after 38 years.
Scale 2'=1ft.(1/6 scale) Wingspan.... 8' 2- 1/2" Area... 615 sq.in.
Weight... 2-1/2 lbs (less R/C equip). Modified Eiffel 400 soaring airfoil.
Will launch with a Cox .09 or any.10 engine ( throttle not needed and about 1-1/2 minutes of fuel) with a power-pod of choice or set up with a tow line hook for R/C tow plane assist. The kit power-pod parts were lost along the way but the outlines are on the plan to copy and build but a pre-built plastic pod would be lighter. The elev.and rudder pushrods are installed and are both attached inside the fuselage.
The model needs to be final sanded, tail wheel or skid?, the horizontal stab glued in, a balsa peice put over the tail cone, hinges glued in, R/C gear installed, and then covered. ( I have 4 six ft. rolls of white Towercoat for an extra 32.00)
The canopy is mint, the plans are not mint but can be followed for all info. The Kraft wheel is installed Some of the decals from the sheet can probably be used and the rest are good enough to copy from.
Asking 280.00.
This is local PU for obvious reasons but I will drive to meet in a 100 mile radius from Gainesville, VA. (If you have money to burn I will ship in professional box)
Will answer your questions. Also cell# is 571-213-6833
Thanks for looking
puplover is offline Find More Posts by puplover
Old May 23, 2013, 01:29 AM
fritzke is online now
Find More Posts by fritzke
Trader Rating: 0
Joined Sep 2006
Trader Rating: 0
Hey there,
Did you ever sell the Schweitzer? I ask because I have a partial kit in need of plans, and would pay for a copy of them...
I have some very reduced plans in the AMA kit plan book, but they are just 8x5 or so, really small. My kit has the decals, canopy, a little bit of wood and nose cone, and the power nacelle parts. Otherwise, nothing. I am tempted to build one, but no plans.
I am active on RCuniverse, not so much over here on groups.
Dave Fritzke
fritzke is online now Find More Posts by fritzke
Old Oct 27, 2015, 10:14 AM
specsafety is offline
Find More Posts by specsafety
Trader Rating: 0
United States, CA, Diamond Bar
Joined Aug 2014
Trader Rating: 0
did you ever sell this?
specsafety is offline Find More Posts by specsafety
Old Oct 27, 2015, 09:35 PM
puplover is offline
Trader Rating: 54
puplover's Avatar
Joined Oct 2007
Trader Rating: 54
Hi, sorry for the response delay.
The first ad on RCG was the Schwiezer in bare bones without a power pod. The other was rtf with the pod and an OS .10, txt and tx. I finished it and put 2 flights on it.
Which ad did you respond to and where are you located.
Regards, John
Regards, John
Sold Vintage R/C Bodies 1/10th spiderxx Cars - Cars and Parts (FS/W) 0 May 01, 2012 03:46 PM
Sold 34" Sterling Schweizer 2-32 $50.00 Shipped skypilot_one Aircraft - Sailplanes (FS/W) 1 Mar 03, 2012 05:55 PM
For Sale Vintage Sterling Schweizer SGS 1-34 kit NIB nero1156 Aircraft - Sailplanes (FS/W) 1 Sep 25, 2011 06:38 PM
