Old Oct 06, 2012, 07:00 AM
moparmyway is offline
Find More Posts by moparmyway
Why the dirt on the wings?
moparmyway's Avatar
New York
Joined Jan 2009
Please feel free to take your time ...............
Nice cool weather is coming around, when they get done, I will be here. No rush ........... make a few different props if you choose and send them in as well .................... its all up to you if its a folder or a regular prop. Ready for anything Dude !!!
moparmyway is offline Find More Posts by moparmyway
Old Oct 06, 2012, 07:22 AM
VooDoo Child is offline
Find More Posts by VooDoo Child
Drinks Day Old Expired Milk
VooDoo Child's Avatar
United States, OR, Portland
Joined Aug 2010
Those 6X10's look SEXY there DUP
VooDoo Child is offline Find More Posts by VooDoo Child
Old Oct 06, 2012, 07:44 AM
sebbe is offline
Find More Posts by sebbe
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
Yepp, ,,,,, sure looks nice..
sebbe is offline Find More Posts by sebbe
Old Oct 06, 2012, 12:26 PM
arcticflyer is online now
Find More Posts by arcticflyer
arcticflyer's Avatar
Canada, SK, Prince Albert
Joined Jan 2006
DownUnder - I did some static this morning with your 7x10 folders. Using a 50mm spinner they come out to be 7.5x10's which is good (little more torque). Using a Thor
45C 3300 6S I got 4.6KW at 228amps STATIC. Will get you in flight data soon as that is the only thing that really matters! Not much time left snow in the forcast!
arcticflyer is online now Find More Posts by arcticflyer
Old Oct 06, 2012, 04:57 PM
DownUnderPilot is online now
Find More Posts by DownUnderPilot
2012 NZ Speedcup - 231 MPH
DownUnderPilot's Avatar
New Zealand, Tasman, Richmond
Joined Mar 2006
Looking great! Can't wait to see how they go in the air. Do you know the rpm?
DownUnderPilot is online now Find More Posts by DownUnderPilot
Old Oct 06, 2012, 05:21 PM
Joined Jan 2006
Video and numbers for your 7x10's are over on the Monster 1.1 build thread...got a flight in today!
Old Oct 06, 2012, 07:15 PM
SB7 is offline
SB7
Find More Posts by SB7
SB7
I am actually really slow
Brisbane
Joined Jun 2008
Few more pics of the 8x13, I have some different carbon coming soon that I will be using for them but this one will be adequate to do some testing on. Settled on a layup using over 10m of 12k tow! Weighs in around 16.4g which is under my target weight, so all happy there. Came out perfectly balanced.
Next up is the 7x10's
SB7 is offline Find More Posts by SB7
Old Oct 06, 2012, 07:29 PM
Joined Aug 2010
I need a 7X10 fixed soooooo bad....every time i look at that APC on my plane,i just want to vomit in my mouth a bit...i know-TMI,but it is just how i feel.
Old Oct 07, 2012, 03:35 AM
moparmyway's Avatar
New York
Joined Jan 2009
My gosh !!!!!!!!!!
I never thought perfection could look so dark !!!
AWESOME !!!!!!
What balancer do you use ?
Old Oct 07, 2012, 04:10 AM
SB7 is offline
SB7
SB7
Brisbane
Joined Jun 2008
Originally Posted by moparmyway View Post
My gosh !!!!!!!!!!
AWESOME !!!!!!
Thanks man! That one will be coming to you hopefully sometime this week.
For a balancer I use a small diameter hardened threaded shaft with two tapered thumb screws on each end that center the prop once tightented. Then I place each end of the shaft on a wine glass aaand thats it. Works better then any ball bearing supported balancer ive used. Havnt used one of those magnetic balancers before though so Im not sure how my method compares to that.
Old Oct 07, 2012, 06:37 AM
moparmyway's Avatar
New York
Joined Jan 2009
OK, sounds like you get it pretty close.
I use a magnetic balancer, and they are not easy to use .............. I mean, they are easily used, but it takes forever to balance some props ............... very repetetive.
If I had to do some lightening to balance better, would I sand away, or add something to these gems ?
Old Oct 07, 2012, 07:20 AM
SB7 is offline
SB7
SB7
Brisbane
Joined Jun 2008
Definitely don't add anything, then you run the risk of whatever you add coming off. I normally just get some 240grit paper and take material off the top surface off the blade till its balanced. Then hit it with some 800, then 1200, then 2000, then polish. If you take your time you wont notice its been sanded.
I'm sure other people have different methods but that's mine. If you really wanted to get serious you can balance the hubs aswell, I normally don't worry about that though. Most of the time I pull them out of the moulds and use them!
Old Oct 07, 2012, 08:32 AM
SB7 is offline
SB7
SB7
Brisbane
Joined Jun 2008
Voodoo, any idea how much power you want to run through the 7x10? I have two 7x10's ill be doing, one for F5D and one for F3S.
Estimated power ratings for each
F5D 7x10 - 2kw
F3S 7x10 - 5+ kw
Which one you need man?
Old Oct 07, 2012, 09:52 AM
moparmyway's Avatar
New York
Joined Jan 2009
The 5+kw one for me !!!
Old Oct 12, 2012, 05:13 AM
SB7 is offline
SB7
SB7
Brisbane
Joined Jun 2008
Thought I'd share something I played around with this arvo, it's a cast 8x13... Not something I would use on anything but interesting anyway. I'm looking into different production methods and this is something I tried.
Is it usable? Yes, on low power
Stronger then an APC? Not sure as its only been cureing for 3 hours! (forced it to cure under heat as I wanted to see results!)
Ben
Alert Building your own (bipole) antenna: The quarter wavelength roundup for beginners Bram1982 FPV Talk 6 Apr 27, 2012 04:12 PM
Mini-HowTo how to make your own Z bend pliers and other cool how to articles! RogueTitan Foamies (Scratchbuilt) 2 Sep 06, 2011 11:26 AM
Discussion September's Speaker - How to Build Your Next Mars Rover or Glider kyle23 South Bay Soaring Society 0 Sep 03, 2011 06:28 PM
Build Log Sparrow Hawk, Or, How To Build And Crash Your Very Own Park Flyer Murocflyer Parkflyers 112 Jan 15, 2007 09:19 PM
Design & Building your own folder propellers Cebola The Builders Workshop 48 Mar 25, 2005 06:46 PM
