Old Jan 10, 2013, 01:23 AM
AUSELECTRIC is offline
Find More Posts by AUSELECTRIC
Joined Nov 2004
Well after cutting the wings this plane is now stuffed, happy for you to send it down for me to look after. Lol
AUSELECTRIC is offline Find More Posts by AUSELECTRIC
Old Feb 12, 2013, 05:07 PM
AvB is offline
AvB
Find More Posts by AvB
AvB
Wind, hill, ... I'm keen ...
AvB's Avatar
Australia, QLD, Woody Point
Joined Nov 2006
No big progress with Scratcho stuff, but since Iíve been posting stuff on other threads I thought Iíd bring it all together here to make a bit of an update. On the macro level:
MOULDS
Still had absolutely no success finding a cheap way to get the Scratcho wing, stab, fin moulds cut, and since I refused to pay commercial rates the mould project remained bogged.
I want to keep making some Scratchos, but remember I ruined the original ones when I repaired and polished them. I did try to re-face them but actually made the situation worse and gave up. So I finally decided to get Mike in the UK to cut the fin and stab moulds. Shipping wonít be too bad as theyíre not so big. I should have the new fin and stab moulds soon.
Well, I have had a go at making a polyurethane filled wing using a mylar splitter plate. Unfortunately the wing is a failure! But there's hope! ... read on ...
NEW PLANES
After Christmas I finished building the 2 Scratchos using the experimental full-foam core wings that I worked on prior to doing the half-cores vacuumed in to the skins. It was a lot of work, post-painting and so on and repairing fin and stab that were made in the stuffed moulds. One is sitting waiting to go to a new owner in NZ, and the other Iíve been flying quite a lot.
FLYING AND CRASHING
Iíve got absolutely heaps of flying with the Scratchos. Their toughness means that I can fly in all sorts of spots and conditions.
I totally love flying the light PU version, with the tips crudely hacked back to elliptical shape.
So I took the slightly heavier version and cut its wings and shaped them better, to see how it flew. I reckon it was slicker, better rolls, better loops. So if I do go ahead with cutting SCratcho wing moulds I will redesign the wing with elliptical tips. I was DSing that plane with Eric and Astan at Byron Bay for ages, and finally flew it into the tops of the trees covering the slope at about 130mph and it now needs significant repairs to the leading edge!! It wasnít built with DS in mind but has been such a superb performer you just have to DS it to see how fast it can flick the turns!! The socked carbon main spar in the blue foam core is so stiff (and aileron/ flap stiffeners too) Ė I think thatís what gives it the performance.
The newer green/ yellow one, made from the experimental wing, is very responsive but I notice when I DS it that it shimmies and wobbles a bit more than Iím used to, and I think itís because itís a light glass wing and has poor torsional rigidity at the tips.
PU FILLED WING
The first PU filled wing is such a success, but the weak point of the technique is that the PU foam does not provide a durable bond of the wing skin seams so the edges are prone to damage and big crashes can tear the skins away from the foam.
So I planned to try using a piece of waxed mylar in between the clamped mould halves as the PU is expanding, so that they can be split apart. The advantage of this would be that areas of dry PU foam could be scraped out around the edges and these areas then filled with a thick bead of expanding epoxy, and the moulds closed again. It should give the best of both worlds Ö a very quick build method, a stiff and light wing, and good durability. It would also allow trenches to be cut for spars and aileron stiffeners for stronger faster wings, and wiring etc could be put in place too.
On Sunday I spray painted the mould and laid up the wing skins and vac bagged them. Then on Monday a bunch of us did the splitter plate and PU process. There is no time to spare and we had 4 people - one per wing side half, mixing for about 10 seconds then pouring and spreading the liquid over the whole skin with gloved fingers. Then the mylar was laid over one half, and the mould closed and clamped.
The splitter plate worked well, but this experiment wasnít a success because when I split the moulds apart and removed the mylar splitter plate, there were some significant deficits in the PU foam. As reported in the PU wing thread, I attempted to fix it and join the wing with expanding epoxy around the edges, but for a number of reasons it was pretty much a total failure. The TE is not bonded together, and the LEís are not great. Worst of all, a good "flex" test and the wing creases quite easily. Very different to the first wing, which is very strong in flex. There are a number of issues that can be rectified next time, but the issue of the poor foam fill during expansion is a worry. I suspect the use of the splitter plate actually reduces the efficiency of the expansion and fill. So the jury is out on whether I proceed further with it.
It was a shame that it failed Ö I was very excited about the potential of this technique! I spent hours painting the mould and used carbon Ė I was so sure it would work.
But I console myself with some words I recently heard: "If you're not prepared to have failures you're never going to come up with anything original"!
FIRMING UP ON SCRATCHO BUILD VARIANTS
Having a wing mould to play with has been great, as Iíve been able to not only learn to build, but also experiment with different techniques towards the aim of producing durable, good performance foam-cored wings with minimal work. At one end, very light, and at the other end, capable of being a 280mph DSer that can land in the rocks.
From all the playing around I now feel that the 3 main ďbuild versionsĒ Iíll stick with are:
1) PU wing, expanded in mould as discussed above - very light and excellent for light air slope fun. AUW around 780gm. Probably just stick with one-step PU application and close mould Ė same as the one Iím flying now.
2) Thicker but comparatively light skin, pre-cut blue foam half cores vac bag bonded into skins and cut flush with hot wire, slots cut for socked spars and stiffeners, edges trimmed for expanding epoxy - all wet up/ poured and mould closed (this is the "Light Scratcho" that flew last year in the US and NZ). AUW around 1050gm. Huge fun on the frontside in 12kts plus, and a brilliant snappy light to moderate air DSer. This really is the ďDucks NutsĒ method and the best quality, most fun Scratcho. Everyone who flies or watches that plane is impressed!
3) Much thicker skins, socked spars etc, foam blocks positioned for servos and wiring, but otherwise fully filled with expanding epoxy. This is the more DS oriented version, AUW around 1600gm without ballast. Can be tweaked, eg the rear half of the wing could be blue-foam core to keep the weight down.
So my project for a while to come will be to make another one of each of the above versions, putting together all that Iíve learnt from each of the techniques.
THE FUTURE
All I can say is Ė I keep thinking how much easier the design/ prototyping/ mould process would be if I had my own CNC machine! Thatís another story. But imagine being able to tweak your wing design and have new Corian moulds in a few days. Or cut out your own perfectly shaped servo trays, control horns, etc. etc. Hmmm.
AvB is offline Find More Posts by AvB
Old Feb 12, 2013, 11:55 PM
A10FLYR is offline
Find More Posts by A10FLYR
Dean
A10FLYR's Avatar
USA, CO, Littleton
Joined Apr 2005
Answered my question. Thx Andrew..
A10FLYR is offline Find More Posts by A10FLYR
Old Feb 13, 2013, 02:15 AM
AvB is offline
AvB
AvB
AvB's Avatar
Joined Nov 2006
OOOoops!!
Went down for a late afternoon short fly here at Woody Point. Great wind, pretty good angle so the green Scratcho was carving and rolling energetically. It's a really small and not steep slope, so there's a lot of horizontal wind component, and trying to do consecutive loops can leave you blowing back if it slows at the top of the loop. First time it landed gently in a Casuarina tree so it was off with the sandals and a tree climb recovery. Five minutes later it just didn't make that third loop easily and went back too far, and pulling too much elevator it stalled (I think) ... tried to recover but from a fair height it dropped really hard into the top of the hill, nose first and slightly off angle.
Really I should be impressed with the lack of damage. It was a big hard crash, and it's snapped the fuz where it previously broke (in a huge brain fade dumb thumb up at T-Bones). It was only lightly patched so no surprise it broke there. You can see the PU foam inside the fuz too.
Apart from that, and cracked paint running from the inner flap corners it's OK. I am sure the light glass skin has been damaged (you can see a white line), but it's still strong. Under the paint, I can't feel the cracks in the skin. I can bend the wing really hard and it is really solid. I don't think it warrants patching the wing. I like solid foam cores and Ampreg!
Old Feb 13, 2013, 11:06 AM
ALEX HEWSON is offline
Find More Posts by ALEX HEWSON
Remember... Fly for fun!
ALEX HEWSON's Avatar
Christchurch, New Zealand
Joined Jul 2005
Loving the Scratcho testing!
ALEX HEWSON is offline Find More Posts by ALEX HEWSON
Old Mar 03, 2013, 04:09 PM
AvB is offline
AvB
AvB
AvB's Avatar
Joined Nov 2006
57sailplane asked me to post the diagram showing what I meant by undercut tips.
This was sent to me by Larrikin.
The tips are also cut off at an 8 degree angle from the flightline.
Old Mar 03, 2013, 05:19 PM
tim_mellor is offline
Find More Posts by tim_mellor
Plays with Toys
tim_mellor's Avatar
Port Fairy, Australia
Joined Jun 2005
Was just having a read through the thread. I met those guys with the Antonov in my shop last year in March when they were here doing some Joy Flights over our Folk Festival. Noisy beast with a stall speed of not very much
Really interesting thread with the foam filling. Some of the F5B planes of years gone by used to run milled foam cores for their molded wings so they could drop the skin weight and raise the strength.
tim_mellor is offline Find More Posts by tim_mellor
Old Mar 05, 2013, 02:48 AM
pope is offline
Find More Posts by pope
Dave Pope Manawatu NZ
pope's Avatar
Palmerston North NZ
Joined Dec 2006
I see you had the same results as we had doing exp. PU with garaths wing, we are going back to hollow molded for a while. just about to start building my cnc so the we will be away. Big learning curve so will take a while. Lucky for us there is a local mate that has built his own cnc so will be able to get help when lost.
pope is offline Find More Posts by pope
Old Mar 05, 2013, 05:21 AM
AvB is offline
AvB
AvB
AvB's Avatar
Joined Nov 2006
Dave, I had success this time! http://www.rcgroups.com/forums/showt...721451&page=15
All the best with the CNC venture! Sort it out fast so you can make moulds for us! Make sure you have enough X axis to be able to make one piece wings up to 1.9m or so!
Old Mar 05, 2013, 12:12 PM
Joined Jul 2005
^ +1
Old Mar 07, 2013, 06:34 PM
AvB is offline
AvB
AvB
AvB's Avatar
Joined Nov 2006
New CNC cut fin and stab moulds are being cut now. Looking forward to getting back onto making new Scratchos.
Mike is also cutting me a heap of control horns. I shaped up the "perfect" horns for ail/flap and elevator and he's drawn them up. I'm really excited about that! Hand cutting and shaping the 4 wing horns and the elevator horn, and drilling them out etc seems like a small job but takes quite some time, so it will be brilliant to be able to pick them up and fit them.
Gradually making the building process more efficient!
Old Mar 07, 2013, 07:48 PM
Joined Jul 2005
Woot! When does Peter get his?
Old Mar 07, 2013, 08:24 PM
AvB is offline
AvB
AvB
AvB's Avatar
Joined Nov 2006
2nd week in April Bernd is travelling to CHCH.
Old Mar 08, 2013, 12:11 AM
Joined Jul 2005
Cool!
Old Mar 08, 2013, 01:44 AM
DrFragnasty is online now
Find More Posts by DrFragnasty
Thermal Wrangler
DrFragnasty's Avatar
Launceston Tasmania
Joined Mar 2004
Classic Photo
Kudos to the photographer; classic photo.!
DrFragnasty is online now Find More Posts by DrFragnasty
Discussion Building a heavy Scratcho for US DS trip. AvB Dynamic Soaring 114 Mar 31, 2012 04:39 AM
