The - Foamies (Scratchbuilt) forum - uses a lot of .pdf files and Cad, maybe they would know if you don't get the answer here.
There is also the - CAD/CAM forum |
No.
Unless you have Professional ($1295) or Platinum ($1495). I have 18 Deluxe I've been using "snipping tool" in Windows 7 to screen capture images from PDFs, saving them as raster files, which can be <Insert><picture><from file> in TurboCAD. |
Yes, see my post about using "Snipping Tool"
If the PDF has vector data, how to extract it? Using Inkscape (free), open Al Hogal's Twizzler PDF, save as DXF Using TurboCAD Deluxe, open DXF file Example saved from my TurboCAD 18 Deluxe as PDF and as TCW zipped. |
Jim |
Jim,
Which Vista do you have? Snipping tool applies to these editions of Vista: Home Premium, Business, Ultimate, Enterprise Assuming you used InkScape to change PDF to DXF. Blank screen is normal as there wasn't any vector data in the PDF. Try this: Open your PDF in InkScape, <save as> a raster-image (JPG, or BMP, or PNG). (Save raster-image file where you can find it again) Close Inkscape without saving (as svg) Open new TurboCAD drawing Draw a small square or circle at 0"x0". (This was necessary to do before inserting an image in V12) <Insert><Picture><from file> Choose your raster-image file (return to blank TurboCAD drawing) Place mouse pointer near upper left corner of drawing, left click. Move mouse pointer down to lower right corner of drawing, left click. Your raster image should be present on your drawing. Let me know if you get this far Rick |
When opening the pdf in inkscape, I get a pop-up that ask several questions including precision of approximating gradient meshes and embed images.
I tried to make the precision very high. The image came out ok in Inkscape. Turbocad likes .bmp files but I could not save as a .bmp file. Only one I could see that you had listed above was .png. I saved it as .png. Then tried to insert in Turbocad as a .png and all I got was a blob. Any suggestions? Jim |
Use the scale tool. ref some points and tell it what to be. like this. find a ruler scale in the drawing you know 1,2,3,4 so on. go command line, type scale. all, then specify base point, pick point of 1. hit enter. reference. pick 1 again then point at 2 hit enter. then type new length would be 1. simple.
| Thread Tools | |
| Discussion How do I convert CAD files to PDF? | OFFA 1 | Foamies (Scratchbuilt) | 6 | May 14, 2012 10:30 AM |
| Help! Needed, laser cutter who can work off PDF files quickly | Yellow Baron | CAD/CAM | 42 | Feb 23, 2012 07:48 PM |
| Discussion Can I scan a picture I drew by hand into a cad program to be manipulated and refined? | Speedfreak | CAD/CAM | 26 | Sep 22, 2011 07:36 AM |
| Question What SIM can import standard solid CAD ?? | superdave42 | Simulators | 7 | Oct 13, 2006 06:38 AM |
| how to turn a drawing on paper into PDF file? | Stefan lamers | Foamies (Kits) | 5 | Oct 29, 2004 12:57 AM |
