Old May 27, 2012, 05:54 AM
YUSENWANG is offline
Find More Posts by YUSENWANG
Joined May 2012
TAIWAN TORNADO 7005 (70EDF Blades)
7005 (70EDF Blades)
Blade dynamic balance doesn't disappear for disassembly, Rc player can optionally replace motor power
Aluminum alloy 7075-T6 CNC OR Aluminum alloy 7009 CNC
diameter: 68mm(7005-1)、69mm(7005-2)、70mm(7005-3)
number of blade:5
weight of one blade: 68mm(14g)、69mm(15g)、70mm(16g)
dynamic balanced point:subtraction
shaft:3.17mm/1.7g & 4.0mm/1.7g
shroud:3.6g
www.tw-tornado.com E-mail:mail@tw-tornado.com
YUSENWANG is offline Find More Posts by YUSENWANG
Old May 27, 2012, 05:56 AM
Joined May 2012
TAIWAN TORNADO 7004 (70EDF Blades)
7004 (70EDF Blades)
diameter: 68mm(7004-1)、69mm(7004-2)、70mm(7004-3)
number of blade:4
weight of one blade: 68mm(12g)、69mm(13.5g)、70mm(14.7g)
shaft:3. 17mm/1.7g & 4. 0mm/1.7g
shroud:3.6g
Old May 27, 2012, 05:57 AM
Joined May 2012
TAIWAN TORNADO 7003 (70EDF Blades)
7003 (70EDF Blades)
diameter: 68mm(7003-1)、69mm(7003-2)、70mm(7003-3)
number of blade:3
weight of one blade: 68mm(12g)、69mm(13g)、70mm(14g)
shroud:3.6g
Old May 27, 2012, 05:59 AM
Knife Liddle is online now
Find More Posts by Knife Liddle
Lee Liddle
Knife Liddle's Avatar
Carrollton, Tx
Joined Dec 2006
Originally Posted by CoolerByTheLake View Post
I guess test stands are out of style. So much easier to hold it in your hand!
Hey, hold my fan and watch this!!!
I gotta admit, they have faith in their products. LOL
They do look pretty good though. I`m intrested. Give us some prices.
Knife Liddle is online now Find More Posts by Knife Liddle
Old May 27, 2012, 06:44 AM
scatsob is offline
Find More Posts by scatsob
Bypass Ratio = Infinity
scatsob's Avatar
United States, NC, Jacksonville
Joined Apr 2006
Are these AMA approved?
Some of the blade on some models look kind of thin, especially the larger models. I guess Gary has not had any problems with his, but I think he demands quality. At the very least they should do dye penetration test to make sure there are no cracks otherwise bad things will happen.
scatsob is offline Find More Posts by scatsob
Old May 27, 2012, 06:51 AM
genghiskt is offline
Find More Posts by genghiskt
genghiskt's Avatar
Joined Sep 2011
I was quoted USD 350 for 70mm 10blades and USD 550 for 90mm
12 blades. Haha......
These prices are without motor. Will like to see what banana hobby retail price!!!
Will wait and see....
Good luck my friends......
genghiskt is offline Find More Posts by genghiskt
Old May 27, 2012, 07:59 AM
viperviper is offline
Find More Posts by viperviper
Antarctica
Joined Apr 2012
Pricing is way too high, btw, is it true that all EDF unit must be AMA approved?
Like those from Tamjet, ExtremeRC and etc?
viperviper is offline Find More Posts by viperviper
Old May 27, 2012, 08:04 AM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
Yes too expensive for my hobby budget.
Old May 27, 2012, 08:13 AM
Jayray123 is offline
Find More Posts by Jayray123
OUCH!!!
Jayray123's Avatar
United States, PA, Erie
Joined Sep 2008
Only metal (of any alloy) must be ama approved
Jayray123 is offline Find More Posts by Jayray123
Old May 27, 2012, 09:20 AM
bri6672 is online now
Find More Posts by bri6672
bri6672's Avatar
San Diego
Joined Jul 2009
Can you post the specs and pics one more time?? I didn't get it after the the first 50 posts of the same information....
bri6672 is online now Find More Posts by bri6672
Old May 27, 2012, 11:33 AM
fh64_lucky is offline
Find More Posts by fh64_lucky
Ginger or MaryAnn ??
fh64_lucky's Avatar
United States, TX, Garland
Joined May 2005
I pushed Garys 70mm Mach Alloy fans above 64,000 rpm and they been holding up great.Sounds just as smooth from startup to max RPMs. I still would not hold it in my hands though!!
fh64_lucky is offline Find More Posts by fh64_lucky
Old May 27, 2012, 12:52 PM
monkamarm2000 is offline
Find More Posts by monkamarm2000
smug in granny panties
monkamarm2000's Avatar
NorCal Silicon Valley
Joined Aug 2002
Pretty! Will look nice sticking out of someone's head after it bores through a glass fuse intact, cause there so durable, after a crash! Lol
monkamarm2000 is offline Find More Posts by monkamarm2000
Old May 27, 2012, 01:11 PM
Joined May 2012
Dynamic Balanced System of Medal EDF
1:balance level: rotor balancing level is divided into 11 levels, and each level is increased 2.5-fold. The most demanding level is G0.41 which has single, double balance ability and 3D laser scanning, making it suitable for different types of balancing.
2:guiding balance function: based on measured data the software could quickly calculate quality and its angles by providing a well-round guiding balance function.
The operator can easily complete the balancing function by its guiding.
3:Use existing installation condition on and off 2~3 times.
4:Vector decomposition: reasonable vector decomposition should be conducted through calculated balance quality.
5:Balancing Method: test weight method and influence coefficient method;
6:weight-testing estimation: reasonable balancing weight-testing quality shall be estimated through automatically input data of ro tor and can bring result of dynamic balancing.
7:The speed measuring range: 60 ~ 100000r/min
8:Residual unbalance data: Quality for 1mg , vibration data: 0.01mm / s
9:Dynamic balance one time can reduce 95% unbalance chance.
10:Speed Accuracy 1%%
Old May 27, 2012, 02:16 PM
capt soap is offline
Find More Posts by capt soap
capt soap's Avatar
dallas tx
Joined Jun 2003
At those prices,, Will buy from gary!!!
capt soap is offline Find More Posts by capt soap
Old May 27, 2012, 02:29 PM
Joined May 2012
Price of waiting for the HET Notice
Discussion Green Bay, Taiwan arthur0903 Slope 15 Mar 24, 2012 10:36 AM
Wanted Tornado 3 blade ( grish ) wanted M Spencer Aircraft - General - Miscellaneous (FS/W) 0 Sep 24, 2011 10:18 PM
Discussion BlitzRCWorks Tornado 3D vs. Blade SR RTF Tinytacohead 3D Electric Heli Flying 15 May 19, 2011 12:35 AM
Help! PLEASE HELP new user to Blade cx2 looks likes its in the middle of a tornado,Why? Morphisblazin Coaxial Helicopters 3 Apr 02, 2008 05:34 PM
